Software Archive
Read-only legacy content
17061 Discussions
Long compile time and low execution speed
Thomas_Stehle
I'm using VS2005 together with Parallel Studio 2011 Update 1. When I compile my software projects with the Microsoft compiler, I have acceptable compilation time and an execution time of 2.9 secs. In the case of the Parallel Composer, however, it takes ages to compile and the execution speed is even lower (3.6 secs) than with the Microsoft compiler. In both cases, the compilation was carried out with /O2 compiler switch and my projects make use of OpenMP.
Am I doing something completely wrong or how is this explainable? And how can I solve the issue?
Cheers,
Thomas
JenniferJ
Hi Thomas,
is /GL (/Qipo) on? It's likely the reason.
is it possible to send us the code using Intel Premier Support - https://premier.intel.com/ ? Or through private response.
Remove /GL to see if the compilation is faster.
The performance: make sure only ONE openmp runtime is running. The Intel C++ Compiler's openmp runtime is compatible with VC's. So you only need to link in the intelc's openmp runtime. See this article for some intructions- http://software.intel.com/en-us/articles/how-to-use-intelr-compiler-openmp-compatibility-libraries-on-windows/
Jennifer
Thomas_Stehle
Hi Jennifer,
thanks for your response. Unfortunately, both /GL and /Qipo were not enabled in my solution, so there must be a different reason for that.
Do you have any other suggestions?
My current compiler settings as displayed by VS are
/c /O2 /I "../../" /D "UNMANAGED_EXPORTS" /D "_CRT_SECURE_NO_DEPRECATE" /D "_VC80_UPGRADE=0x0710" /D "_WINDLL" /D "_MBCS" /EHsc /MD /GS /fp:precise /Fo"Release/" /W3 /nologo /Wp64 /Zi /Qopenmp
Thomas
