I am not sure why none of the expressions related to the position of the head are working? I have attached some photo links here that can represent the problem and here's the link to my code. Any help in figuring me out how to make these defined expressions work is really appreciated.
https://github.com/lamiastella/FaceTracking
EXPRESSION_HEAD_TURN_LEFT, | |
EXPRESSION_HEAD_TURN_RIGHT, | |
EXPRESSION_HEAD_UP, | |
EXPRESSION_HEAD_DOWN, | |
EXPRESSION_HEAD_TILT_LEFT, | |
EXPRESSION_HEAD_TILT_RIGHT, |
Mona Jalal.
Hey Mona, regarding head expressions - they are obsolete (API returns not supported when enabling them - they will be removed in the upcoming versions). The reason we decided to remove them is because they are not properly defined (user expects left to be his real left - and not left in camera coordinates).
Obviously the implementation is very simple - and if you know the camera position or some other user calibration you can calculate them using the pose data.
Head turn left/right -> Frontal pose yaw - Current pose yaw > Threshold
Head turn up / down -> Frontal pose pitch - Current pose pitch > Threshold
Head tilt left / right -> Frontal roll pitch - Current roll pitch > Threshold
