With Intel XDK nothing works only HTML and Jscript but nothing referent to intel.xdk or cordova... now I try to use cordova.inAppBrowser plugin.. I checked on project settings and when I try to invoke get the same cordova is not defined.. and when I try to invoke intel is the same intel is not defined... then my conclusion is that Intel XDK for OSX do not work and I spent a lot of time building this app thinking that the problem is mine.
Please when you fix all the issues for Intel XDK for OSX let me know and I go to develop in this tool again.
- Tags:
- HTML5
- Intel® XDK
Nobody has nothing to said here, I want to know the experiences using Intel XDK for OSX
Alexander,
I use the Intel XDK on OSX. Your app exhibits problems independent of the XDK. You need to show more of your source so I can only speculate what is broken. Try uploading the whole index.html. The JS above the includes is important. If the code is not surrounded by a device ready, the cordova and app have not been loaded.
Hi John, can you tell me if you check my files to see where is the problem
thank you.
Hey now I took the sample project hybrid_app and when I tested on Emulator everything works but when I tested in the mobile device like IOS and Android I get the same message intel is not defined... now what is the problem if the project is a sample project comes to Intel XDK, please I need help because think that the problem is yours... think that at the moment of build the app.. is not include the intelxdk into.
![](/skins/images/D3C0B914909A6564BBB97F4AD1ED1973/responsive_peak/images/icon_anonymous_message.png)
