Since yesterday evening every IntelXDK Windows 10 UAP Build failed.
Trying to make a build of HelloCordova App. After a long time build process the build process failed with message:
Warning: Windows 10 Apps are not allowed to have a Version with a revision number other than zero. Your Version has been set to 0.0.1.0
Error: Could not add the platform (windows10)
Log File:
Creating a new cordova project. No scripts found for hook "before_platform_add". Adding windows project... PlatformApi successfully found for platform windows Creating Cordova Windows Project: App Name : helloCordova Namespace : initial.project.id Path : ...\helloCordova\platforms\windows Copying template to ...\helloCordova\platforms\windows Copying cordova-js sources to platform_www Copying node_modules to ...\helloCordova\platforms\windows
WHAT IS GOING WRONG? Android Build can be created without problems.
- Tags:
- HTML5
- Intel® XDK
I'll alert our build engineer to see if there is an issue with the Windows build servers.
During another build error I saw more entries in the log.
This is only an extract of the file.
...\MSBuild\Microsoft\VisualStudio\v14.0\AppxPackage\Microsoft.AppXPackage.Targets(2869,5): error MSB3030: Could not copy the file "...\PanelDemo\platforms\windows\build\windows\release\arm\win10\ilc\www\jqm\images\icons-png\refresh-black.png" because it was not found. [...\PanelDemo\platforms\windows\CordovaApp.Windows10.jsproj]
...\MSBuild\Microsoft\VisualStudio\v14.0\AppxPackage\Microsoft.AppXPackage.Targets(2869,5): error MSB3030: Could not copy the file "...\PanelDemo\platforms\windows\build\windows\release\arm\win10\ilc\www\jqm\images\icons-png\refresh-white.png" because it was not found. [...\PanelDemo\platforms\windows\CordovaApp.Windows10.jsproj]
Looks like some issues with either your icons or with a plugin you are using, that has some special icon images. Do you have icons named "refresh-white.png" and "refresh-black.png" as part of your project? In other words, do you recognize those image names?
No I am not using any plugin also no image like "refresh-black.png".
Every project build is failing.
Even if I create the "helloCordova" from the template or any other. It is independent from the Intelxdk version I use or the machine I am using. Since Yesterday every build fails allmost with no errors in the log.
The error message above seems to come from the build server since I do not have such a path in the project (..\PanelDemo\platforms\windows\build\windows\release\arm\win10\ilc\www\jqm\images\icons-png\)
It looks like one of the build servers was failing. The server has been replaced. Let me know if you have any further problems!
Yes now it's running perfect. Thank you for the prompt action.
