Software Archive
Read-only legacy content
Intel XDK updated to v 2366
John_H_Intel2
This update was made to fix the following issue from the August release (version 2323):
  • This update fixes an issue with the Intel XDK Windows updater.  Node-webkit was not getting properly updated to a newer version when an automatic update was performed. If you downloaded the installer package and installed directly versus using the automatic updater, the proper version was used.
For detailed information on the release, please see the release notes here:  https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk
Michael_O_2
Alright. Thanks for the info, I will update my XDK very soon.
Hamilton_Tenório_da_
Valued Contributor I
Great. I´m using it now.
Alvin_H_
Failed to install it in my workplace computer (Windows 10 in a domain environment).  Error Message: Intel XDK Setup Wizard ended prematurely because of an error(s).  failed_to_create_dir The system cannot find the file specified.
Adam_L_1
in that version intelXDK on windows 10 I cannot build app for iOS. I recieved error: Please, help
The following build commands failed:
	CodeSign build/device/IDEAerp.app
(1 failure)
Error code 65 for command: xcodebuild with args: -xcconfig,.../ERPApp/platforms/ios/cordova/build-release.xcconfig,-project,IDEAerp.xcodeproj,ARCHS=armv7 armv7s arm64,-target,IDEAerp,-configuration,Release,-sdk,iphoneos,build,VALID_ARCHS=armv7 armv7s arm64,CONFIGURATION_BUILD_DIR=.../ERPApp/platforms/ios/build/device,SHARED_PRECOMPS_DIR=.../ERPApp/platforms/ios/build/sharedpch
Command finished with error code 2: .../ERPApp/platforms/ios/cordova/build --release,--device
ERROR building one of the platforms: Error: .../ERPApp/platforms/ios/cordova/build: Command failed with exit code 2
You may not have the required environment or OS to build this project
    at ChildProcess.whenDone (/Developer/cordova/5.1.1/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:134:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
Please, help
John_H_Intel2
Alvin H.
 Do you have full permissions on your work computer, or is there some sort of software the prevents you from installing?
@ Adam
Please save you entire build log and attach it to to a new thread.
I am using this version on Window10 with no problem. Everything is working well.
Dmitry_S_3
Thank you for creating Intel XDK. But in my applications I stopped working <audio> tag. No sound or moving the slider to the controls. but the ‘play’ changes to ‘pause’. I tried to create a simple application of a pattern «Audio Player App», but it does not work <audio> tag. tested on Android devices version 4.4.2. What happened? 3 months ago <audio> work.
Please, help
PaulF_IntelCorp
@Dmitry -- are you build for Crosswalk? If so, there is a known issue regarding audio playback. We are working on a solution. As a workaround, you can build with shared mode option or upgrade your project to CLI 5.1.1 with the new 2496 release and build with CW15. Then your audio will work.
