Software Archive
Read-only legacy content
17061 Discussions
cordova-plugin-googlemaps installation issue
sammoudi_m_
hello ,
i tried many time to install cordova-plugin-googlemaps but always i get this error message
- i get this error with git Repo installation and also local.
- in the installation process i entered both the android key and ios key
PaulF_IntelCorp
The plugin you are trying to install has a dependency on another plugin (look inside the plugin.xml file), which does not get resolved properly during the install. So you need to first install the plugin that satisfies the dependency, then install the plugin that needs the dependency.
The dependency plugin is not published in the Cordova NPM registry, so you have to install it as a git repo, as follows:
Then you can add the first plugin by ID, since it has been published to the Cordova NPM registry:
PaulF_IntelCorp
We've uncovered an issue in the plugin manager that may result in that error message persisting, when you try to add a plugin as a git repo, it doesn't affect all plugins, but it does seem to have an effect on the dependency plugin. To get around that problem, you can add the dependency plugin locally by first downloading a ZIP of the plugin repo and then using the "Import local plugin" button to locate the top-level folder of that unzipped plugin on your local hard disk.
sammoudi_m_
i getting the same error when using the local install for the plugin and also the the dependecy
PaulF_IntelCorp
Do it as I have done, above. First install the "dependency" plugin by downloading a ZIP of the repo, unzipping it, and using the "import local" option to add it to your project. Then use the NPM import option. Both are shown in the images in the order you should do them.
sammoudi_m_
i have created an new project
i have downloaded the dependency plugin , unzip it and i have choosen the folder for local instalaltion ,
oppp it is the same error :(
PaulF_IntelCorp
Try using the local import technique for both. Remember to import the dependency plugin first.
sammoudi_m_
i already tried this method . are you working on mac os system ?
Paul_C_
I'm also having the same issue and error them installing the dependency via local install and Git Repo. Are there any other thoughts?
sammoudi_m_
the issue is fixed
replace plugin.xml with
<?xml version='1.0' encoding='utf-8'?>
<plugin id="cordova-plugin-googlemaps" version="1.4.0" xmlns="http://apache.org/cordova/ns/plugins/1.0" xmlns:android="http://schemas.android.com/apk/res/android">
    <name>phonegap-googlemaps-plugin</name>
    <js-module name="cordova-plugin-googlemaps" src="www/googlemaps-cdv-plugin.js">
        <clobbers target="cordova-plugin-googlemaps" />
    </js-module>
    <description>Google Maps native SDK for Android and iOS</description>
    <repo>https://github.com/mapsplugin/cordova-plugin-googlemaps</repo>
    <issue>https://github.com/mapsplugin/cordova-plugin-googlemaps/issues</issue>
    <license>Apache 2.0</license>
    <keywords>google,maps,geo</keywords>
    <engines>
      <engine name="cordova-android" version=">=5.1.0" />
      <engine name="cordova-ios" version=">=4.0.0" />
    </engines>
    <!-- android -->
    <platform name="android">
        <preference name="API_KEY_FOR_ANDROID" />
        <info>
             In order to run this plugin, you need to obtain Google Maps API key for Android.
             Visit https://github.com/mapsplugin/cordova-plugin-googlemaps/wiki/Installation
             Check our release notes.
             https://github.com/wf9a5m75/phonegap-googlemaps-plugin/wiki/Release-Notes
        </info>
        <config-file target="res/xml/config.xml" parent="/*">
            <feature name="GoogleMaps">
                <param name="android-package" value="plugin.google.maps.GoogleMaps" />
                <param name="onload" value="true" />
                <param name="onreset" value="true" />
            </feature>
            <feature name="External">
                <param name="android-package" value="plugin.google.maps.External" />
            </feature>
            <feature name="Geocoder">
                <param name="android-package" value="plugin.google.maps.MyGeocoder" />
            </feature>
        </config-file>
        <framework src="com.google.android.gms:play-services-maps:9.8.0" />
        <framework src="com.google.android.gms:play-services-location:9.8.0" />
        <!-- plugin src files -->
        <source-file src="src/android/plugin/google/maps/AsyncLicenseInfo.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/AsyncKmlParser.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/AsyncLoadImage.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/AsyncLoadImageInterface.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/GoogleMaps.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/MyPlugin.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/MyPluginLayout.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/MyPluginInterface.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginCircle.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/External.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/MyGeocoder.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginGroundOverlay.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginKmlOverlay.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginMap.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginMarker.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginPolygon.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginPolyline.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginTileOverlay.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginTileProvider.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginUtil.java" target-dir="src/plugin/google/maps" />
        <source-file src="src/android/plugin/google/maps/PluginAsyncInterface.java" target-dir="src/plugin/google/maps" />
        <config-file target="AndroidManifest.xml" parent="/manifest/application">
            <meta-data
              android:name="com.google.android.geo.API_KEY"
              android:value="$API_KEY_FOR_ANDROID" />
            <!-- Google Play Services SDK -->
            <meta-data android:name="com.google.android.gms.version"
                       android:value="@integer/google_play_services_version" />
        </config-file>
        <config-file target="AndroidManifest.xml" parent="/manifest">
            <uses-permission android:name="android.permission.INTERNET"/>
            <uses-permission android:name="android.permission.ACCESS_NETWORK_STATE"/>
            <uses-permission android:name="com.google.android.providers.gsf.permission.READ_GSERVICES"/>
            <!-- The following two permissions are not required to use
                 Google Maps Android API v2, but are recommended. -->
            <uses-permission android:name="android.permission.ACCESS_COARSE_LOCATION"/>
            <uses-permission android:name="android.permission.ACCESS_FINE_LOCATION"/>
            <!-- OpenGL ES version 2 -->
            <uses-feature android:glEsVersion="0x00020000" android:required="true" />
            <!-- GPS -->
            <uses-feature android:name="android.hardware.location" />
            <uses-feature android:name="android.hardware.location.gps" />
        </config-file>
    </platform>
    </plugin>
add a variable and try to import the local plugin again
it works
Paul_C_
It just looks like you've removed the iOS section so the plugin will only work for Android. This won't get things working for iOS... am I correct?
sammoudi_m_
yeah , you can now develop your android application , then install mac os on virtual machine and re-install the plugin and then generate the ios application
Paul_C_
Thanks, I get the Android part... works perfectly.
I think the iOS version needs to work better than that in XDK...
But as you say development can at least be carried out.
Any thought to get the iOS plugin working on Windows PC development?
PaulF_IntelCorp
We have been able to install these plugins on both Windows and Mac machines using the "import local" method. Not sure why the workaround is not working for you guys. We'll try again, but if we are unable to reproduce we will have difficulty coming up with a fix.
Paul_C_
That's fair enough Paul. Thanks for looking in to this or us.
Paul_C_
I've created a new project and downloaded the dependancy plugin from https://github.com/mapsplugin/cordova-plugin-googlemaps-sdk
Extracted and tried to install the plugin locally. I get the error below...
sammoudi_m_
Paul C,
could you please help me how to add multiple markers on the map , from an array ?
Paul_C_
Paul_C_
When you look are plugin file structure there is no Resources folder within the 'Versions\A' folder
Ricardo__Perez
I have the same problem :(
Adding the Repo URL with the Git repo option, adding my variables and Uh ! , the same error :,c
PaulF_IntelCorp
It looks like that plugin is using a symbolic link, which is failing on Windows (I tried this on a Windows 8.1 system). This is not something I believe the XDK can detect and automatically fix for you, it is a problem with the way that plugin is configured. Using symbolic links is not guaranteed to be transportable between multiple filesystems and operating systems.
If you modify the copy of the plugin.xml file to be similar to this:
<?xml version='1.0' encoding='UTF-8'?>
<plugin id="com.googlemaps.ios" version="2.1.1" xmlns="http://apache.org/cordova/ns/plugins/1.0">
  <name>Google Maps SDK for iOS</name>
  <description>Install the Google Maps SDK for iOS without CocoaPods</description>
  <keywords>cordova, ios, googlemaps</keywords>
  <license>MIT</license>
  <engines>
    <engine name="cordova-ios" version=">=3.0.0" />
  </engines>
  <platform name="ios">
    <!-- system frameworks -->
    <framework src="Accelerate.framework" />
    <framework src="CoreData.framework" />
    <framework src="CoreGraphics.framework" />
    <framework src="CoreLocation.framework" />
    <framework src="CoreText.framework" />
    <framework src="GLKit.framework" />
    <framework src="ImageIO.framework" />
    <framework src="libc++.tbd" />
    <framework src="libz.tbd" />
    <framework src="OpenGLES.framework" />
    <framework src="QuartzCore.framework" />
    <framework src="SystemConfiguration.framework" />
    <framework src="UIKit.framework" />
    <framework src="Base/Frameworks/GoogleMapsBase.framework" custom="true"/>
    <framework src="Maps/Frameworks/GoogleMaps.framework" custom="true"/>
    <framework src="Maps/Frameworks/GoogleMapsCore.framework" custom="true"/>
    <!-- <resource-file src="Maps/Frameworks/GoogleMaps.framework/Versions/A/Resources/GoogleMaps.bundle"/> -->
    <resource-file src="Maps/Frameworks/GoogleMaps.framework/Resources/GoogleMaps.bundle"/>
  </platform>
</plugin>
it will work.
Following are the steps I went through. On the last image you can see that it is a Windows machine the XDK is running on. It's only necessary to download and modify the dependency plugin (as I have changed it above) and then you can use NPM to install the other plugin.
