Software Archive
Read-only legacy content
17060 Discussions
copyToClipboard not working
janed_o_
I am trying to use Device plugin copyToClipboard but it's not working...test on Android. please someone help. Thank You
below is my code
<!DOCTYPE html>
<html>
    <script src="cordova.js" id="xdkJScordova_"></script>
    <script src="js/app.js"></script>           <!-- for your event code, see README and file comments for details -->
    <script src="js/init-app.js"></script>      <!-- for your init code, see README and file comments for details -->
    <script src="xdk/init-dev.js"></script>     <!-- normalizes device and document ready events, see file for details -->
    <script src="xhr.js"></script>
   <script type="text/javascript" src="js/SocialSharing.js"></script>
     <script type="text/javascript">
        var onDeviceReady=function(){                             // called when Cordova is ready
           if( window.Cordova && navigator.splashscreen ) {     // Cordova API detected
                navigator.splashscreen.hide() ;                 // hide splash screen
        document.addEventListener("deviceready", onDeviceReady, false) ;
    </script>
    <script type="application/x-javascript"> addEventListener("load", function() { setTimeout(hideURLbar, 0); }, false); function hideURLbar(){ window.scrollTo(0,1); } </script>
</head>
<body>
     <script>
        function openExternal(elem) {
            window.open(elem.href, "_system");
            return false; // Prevent execution of the default onClick handler
    </script>
 <script>
	//Test for javascript interface "intel.xdk.device.copyToClipboard()".
            function copyToClipboard(text){
                intel.xdk.device.copyToClipboard(text);
</script>
<button onclick="copyToClipboard('hello, world');">copyToClipboard</button>
	<script src="https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js"></script>
	<script src="js/base.min.js"></script>
</body>
</html>
janed_o_
urgent.....please help
John_H_Intel2
The intel.xdk.device plugin is being deprecated, so I suggest that you find another Cordova plugin that will do what you are looking for.
That being said, it should work if you have selected that plugin in the project settings-plugins. Is this in App Preview, XDK, or on a built application? What platform?
janed_o_
IntelXDK ....Windows 10 ......Android
its not working,,,and there no other plugins.
John_H_Intel2
I copied your code, built an apk, installed on an S4 running android 5.0.1 and it copied the "hello,world" just fine.
I then opened a browser, and pasted it in. It worked as it should.
