The description for Event ID 257 from source Intel Accelerated Storage Manager cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Configuration warning: No users and groups in rste scope section. Access token will be unavailable.
The specified resource type cannot be found in the image file
链接已复制
Hi Leonardo,
Thanks for your reply.
- I am using I9 CPU and 32 GB of memory. MB is from asus and model number is: X299-A. Using SSD drives from Samsung and 1TB each.
- Using Intel Rapid Technology V. 16.7.0.1009
- Using Win 10 Professional 64 bits.
- I would rather send you the reports via email. If possible.
Doron
Hello Leonardo ,
1.
I can still email you the reports I created if need be.
But the version that I have is 16..7.0.1009
and please see image below.
2.
OK I see this link:
https://downloadcenter.intel.com/product/55005/Intel-Rapid-Storage-Technology-Intel-RST-
Is that the correct link? (which should be downloaded?)
It says the file is from: Date: 11/14/2017 and it is called SetupRST.exe.
Please clarify the above.
Doron
Hello again,
I also get this info as shown in the below image.
I tried to un install the Intel Rapied Storage Technology enterprise and still see this folder with all files here:
C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology enterprise
Under the Un Install the Turbo program is not there.
There is another folder see as this one:
C:\Program Files (x86)\Intel\Intel(R) Management Engine Components
Can you provide steps how to resolve the above?
Doron
Hi Leonardo,
In this point I installed the chip-set of this version: Version 1828.12.0.1152 2018/12/24 and they provided this version:
Intel Rapid Storage Technology Driver software
Intel(R) Rapid Storage Technology Driver Software V16.7.0.1009
Intel(R) AHCI/RAID Driver V16.7.7.1023
For this mother board: Prime X299-A and made by Asus.
So what they provided for the MB does not match?
Doron
