Hi!
I created a new blank project, and i tried build it, but it not was success. (I attached error log)
I used this plugin: https://github.com/phonegap/phonegap-plugin-push
(and defaults: StatusBar, Device, SpalshScreen)
What is the problem?
Thank you!
- Tags:
- HTML5
- Intel® XDK
Include this URL in github repo: https://github.com/phonegap/phonegap-plugin-push.git#1.2.1
This is different version and now build it.
There is some incompatibility with the current version of the push plugin. Version 1.2.1 works well with the XDK.
Thanks!
I deployed and tried but not works on every kind of phone. This could be a phone or a plugin problem? Or an option promblem on phone?
Does work:
Samsung Galaxy Note 3 (android version: 5.0)
Xiaomi redmi note 4g (android version: 4.4.2)
Doesn't work:
Doogee DG700 Titans 2 (android version: 5.0)
Lenovo P-70 (android version: 4.4.4)"
My suspicion is this is a phone problem. I think the plugin you are using requires some Google-specific libraries (I'm not positive). There are many Asian phones that are built without the necessary libraries to support Google services, because doing so requires a special license agreement with Google. A tip-off to such phones is whether or not they include the Google Play Store app.
If they DO NOT include the Google Play Store app, then they are phones that probably fit this profile. Is that the difference between the phones in the "does work" category and those in the "doesn't work" category?
Thank you for answer! It is device problem, but all phone includes Google Play Store :-/
Hi!
Why it can't update newer version than 1.2.1 (https://github.com/phonegap/phonegap-plugin-push)? I need the newest version because of some new functions. Thanks the answer!
You can change the version of the plugin directly from XDK project.
You can use up to version 1.4.3 with Cordova 5. The upgrade versions contain Gradle script not supported (we have to wait Cordova 6.0.0).
Bye.
Unfortunately, all phones do NOT include access to the Google Play Store. Many Asian phones do not include the Google services parts that are needed. The Android project is free and open source, but the parts that are needed to access Google services (such as the Google Play Store, Google Drive, etc.) are not free and open. In order to include those parts in a phone (or tablet) the device manufacturer has to sign an agreement with Google. Many Asian devices have their own store and do not have an agreement with Google, so they do not have access to any Google services.
Raiden d. wrote:
With the 1.4.3 version, the debug module always get an error, but with the 1.2.1 version work. Why?
The current debug module builder is based on the "old" Crosswalk build system, which is like the CLI 4.1.2 build system. We are in the process of upgrading the debug module builder as part of the next major release. In the meantime, it has this limitation. In order to debug such an app, that you cannot build with the Debug tab, you have two options:
- remove the problem plugin and debug everything but the code associated with that plugin
- build a "debuggable" version of your app and load it onto your device (see https://software.intel.com/en-us/xdk/docs/intel-xdk-debug-and-test-overview#RemoteChromeDevTools)
Thanks for your answers!
I use this https://github.com/aahedi/PushPlugin
type in ID
com.phonegap.PushPlugin
intelxdk.config.android.xml: add in git repo to #2.4.0 version like this
<intelxdk:plugin intelxdk:name="PushPlugin" intelxdk:value="https://github.com/aahedi/PushPlugin.git#2.4.0"/>
Please add it using the plugin explorer on the Projects tab. See the documentation for details > https://software.intel.com/en-us/xdk/docs/add-manage-project-plugins
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
