Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
How to enable x4 mode QSPI on Arria10 with Micron memory flash on Uboot 2020.04, Altera 20.1
Yoels
Hello, I'm working on a custom board with a Socfpga Altera Arria10 on it with a Micron Serial Nor Flash memory MT25QU01GBBB.
Currently, the Uboot 2020.04 I'm using works with one lane of QSPI data transfer with the Micron memory unit; how can I make it work with four lanes?
I can't find how I can configure it to work this way in the device tree. Also, in the Cadence Qspi driver, I can't find how to change the number of lanes to work with.
I'm working in Altera Environment 20.1.
Any help applaying this change would help.
Thanks in advance, Yoel
aikeu
Hi Yoels,
Do consider using the latest Uboot for your Arria10 development. Referring to the get Uboot section:
https://www.rocketboards.org/foswiki/Documentation/BuildingBootloaderCycloneVAndArria10
Can search the related device tree enablement in the uboot source code, example socfpga_arria10 related:
https://github.com/altera-opensource/u-boot-socfpga/blob/socfpga_v2023.10/arch/arm/dts/socfpga_arria10_socdk.dtsi
You can check with Micron on how their particular device to be enabled as they have tested it for working:
https://www.mouser.com/pdfdocs/Micron_Support_Intel_FPGA.pdf
Aik Eu
aikeu
Hi Yoels,
I will close the thread if no further feedback from your side.
Aik Eu
