Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
Intel 760p NVME SSD VROC Support OS Bootable RAID on x299 (With Benchmarks)
GAcke
As the title suggests, would intel 760p nvme m.2 drives be supported as a bootable raid array on x299 chipset?
I understand that this would need the VROCISSDMOD key?
ncao1
did you watch my video?
GAcke
Yes, I did. Did you use an xpander/hyper card through PCIe?
The other user here used one and got it working.
ncao1
i tried two MB ROG extreme vi and prime deluxe with asus hyper 16x, intel ssd 760p, now intel is still investigating the case
GAcke
Well, my package arrived one day early! VROC up and running and BOOTABLE! Here is my bench (with Crystal Disk Mark v6.0.0)
At any rate, 2x 256GB 760p Intel drives. Running great!
Currently ran on
MSI X299 Gaming Pro Carbon AC
Intel i9 7900x
32GB Gskill TridentZ RGB 3200MHZ
Windows 10 x64
ncao1
Did you use
HYPER M.2 X16 CARD?
SEric
Spanning drives over more than 1 VMD is not bootable, it is for storage only.
I saw the video and saw the error.
Put the drives in a hyper card, do not span vmd.
Make sure the pcie slot is set to x4x4x4x4.
Create volume.
SEric
Mr Trumpz, how are your boot times in VROC?
BDixo1
I watched the video and the same thing happened to me! Has Intel responded with a solution?
BDixo1
Oh , I guess I found my answer here..
GAcke
Sorry I didn't get back to you sooner Birdman.
Windows desktop is visible at about 37 seconds. I auto logon at Win10 welcome screen so that saves a few seconds.
Total load with all my gadgets and my background processes in system tray to load is about 70 seconds. I think the POST test on my board is a little slower though.
I could use the MSI fast boot to speed boot time a little bit, but I like to be able to access BIOS from boot screen.
What do you think are acceptable times?
BDixo1
So I need to find the rste vroc driver for windows 8 for this to work? As shown in your description?
charr13
1. Did you need the Hardware key for your setup in RAID 0 bootable using 4x 760p's on hyper M.2 card?
2. Do you hit a 90 day expiration limit in Intel software?
