- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
buit successfully target version iOS 8.0 by intel XDK 1912 ,After sync by itunes only can see a gray icon ,if you click on it ,the topic became installing.
- Теги:
- HTML5
- Intel® XDK
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Can you install it on other devices?
Are all the devices listed in the provisioning profile you supplied to the XDK?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I tried two devices iphone5 iphone 6 plus , firstly the iphone5 was iOS 7.X it worked fine with the ipa built by intel XDK 1912 , but that iphone 6 plus was not be able to install the same ipa (the two devices were included in the certifaction),unfortunately I upgraded the iphone5 to iOS8.3 ,It was not be able to install my ipa anymore . Now , I can not restore iphone5 to iOS7.X and both of them are not working, nothing to do , pls help
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
That doesnt make any sense. Add these UDID your devices, update the provisioning profile, download it and pick it in the XDK again under the Build settings.
b4e5ca2b91dcc1750b3f9eba7652f2e0a1300c47
ea9dd89e3c1eda0a5e5021d187a253c728f973f4
Build your app again and when the build completes enter this email into the form provided to send me a build. Inteldevice@gmail.com
From there, I can try to install the app on and iPHone 6+ and iPhone 6.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Okay I had rebuilt and sent to you ,please check , thank you
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
You did not send me the successful build notification that I asked for. Rebuild your app, then when you get the build complete screen in the XDK, enter the email address I provided, uncheck the SECURE box, then press the SEND button.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Sorry I sent again
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I upgraded to new version xdk1995 and rebuilt, but still was not able to install, just like before
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
You must not have the UDID of the iphone in the provisioning profile. I used the email that you sent to me to install your app on an iphone 6, that I just updated to 8.3.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I am so sorry John ,I am new hand to iOS, I do not know why the provision status became invalid. Today I rebuilt the provisions and added your two uuids to my devices and one more ipad with system iOS 8.1.3 ,unfortunately still the same result.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I know what your issue is :)
The UDID that you gave to the apple developer portal are incorrect. They probably start with FFFFFF. These are INCORRECT. Whatever app you used to get the UDID from the device is junk. Hook your devices up to iTunes to get the correct UDID.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Yes, I could install and launch your app using the link you sent me.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
That is weird,My three devices are not working ,only display the gray icon ,would you please give me some advice to try?something wrong with my iTunes ?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Heres what I suggest.
Remove the app from device. Build the app again. When the build completes email (like you did for me) the build to an email address that is setup with the mail app on the phone and use the OTA link to install it. I hate iTunes.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I tried OTA ,it appears messy code, because there are chinese words in my app, and failed with "you cannot install it at this time" , though I hate itunes also ,I had to use it
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
