Software Archive
Read-only legacy content
17060 Discussions
ifort: error #10052: could not checkout FLEXlm license
peng_l_
Hi everyone,
I encounter a problem since which I couldn't fix yet,
The OS is Ubuntu 14.04
Software is Intel® Parallel Studio XE Cluster Edition for Linux* (have SN for 1 year education use)
when I compile a software with ifort, I get the error message :
Error: A license for FCompL is not available now (-15,570,115).
A connection to the license server could not be made.  You should
make sure that your license daemon process is running: both an
lmgrd process and an INTEL process should be running
if your license limits you to a specified number of licenses in use
at a time.  Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /opt/intel/composer_xe_2015.0.090/licenses
**  3.  /opt/intel/licenses/l_SJR5G9B8.lic
**  4.  /home/chpliu/intel/licenses
**  5.  /opt/intel/composer_xe_2015.0.090/bin/intel64/../../Licenses
**  6.  /home/chpliu/Licenses
**  7.  /Users/Shared/Library/Application Support/Intel/Licenses
**  8.  /opt/intel/composer_xe_2015.0.090/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
How can I fix it?
Could anyone give me some advises,
Thank you very much,
LIU Peng
QIAOMIN_Q_
Hello Peng,
Please upgrade the license server to the latest then see if the problem persists. Here is the link to download the license manager https://registrationcenter.intel.com/regcenter/Download.aspx?productid=1938&pass=yes
Please let me know if this works for you.
Thank you.
QIAOMIN.Q
Intel Developer Support
Please participate in our redesigned community support web site:
User forums:                   http://software.intel.com/en-us/forums/
peng_l_
Dear Qiaomin,
I cannot download the license manager by click the link you posted above, it appears:
"Error
This account does not exist"
I already logged in.
Any suggestions?
Peng LIU
QIAOMIN_Q_
Hello Peny,
I have generated a direct downloadble link for you and have sent you the link in a private message, please have a check.
Thank you.
QIAOMIN.Q
Fabricio_C_
Hi Qiaomin
I think i have a similar problem as of Peng, but with a strange twist. Some weeks ago I had problems to use icc/icpc, while ifort was running fine.
Now i cannot use ifort, but icc/icpc is running fine. The client assured me that he had not fiddled with its licenses.
Could you please send or post the link to the updated license manager?
TIA,
Fabricio
QIAOMIN_Q_
Hello Fab,
Have sent the link to your message inbox.
Best,
Qiao
Chunrui_G_
Hello Qiaomin,
I get the same problem whi Fab. Could you please help me to fix it? Thank a lot~
My regards,
Chunrui
md_abdullah_s_
Hello everyone,
I have the similar problem with  Intel® Parallel Studio XE Cluster Edition for Linux* 2016 . I also have a Student 1 yr license. I have installed it under (home)/opt/intel-install/ directory. I installed it for one user (not root) in a cluster environment. I used Serial number activation, and it installed successfully. But when I try to use icc it gives me the error. Could you please let me know how can I solve this issue. Thanks in advance.
Abdullah
Yuan_C_Intel
Hi, Abdullah
I have created a new topic for your question. This old thread is going to be closed for further follow up.
Please reply to the new thread to discuss your issue:
https://software.intel.com/en-us/forums/intel-software-development-products-download-registration-licensing/topic/597155
