Software Archive
Read-only legacy content
17060 Discussions
XDK Bug: IDE does not respect custom Documents folder location
Jeff_S_1
I have My Documents on another hard drive.  So when I went looking for my project I went to My Documents but I didn't find it!
Turns out Intel saved the project to c:\users\user\documents rather than to my custom documents folder that My Documents points to.
PaulF_IntelCorp
You can change that "default" location manually (the XDK is supposed to be smart about it, but something broke some time back and we haven't been able to get it fixed). Locate the "global-settings.xdk" file on your system (location varies as a function of the OS) and find this JSON object inside that file:
 "projects-tab": {
    "defaultPath": "/Users/paul/Documents/XDK",
    "LastSortType": "descending|Name",
    "lastSortType": "descending|Opened",
    "thirdPartyDisclaimerAcked": true
The bit above came from a Mac. On a Mac "global-settings.xdk" is located under "~/Library/Application Support/XDK"
On a Windows machine global-settings.xdk is normally found in "%LocalAppData%\XDK" and the part you're looking for will look something like this:
  "projects-tab": {
    "thirdPartyDisclaimerAcked": false,
    "defaultPath": "C:\\Users\\paul/Documents"
Obviously, it's the "defaultPath" part you want to change.
BE CAREFUL WHEN YOU EDIT THE GLOBAL-SETTINGS.XDK FILE!! You've been warned...
Make sure it is proper JSON when you are done, or it may cause your XDK to cough and hack loudly. :) Make a backup copy, just in case.
John_H_Intel2
That is the default that is used. When you create a new project, you have the option to specify where the project is saved.
Did you specify your external drive when you started the project?
Jeff_S_1
I went with the default folder location.  There is literally nothing in c:\users\user\documents except my XDK projects.
I suppose the expected behavior would be to respect custom Windows folder settings.
PaulF_IntelCorp
 "projects-tab": {
  "projects-tab": {
Jeff_S_1
"defaultPath":"c://Users//User\Documents"
Does not properly respect the flags of windows.
I will have to assume that "c://Users/User" is a field that is derived out of necessity but the "\Documents" folder is one that is hardcodeded rather than respecting proper windows pathing.
PaulF_IntelCorp
Jeff -- you can change that path in that JSON object to point to where you want it to... I've got a long-standing bug/feature request in place to make this changeable via the UI. Paul
