Software Archive
Read-only legacy content
17060 Discussions
StropheJs - Connecting issues only on debug
Quentin_G_
Hello community,
i'm currently developping an app that support XMPP using StropheJs
When i build, then install manually, it works fine, it can connect to BOSH server.
The problem is when I debug it through XDK, it stuck on the Connecting state.
Weirdly I have answer 200 on hxr POST request to the bosh server.
Anyone can help ?
Thank you very much.
Elroy_A_Intel
Are you debugging your project with the Emulate Tab or the Debug Tab?
Quentin_G_
With the debug tab.
It's working fine on the emulate tab but i have to use debug tab because i have cordova plugins too.
Elroy_A_Intel
What do you mean by it getting stuck if you received a response?
Quentin_G_
It is designed like that :
onConnect : function(status){
        if (status === Strophe.Status.CONNECTING) {
            Chat.log('Strophe is connecting.');
        else if (status === Strophe.Status.CONNFAIL) {
            Chat.log('Strophe failed to connect.');
        else if (status === Strophe.Status.DISCONNECTING) {
            Chat.log('Strophe is disconnecting.');
        else if (status === Strophe.Status.DISCONNECTED) {
            Chat.log('Strophe is disconnected.');
        else if (status === Strophe.Status.CONNECTED) {
            Chat.log('Strophe is connected.');
Emulator or build give me connecting then connected then continue with the code.
Debug is stuck at connecting
