Software Archive
Read-only legacy content
Intel Real Sense with Java Script
Aravind_G_
Dear Team,
Initially web application worked well. But from last two days I'm unable to run the samples.
I tried installing with webplugin(Provided by Intel) many times, Its not working.Anyone getting the same problem.
Khalil_S_
What error you are getting ?
Aravind_G_
Dear Khalil,
Greetings!!!!
Please see the pic attached
Khalil_S_
Did you tried on different browser ?
Khalil_S_
You need intel_rs_sdk_runtime_webapp_8.0.24.6528.exe
DKryd
this javascript is currently broken on my laptop. it worked as recently as 2 weeks ago but not now. even with runtime_webapp fresh install no luck on either I.E., Edge, or Chrome.
the 400 error results from resourseaccesstoken return
{"error":{"code":400,"errors":[{"domain":"CapabilityProxy","extendedHelp":"","message":"","reason":"CP-
001","sendReport":""}],"message":"Invalid parameter received in request.","requestId":4}}
so it may be asking for something not created or some such.
Aravind_G_
Hi Khalil,
Tried on different browsers and installed the .exe
Any work arounds?
Khalil_S_
Hey Aravind ,
i am also facing same issue,
I tried on 3 different machines but showing same error.
Khalil_S_
https://software.intel.com/en-us/forums/realsense/topic/597883
earlier same issue was there with Javascript
Colleen_C_Intel
JS API page problem - We're trying to solve this - Could you please reply with your version of ITA (in control panel programs as Intel(R) Technology Access - something like 1.7.0.1011.
DKryd
yes, Colleen, that 1.7.0.1011 version is what is installed on my laptop.
Colleen_C_Intel
Thanks Citação,   We believe there's a certificate issue and it's being worked. Stay tuned.
Colleen_C_Intel
Update - a fix is in the works but has to clear multiple levels of security within Intel before any posting. So again please stay tuned.
Aravind_G_
Dear Team,
Thanks for your continuous effort.
Mr . Colleen my special thanks to you.
Kindly please check the screen shot of my ITA version. I could find it as 1.7.1.
Kindly also request you to update on when it is going to get resolved.
Colleen_C_Intel
There is a problem with the certificate in that version of ITA. Unfortunately it will take time to get the new version released, since there are multiple processes required to clear a new release thru security. Please stay tuned.
ThomasE
Thanks for addressing the issue. Is there an update on this issue?
ahmad_s_1
Bump!
Experiencing the same issue.  Is it universal or only for some installs?
If it takes a while to push a new release, can you give us a workaround or a manual way to fix the issue?
Colleen_C_Intel
Update - still working on what is good way to release and get those permissions. Unofficially, with no legal commit from Intel, let me suggest it might be the weekend before you see a posting.....(depending where you are in the world)
Colleen_C_Intel
There has been an issue lately in launching any browser-based apps for the Intel® RealSense™ technology.  The issue is fixed and your web software will be updated in the next scheduled update window (within 30 days.) In the interim, you can go to this link to manually update the web software.
https://downloadcenter.intel.com/download/25435   (version 1.9.x of ITA)
ahmad_s_1
works like a charm - thank you
Aravind_G_
Dear Colleen C & Ahmad,
It is not working for me. Could you guide me.
