I am integrating the guts of the RealSense F200 into a custom built computer/capture rig I am building and I need an extension of the cable that goes from the camera module to the on-board processing in the F200. I am looking to get in contact with one of the hardware engineers in order to find out where I might be able to acquire a longer version of this relatively unique cable. I have attached a picture of it next to a measuring tape in mm. It has 10 pins and looks like it is around 0.5mm in pitch. I imagine longer versions of this cable are needed when manufacturers include the F200 into the tops of computer screens.
Thanks!
You can contact with Amphenol to get such 10 pins cable. Thanks!
SALES CONTACT
Bruce Motavaf
AGIS - Sales Engineer
Amphenol
bruce.motavaf@amphenol-gis.com
408.799.6060
VENDOR PART NUMBER LENGTH REVISION
Amphenol H26311-001 100mm AX1
Amphenol H26312-001 150mm AX1
Amphenol H26313-001 300mm AX1
Amphenol H26314-001 500mm AX1
hello Keith,
i have the same problem than you with the little internal pitch cable !
Do you find a plug to connect it ? I search a convertor: "internal pitch <----> usb 3.0 plug " !
Someone knows it ?
thx for the help
Francois
I found this picture on the web (but without explanation)
it looks like that :
any ideas ?
Francois
up !
if someone could help me ! please !
Fr
Hey Everyone
I'm trying to achieve the exact same thing as Keith B. Did anybody have any luck identifying the hardware to connect to external USB?
Moley
Hi Moley,
I feel less alone ! Tell me if you find a begining of solution ! Thx
Francois
