Software Archive
Read-only legacy content
17060 Discussions
algorithm behind the function of renderd.RenderFrame(sample->depth);
Ning_R_
Hi guys, anybody have idea about how to map the value of the deep to the value of the intensity?    the function
what the algorithm behind this.
Thanks a lot ^_^
Ning
Johannes_V_
what exactly do you mean? going from depth data to grayscale?
i have a r200 and the raw depth data is unsigned 16 bit integer. if you want to show it on a standard grayscale (8bit) image, you could divide each pixel value from depth stream by 256 (maybe round the value). you will lose some information by this.
Ning_R_
Thanks Johannes, looks we did  the same way, but the image picture was not good as that in our imagination.   We're trying to modify the algorithm.
