Software Archive
Read-only legacy content
17061 Discussions
Intel XDK keeps crashing after new update
Tawab_G_
Débutant
2 912 Visites
Hi Intel,
I've been working with intel XDK for a couple weeks and everything was fine until this last update. Everytime when I open my debugger (in simulator tab) It crashes.
I've attached the preview log.
I also upload every log that I get, so you'll notice that it crashes every. single. time.
It's getting pretty frustrating.
0 Compliments
PaulF_IntelCorp
Employé
2 912 Visites
Geoff -- one thing that has helped some people with the crashing Emulate tab is to disable the auto-refresh feature. See this post for details > https://software.intel.com/en-us/forums/intel-xdk/topic/621866#comment-1865357
Voir la solution dans l'envoi d'origine
0 Compliments
15 Réponses
Swati_S_Intel1
Employé
2 912 Visites
Are you on Windows 10? Is your project started using a blank template and does it use App Designer? I see in the log some missing jquery errors. If possible can you send your project zip via private message?
0 Compliments
Geoff_at_CFM
Débutant
2 912 Visites
This is driving me nuts too, this version is almost unusable for me!
0 Compliments
Geoff_at_CFM
Débutant
2 912 Visites
In answer to your questions...
1. Yes Win 10
2. Using Ionic Template
3. Using App builder.
4. Not using jquery.
0 Compliments
PaulF_IntelCorp
Employé
2 913 Visites
0 Compliments
Geoff_at_CFM
Débutant
2 912 Visites
Thanks Paul,
That helped with one app, and I might have forgotten to reset it on subsequent apps? I hope this issue can be resolved.
0 Compliments
Tawab_G_
Débutant
2 912 Visites
Problem seems fixed now ( with disabling the auto-refresh feature )
Will report back if something happens again.
Thanks for the fast replies!
Intel XDK Keeps crashing, even when auto refresh is disabled..
0 Compliments
Shai_D_
Débutant
2 912 Visites
i'm on a mac and the auto refresh makes my xdk crash again and again
0 Compliments
PaulF_IntelCorp
Employé
2 912 Visites
@Shai -- please disable the Emulate tab's auto-refresh, we are aware of the problem.
0 Compliments
Tawab_G_
Débutant
2 912 Visites
Okay, so Intel XDK keeps crashing over and over. the problem is not fixed at all.
I'm getting pretty annoyed about this...I have to debug/simulate alot, imagine it crashing every time, it's making me crazy.
When restarting it says: ''Cleared the selection of the project 'My projectname' reselecting it may cause the problem again"
0 Compliments
Anusha_M_Intel1
Employé
2 912 Visites
@Tawab, is your problem related to this emulator crashing thread? If it is your emulate tab where the crash is occurring, many users have had this go away by disabling auto-refresh.
If some other action is causing the crash to occur and this can be reproduced, we will need more information.
0 Compliments
Tawab_G_
Débutant
2 912 Visites
Disabling auto-refresh didn't work... and Yes this is related related to the emulator crashing tread.
Crash scenario's:
1. I noticed the crash happens when I'm in developer tab with the debugger open and the second I close the debugger my Intel XDK crashes.
2. Also when I got my debugger open and restart the simulator Intel XDK crashes too..
What kind of extra information do you need?
0 Compliments
Aya_S_
Débutant
2 912 Visites
Every time i try to build or emulate a project the platform crashes
OS: windows 7
the reload feature in emulated tap is disabled already
0 Compliments
PaulF_IntelCorp
Employé
2 912 Visites
@Tawab -- you mentioned "with the debugger open" -- do you mean the debugger in the Emulate tab or the debugger in the Debug tab? Assuming you mean the debugger in the Emulate tab, if you close the debugger before you move to another tab, does that prevent the crashes? Have you tried using the Debug tab as an alternative to the Emulate tab? It will actually provide a better debug environment. Please watch this webinar for a demo > https://software.intel.com/en-us/xdk/videos/debug-tab-html5-apps-debugging-using-the-intel-xdk
@Aya -- if you push the button in this image you can "stop" the Emulate tab. I recommend doing this before you leave the Emulate tab to see if that fixes the crash problems you're having:
0 Compliments
Tawab_G_
Débutant
2 912 Visites
Paul F. (Intel) wrote:
@Tawab -- you mentioned "with the debugger open" -- do you mean the debugger in the Emulate tab or the debugger in the Debug tab? Assuming you mean the debugger in the Emulate tab, if you close the debugger before you move to another tab, does that prevent the crashes? Have you tried using the Debug tab as an alternative to the Emulate tab? It will actually provide a better debug environment. Please watch this webinar for a demo > https://software.intel.com/en-us/xdk/videos/debug-tab-html5-apps-debuggi...
@Paul, No that doesn't prevent the crashes unfortunately.
I tried using the debugger in the debug tab, but for some reason intel XDK will not find my device, I've tried everything (all the troubleshooting tips) to no avail. -> (mainly the reason why I use the debugger in the emulate tab that often)
0 Compliments
PaulF_IntelCorp
Employé
2 912 Visites
@Tawab -- did you follow the video that shows how to setup the ADB debug driver (I'm assuming you have a Windows machine) for the Debug tab? That's usually the key to getting it working.
0 Compliments
Répondre
