Software Archive
Read-only legacy content
Why when use "omp parallel for schedule(auto)" to different calculation result with environment is 32bit
Cucumber
Hi all,
I have a problem when apply parallel (using omp parallel for schedule(atuo)), please help me reslove it.
The problem is explained as below:
1. Setup environment
- Win XP 32 bit
- Visual Studio 2008
- Intel Parallel Studio 2011
2. Scenario
- Configure Floating Point Model: Stric (/fp:strick)
- Source code apply parallel
void ParallelOMP(short *    outputData)
    int datasize = 512*512;
    #pragma omp parallel for schedule(auto)
    for(int i=0; i<datasize; i++)
        double cal = (i%5 * 10/3) + i/5;
        outputData = (short)cal;
-Code calculate [total] variable
 [DllImport("OMPParallel")]
 public static extern void ParallelOMP(short[] outputData);
 private void btn_Compute_Click(object sender, EventArgs e)
       short[] inputData = new short[512 * 512];
       ParallelOMP(inputData);
       double kernel = -0.80000000000000004;
       short input = 155;
       double total = -37.692307692307693;
       total += kernel * input;
       MessageBox.Show("total = " + total.ToString("G17"));
3. Results
- When apply parallel, [total] = -161.69230769230771
- When not apply parallel, [total] = -161.69230769230768
4. Question
Why when use "omp parallel for schedule(auto)" to different calculation result with environment is 32bi.
How "schedule(auto)" affect to calculation result above? If use "omp parallel for" or "omp parallel for schedule(statistic)" not effect to calculation result.
Note: At Win7 64bit, value of [total] variable is the same when apply or not apply parallel and value is -161.69230769230768
Cucumber
Vladimir_P_1234567890
the answer was posted to "Intel® Open Source OpenMP* Runtime Library" Forum
--Vladimir
Cucumber
Hi Vladimir Polin,
Thanks for your answer.
Cucumber
