Software Archive
Read-only legacy content
17061 Discussões
takepicture method
carmine_n_
Principiante
2.316 Visualizações
i am using the takepicture method but when i display the pic it is huge.
how do you control the size of it when you display it?
thanks.
13 Respostas
Anusha_M_Intel1
Funcionário
2.316 Visualizações
The only way I can think of resizing the image is by using inline CSS rules. But it looks like you are using the deprecated Intel XDK APIs. We strongly encourage our users to switch to their Cordova counterparts because the Intel XDK ones are no longer maintained. Check out the cordova camera plugin instead - https://github.com/apache/cordova-plugin-camera. We also use this plugin in our Image Capture sample that ships with the XDK.
carmine_n_
Principiante
2.316 Visualizações
i will try it.
thanks.
carmine_n_
Principiante
2.316 Visualizações
any idea why i am getting a camera is not defined error?
thanks...
/*cordova plugin add cordova-plugin-camera*/
 /* button  Camera */
   navigator.camera.getPicture(onSuccess, onFail, { quality: 50,
    destinationType: Camera.DestinationType.FILE_URI });
function onSuccess(imageURI) {
    var image = document.getElementById('myImage');
    image.src = imageURI;
function onFail(message) {
    alert('Failed because: ' + message);
      document.addEventListener("deviceready", onDeviceReady, false);
function onDeviceReady() {
    console.log(navigator.camera);
John_H_Intel2
Funcionário
2.316 Visualizações
Did you select the camera plugin in the project settings?
Do you have a javascript error somewhere in your code?
carmine_n_
Principiante
2.316 Visualizações
i do not see the camera plugin.
i started with the tabview template.
the error is 'camera' is not defined.
do i need to start over?
thanks.
Anusha_M_Intel1
Funcionário
2.316 Visualizações
@Carmine,
The tabview template is not a cordova template. It is Standard HTML 5. Read this to know the difference - https://software.intel.com/en-us/xdk/docs/using-the-projects-tab#projtypes
It looks like you need a Cordova app. Follow the link above and you will see how you can upgrade your existing HTML5 app to Cordova from the Project tab. Just click on the little Cordova icon next to Upgrade and it will convert it for you. You will then see that you project type has become 'HTML5+Cordova' and it now has a 'Plugin Management' section. Expand it and add plugins. Camera plugin is listed second in the core plugins list.
carmine_n_
Principiante
2.316 Visualizações
I did all of that and I can get the camera to take the picture, but it won't display.
I don't see where to specify a location to display the pic.
Am I missing something or is it a bug with my samsung s4 mini?
Thanks again.
Amrita_C_Intel
Funcionário
2.316 Visualizações
Hello Carmine,
This might help.
Take a photo and retrieve the image's file location:
carmine_n_
Principiante
2.316 Visualizações
i tried that and when i click the camera button, the camera opens up, i take the pic, hit save, and it just goes back to the screen with the camera button. the pic is gone.
any ideas?
thanks again.
Amrita_C_Intel
Funcionário
2.316 Visualizações
Adding on that you need to specify html tag for myImage and set to height and width 100% so it will solve the sizing problem too.
For example:
<img src="myImage" height="100" width="100">
carmine_n_
Principiante
2.316 Visualizações
getting closer, but it still won't display.
pic is attached.
thanks.
carmine_n_
Principiante
2.316 Visualizações
i just noticed a 'camera is not defined' error.
pic is attached.
thanks.
PaulF_IntelCorp
Funcionário
2.316 Visualizações
Why don't you try the sample we've got, first: https://github.com/gomobile/sample-image-capture it's in the "samples and demos" section of the "start a new project" from the Projects tab
Responder
