Software Archive
Read-only legacy content
the alert message doesn't show when function success javaScript using intel xdk and php
nicolas_r_
hi im trying to add info to a data base whit PHP it works in the DB i get the new register but it doesn't show the alert massage confirming that was all ok.
$( document ).ready(function() {
var $server;
$server = 'http://localhost:8888/registro/www/';
 $('#inclusao').on('click', function(){
    $id = $('#id').val();
    $nome = $('#nome').val();
    $sobrenome = $('#sobrenome').val();
    $.ajax({
        type: "get",
        url: $server+"/conecta.php",
        data: "id="+$id+"&nome="+$nome+"&sobrenome="+$sobrenome+"&acao=inclusao",
        success: function(data) {
        intel.xdk.notification.alert('Usuário Cadastrado!','Aviso!','OK');
            Lista();
function Lista(){
       $.ajax({
           type: "get",
           dataType  : 'html',
           data: "acao=listarusuario",
                $('#listarusuario').html(data);
Lista();
Diego_Calp
Valued Contributor I
Hi Nicolas,
intel.xdk.notification api is deprecated, you should use another way to display an alert.
Take a look if the framework you are using provides dialogs. For testing purposes the simple javascript alert() may work.
Diego
Diego_Calp
Hi Nicolas,
Diego
nicolas_r_
thanks diego =)
Chris_P_Intel
And you should have a failure handler as well.
$.ajax( {options} )  //<-- same options, except no success handler
.fail(function(er){
  // do something
.then(function(data)
//this is the success handler
