I set both the depth and color streams to 640*480, but they are not aligned, for example, the depth of (320,240) in color stream is not the value of (320, 240) in depth stream.
I tried pxcprojection, but I can not get correct value, can someone help me? I have tried projection->QueryVertiecs(image_depth, vertices), but the values in vertices are all 0, and tried MapColorToDepth(image_depth, 640 * 480, ij, pos_uv); but the value in pos_uv are all -1,
can someone provide me a sample code to fix my problem?
int width = 640;
int height = 480;
PXCSenseManager *sm = PXCSenseManager::CreateInstance();
sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, width, height);
sm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, width, height);
sm->Init();
UtilRender color_render(L"Color Stream");
UtilRender depth_render(L"Depth Stream");
PXCCaptureManager *g_captureManager = sm->QueryCaptureManager();
PXCCapture::Device *g_device = g_captureManager->QueryDevice();
PXCProjection *projection = g_device->CreateProjection();
PXCPoint3DF32 *vertices = new PXCPoint3DF32[640 * 480];
while (!quit)
pxcStatus sts = sm->AcquireFrame(true);
if (sts < PXC_STATUS_NO_ERROR) {
std::cout << "Unable to acquire the frames!" << std::endl;
break;
if (sm->AcquireFrame(true)<PXC_STATUS_NO_ERROR) break;
PXCCapture::Sample *sample = sm->QuerySample();
PXCImage *image_color = sample->color;
PXCImage *image_depth = sample->depth;
PXCImage::ImageData data_color;
PXCImage::ImageData data_depth;
projection->QueryVertices(image_depth, vertices);
//projection->MapColorToDepth(image_depth, 640 * 480, ij, pos_uv);
image_color->AcquireAccess(PXCImage::ACCESS_READ, PXCImage::PIXEL_FORMAT_RGB32, &data_color);
image_depth->AcquireAccess(PXCImage::ACCESS_READ_WRITE, PXCImage::PIXEL_FORMAT_DEPTH, &data_depth);
// do something
image_color->ReleaseAccess(&data_color);
image_depth->ReleaseAccess(&data_depth);
sm->ReleaseFrame();
sm->Close();
The two cameras cover different areas in the real world. You need to project one into the other to have a matching image. You were right with pxcprojection.
Take a look at the samples, there is one that shows you how to work with projections.
can you tell me which sample? I can not find one that work with projection
There is a newer, more complete example in the latest SDK, R2. Just run the samples browser and it will be there... can't tell you exactly the name of it since I am in Linux at the moment...
I tried pxcprojection, but I can not get correct value, can someone help me? I have tried projection->QueryVertiecs(image_depth, vertices), but the values in vertices are all 0, and tried MapColorToDepth(image_depth, 640 * 480, ij, pos_uv); but the value in pos_uv are all -1,can someone provide me a sample code to fix my problem?
int width = 640;
int height = 480;
PXCSenseManager *sm = PXCSenseManager::CreateInstance();sm->EnableStream(PXCCapture::STREAM_TYPE_COLOR, width, height);
sm->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, width, height);sm->Init();
PXCPoint3DF32 *vertices = new PXCPoint3DF32[640 * 480];while (!quit)
break;
// do somethingimage_color->ReleaseAccess(&data_color);
sm->ReleaseFrame();
}sm->Close();
Hey Binbin,did you find any solution? I also want to do the same thing.If yes, please post a code sample here please!
How can I achieve this with librealsense and something similar to: buffers[1].show(dev, rs::stream::color_aligned_to_depth, s, 0, s, h-h/2);
thanks!
The documentation of librealsense is pretty good. Have a look there:
https://github.com/IntelRealSense/librealsense/blob/master/doc/projection.md
![](/skins/images/3344F5B3B76C91485ED0E980FD0CA95E/responsive_peak/images/icon_anonymous_message.png)
