Software Archive
Read-only legacy content
17060 Discussions
hStreams HTSR_RESULT_REMOTE_ERROR
Jianbin_F_
Hey Guys,
I am trying hStreams these days and encounter the following issue.
When running the tiled LU (from hStreams ref_code), the code reports "hStreams_EventWait1: returns: HSTR_RESULT_REMOTE_ERROR: ... segmentation fault"  (core dumped) ./lu_tiled_hstreams -m 6000 -t 10 -s 8 -l row -i 3
The point is that, sometimes the code can run and exit normally, while it reports such an error in some other time.
Note that I am using MPSS 3.6.
Jianbin
Wojciech_W_Intel
Hi, Jianbin. Unfortunately, we've been unable to reproduce your issue locally. On what operating system/hardware configuration did you encounter this problem?
