Software Archive
Read-only legacy content
17060 Discussions
Issue with certificates
Jerome_P_
Hi there,
I have several apps made with an older computer, and an older Intel XDK. I have a new computer with the latest Intel XDK which has a difference certificate process. I just tried updating an app (importing to XDK then building) and Google is telling me the certificates do not match.
What are my options?
Pamela_H_Intel
Jerome,
You won't get the option to upgrade again. You've already done it.
In XDK,
  • select the app you want to submit (if you don't already have it open),
  • go to PROJECTS
  • open Build Settings (with the "+")
  • select the Android tab
  • go down to the Developer Certificate text box
  • click on the drop down arrow
  • select the upgraded cert (you actually should not see the legacy cert anymore)
  • then build
Pamela
Pamela_H_Intel
Jerome,
You have 2 certs in your account. You probably submitted your app originally with the Legacy cert? I see that you converted your Legacy cert. So now submit to the Play Store with the converted (upgraded) cert - that matches the Legacy cert as far as Google is concerned.
If you originally submitted with a different cert that you created outside of XDK, you will need to import that cert into XDK (assuming you want to use XDK to build and sign).
Pamela
Jerome_P_
Pamela H. (Intel) wrote:
Jerome,
Pamela
Hi Pamela,
Thank you for the fast reply. This is correct, I used the legacy cert during the original submission. I am not sure how to submit with the upgraded cert. Intel XDK keeps applying a general cert for all my apps (which was an upgraded cert). The certification was all down within Intel XDK.
Jerome_P_
So I tried re-adding my project, I don't get the option to upgrade the cert or use the legacy one at all.
Pamela_H_Intel
Jerome,
In XDK,
  • go to PROJECTS
  • then build
Pamela
Jerome_P_
Jerome,
In XDK,
  • go to PROJECTS
  • then build
Pamela
That worked, somehow when I did my test builds, I used the same cert twice. In my mind, I thought I tried both of them on my account. Nope, I was wrong.
Thank you very much, issue is solved :)
