Software Archive
Read-only legacy content
My first program with RealSense using Java
Eduardo_C_1
Hi everyone,
How can I setup and run my first program using Java to build my first aplicattion using RealSense? I tried a lot, but I am stuck on.
Someone can help with this?
My best regards,
Eduardo
RBang
New Contributor II
Where are you stuck on? Also I hope you're not using Eclipse/Android Studio as the IDE for your application.
Yiannis_C_
i am using realsense with c# (so i haven't tried what i am about to propose) but have you followed the steps described below?
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?devguide_java_application.html ;
Sergio_J__C_
Nnice! i wanna try this
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/d...
Eduardo_C_1
I am trying to run the example of CameraViewer.java available on the $(RSSDK_DIR)/framework\Java\FF_HandsViewer . Now I can compile using the Eclipse IDE, but there's an error that I can figure out.
See my print screen about the error:
I am always receiving the status PXCM_STATUS_ITEM_UNAVAILABLE and the error on line 44. Did you know about this problem?
