Software Archive
Read-only legacy content
공지
Keyboard comes in front of inputs on Android
Ömer_G_
초급자
2,015 조회수
When using text fields in android, when i click on the field, keyboard comes in front of the text field and i cannot see what is written.
On ios, page scrolls up so i can see what is being written.
Also on AppPreview, it is OK as IOS, but a whitespace is shown in the page.
1.png: Screenshot of the actionsheet (everything is fine up to now)
2a.png: Screenshot of the app on Android which launched by apk (input is behind keyboard, so only way to see is pressing AndroidBackButton)
2b.png: Screenshot of the app which launched by IntelXDK Debug option. --> A whitespace is shown above, what is it?
How can i fix this issue on android?
0 포인트
9 응답
Swati_S_Intel1
2,015 조회수
Which framework are you using?
0 포인트
Ömer_G_
초급자
2,015 조회수
appdramework2.1
0 포인트
Ömer_G_
초급자
2,015 조회수
Any suggestions?
0 포인트
John_H_Intel2
직원
2,015 조회수
App Framework 3.0 has been released. Please upgrade and see if the problem persists.
0 포인트
Ömer_G_
초급자
2,015 조회수
AppFramework 3.0?
I'm using 2.1 as below:
<link rel="stylesheet" type="text/css" href="app_framework/2.1/css/af.ui.min.css">
<link rel="stylesheet" type="text/css" href="app_framework/2.1/css/icons.min.css">
<script type="application/javascript" src="app_framework/2.1/appframework.js"></script>
<script type="application/javascript" src="app_framework/2.1/appframework.ui.js" data-ver="1"></script>
but 3.0 does not have "appframework.js"
How can i use 3.0 as 2.0?
0 포인트
Swati_S_Intel1
2,015 조회수
In App Framework 3.0 support for the query selector library has been removed, that's why you don't see appframework.js file. Instead you are encouraged to use jQuery or Zepto. There are some other limitations, see the release notes below.
The 3.0 version of App Framework removes the following
  1. Query selector library - instead use jQuery* or Zepto*
  2. Only supports Android* 4+, iOS* 6+, WP* 8, FF* OS and Blackberry* 10
  3. No longer provides a "Touchlayer", use Fastclick (https://github.com/ftlabs/fastclick) instead.
  4. Native scrolling is only used. If you need a JS scroller, use an existing one like FTScroller (https://github.com/ftlabs/ftscroller) or iScroll
Swati
0 포인트
Ömer_G_
초급자
2,015 조회수
So I understand that switching an existing application from appframework 2.1 to 3.0 will cause a lot of headache, am i right?
headers, footers, af.ui functions, etc. will they work same without modification as they are in 2.1 or 2.2?
0 포인트
Swati_S_Intel1
2,015 조회수
The af.ui functions work as before.
0 포인트
ale_d_
초급자
2,015 조회수
Hello are you using crosswalk? If yes just switch to crosswalk version 10 even with framework 2.1
0 포인트
응답
