Hi.
I`ve tryed to use new version of Manufacturing Flash Tool on my Lenovo K900. But due flashing i`ve got error with such log listing:
- Tags:
- Android* OS
And flashing stopped with an error. Later i reflashed my device with earler version of MFT, but ALL data was LOST. I mean ALL INTERNAL MEMORY WAS ERASED. And internal sdcard is become only 9.7 Gb capacty (was 11.4).
I reflashed my phone a several times with another versions of MFT and PFT, but internal storage card is still 9,7 Gb. WHERE IS MY 2 GB ROM IS DISSAPPEARED?!
I know at least two persons, who get the same problem after using Manufacturing Flash Tool 6.0.43 on Lenovo K900. And all these people had lost part of the phone's memory.
Two more users lost a part of internal memory on Lenovo K900 http://4pda.ru/forum/index.php?showtopic=475854&view=findpost&p=36958052
How to fix this problem?! We have damaged our devices with your program!
Seems this app has a problem with your system.img size, why do you even use this tool? this tool is just garage gui for fastboot, use fastboot commands via hand, or via script.
most likely you need to run resize after you have partitioned your internal memory to gain correct size.
I use Dell venue 8, I don't bother with this useless tool, I just use fastboot directly, to change size of partitions, edit partition.tbl to desired size, My dell system was set at 1024, which is too small when I use my cwm recovery to backup and restore system will fault out as system is too big to go back on 1GB partition, so choice is remove some junk from system or increase system partition size.
I have tried both, and both work, but I decided I want 1.5GB system partition, and increase cache to 1GB from 768MB, to do this I first get size of current partitions.
adb shell
fdisk /dev/block/mmcblk0
p
Once you partition and flash everything, boot to cwm recovery and resize partitions, use resize on cache, data, system, you need to umount cache first, cache may not need but try anyway, before reboot remount cache.
I got resize ideal from social-design-concepts
the size doesn't change until you run resize.
This is how I did mine, I use Linux so adjust to windows as needed.
adb reboot bootloader
run partition script
#!/bin/bash
fastboot oem start_partitioning
fastboot flash /tmp/partition.tbl partition.tbl
fastboot oem partition /tmp/partition.tbl
fastboot erase system
fastboot erase cache
fastboot erase config
fastboot erase data
fastboot erase logs
fastboot erase factory
fastboot oem stop_partitioning
fastboot flash boot boot.img
fastboot flash fastboot fastboot.img
fastboot flash recovery recovery.img
fastboot flash system system.img.gz
then run my recovery script
#!/bin/bash
./fastboot flash /tmp/recovery.tar ./recovery.tar
./fastboot flash /tmp/recovery.envsetup ./recovery.envsetup
./fastboot flash /tmp/recovery.fstab ./recovery.fstab
./fastboot flash /tmp/postrecoveryboot.sh ./postrecoveryboot.sh
./fastboot flash /sbin/partlink recovery.launcher
./fastboot oem stop_partitioning
now run resize .
adb shell
umount /cache
e2fsck -f /dev/block/mmcblk0p6
resize2fs /dev/block/mmcblk0p6
e2fsck -f /dev/block/mmcblk0p8
resize2fs /dev/block/mmcblk0p8
e2fsck -f /dev/block/mmcblk0p9
resize2fs /dev/block/mmcblk0p9
mount -t ext4 /dev/block/mmcblk0p6 /cache
reboot
Thanks for responce, where i can find original instruction from social-design-concepts?
But anyway i want to hear official answer from utility developers - Intel.
While some of what you say maybe true, I can't help but smile, you do know the only reason this thread exists is cause the tool failed? Had the tool preformed 100% correctly this thread wouldn't exist, if OP had just used fastboot like I posted above this thread again wouldn't exist.
So while you may think this tool is great, I don't to each our own, I am also waiting and for a response that I know will never happen, from intel, on this tool, would love to see them tell the OP to do almost exactly what I posted above.
I tried to flash my device(Chuwi VI8 dual OS) and made mistake - erased droidboot.
Can somebody help me, how can i flash droidboot.img from original Android firmware.
I tried flash him with adb fastboot:
Maybe some script for Manufacturing Flash Tool?
UPDATED: i was fix everything. Do not answer.
Sergey M. wrote:hi, Sergey. I've problem just like you, my chuwi vi8 wont boot when swicth to android, but it ok when using windows. its always Message : Entering DNX Mode : Waiting Fasboot command. Please help, tell me how you can fix the problem. Thank you.
