Software Archive
Read-only legacy content
17060 Discussions
jquery $.get throws "ERR_FILE_NOT_FOUND" error
onn_kum_c_
hello good day.
I'm getting this error when trying to use $.get to retrieve html via App Preview
I have added whitelist in build settings. not sure what I'm doing wrong. any help is greatly appreciated
Diego_Calp
Valued Contributor I
Could you post some lines of the javascript code with $.get?
Diego
PaulF_IntelCorp
App Preview ignores the whitelist settings in your project, so those are not relevant to this problem. I suspect this is caused by a workaround that is required to access local files. See these posts for some help using the "data-noxhrfix" option in the head tag:
