Software Archive
Read-only legacy content
17060 Discussions
r200 camera not detected
Tigran_N_
Hi guys! Has anyone found a solution to this problem? https://youtu.be/rr9S4Lt0QTk
Thanks!
Tigran_N_
I found solution for this problem, it is USB 3 voltage. But now I have new trouble...
Drivers installed only like regular Usb Video drivers, I try to uninstall them and scan hardware several time, but every time installed USB Video Device for 2006 year. I try every version DCM installer, but it's not helped.
"Driver Management concluded the process to install driver usbvideo.inf_amd64_853a149025406013\usbvideo.inf for Device Instance ID USB\VID_8086&PID_0A80&MI_00\7&3B355142&0&0000 with the following status: 0x0."
have you way to install drivers manually or some other solution? Thank you!
(win 8.1 or 10)
