Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
公告
Looking for RAID, VROC? You found the forum to ask questions!
VROC software 7.7 GUI problems
MoVij
初学者
6,252 次查看
Upgraded VROC 6.2 to 7.7 - Already have latest version of .Net 4.72 on fully up to date win2019 server
Server has intel boards. No OEM.
We Have exact same problem as
(1) Intel VROC software Driver Version = 7.5.0.1991 problems continued - Intel Communities
on 2 servers
How do we fix this problem:
Application: IAStorUI.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileNotFoundException
at IAStorUtil.SystemReportProvider+<GetVrocDriversVersions>d__22.MoveNext()
at System.Linq.Buffer`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]..ctor(System.Collections.Generic.IEnumerable`1<System.__Canon>)
at System.Linq.OrderedEnumerable`1+<GetEnumerator>d__1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].MoveNext()
at System.Collections.Generic.List`1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]]..ctor(System.Collections.Generic.IEnumerable`1<System.__Canon>)
at System.Linq.Enumerable.ToList[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](System.Collections.Generic.IEnumerable`1<System.__Canon>)
at IAStorUtil.SystemReportProvider..cctor()
Exception Info: System.TypeInitializationException
at IAStorUI.App.Application_Startup(System.Object, System.Windows.StartupEventArgs)
at System.Windows.Application.OnStartup(System.Windows.StartupEventArgs)
at System.Windows.Application.<.ctor>b__1_0(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.DispatcherOperation.InvokeImpl()
at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(System.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
at MS.Internal.CulturePreservingExecutionContext.Run(MS.Internal.CulturePreservingExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Windows.Threading.DispatcherOperation.Invoke()
at System.Windows.Threading.Dispatcher.ProcessQueue()
at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at IAStorUI.App.Main()
0 项奖励
19 回复数
MoVij
初学者
6,246 次查看
Also attaching the System Support Utility Report.
0 项奖励
JoseH_Intel
主持人
6,225 次查看
Hello MoVij,
Thank you for joining the Intel community
About the .NET software, it is supposed to not be necessary when using Windows Server 2019. You can check it here: https://downloadmirror.intel.com/713033/Windows_VROC_7.7_PV_ReleaseNotes.pdf#page=19
Also, there is a version in between 7.5 and 7.7. By any chance have you tested v7.6.0.1023? Intel® Virtual RAID on CPU (Intel® VROC) and Intel® Rapid Storage Technology Enterprise (Intel® RSTe) Windows* Driver for Intel® Server Boards and Systems Based on Intel® 62X Chipset
Jose A.
0 项奖励
MoVij
初学者
6,212 次查看
Hello Jose,
Yes I tried v7.6 as well, It puts an icon in the tray but Still does not launch the software. 7.7 does not even puts the tray icon.
I even downloaded to 6.x - but that gives an error saying driver is newer, please updare GUI software.
I spent hours trying all 3 different version on both INtel boxes - exact same result.
0 项奖励
JoseH_Intel
主持人
6,202 次查看
Hello MoVij,
Let me try to investigate further. I will get back to you as soon as I have updates.
Do you have VROC previously enabled in BIOS prior to install the GUI software?
You can follow this instructions How do I make a RAID Volume with NVMe* Drives via Intel® Virtual...
Jose A.
0 项奖励
JoseH_Intel
主持人
6,186 次查看
Hello MoVij,
We need to gather all the information possible about the error presented. There are no previous reports of issue with the VROC GUI software tool.
Could you please attach screenshots of the installation process up to the point where the issue is displayed. We want to check if any is similar to the ones listed in the VROC issues contained in chapter 6 "Intel® VROC 5.5 for Windows* User Guide". Also share the Windows Event Log image showing the installation error.
We will look forward to your updates.
Jose A.
0 项奖励
MoVij
初学者
6,176 次查看
Hello Jose,
The installation goes without flaw. However the program does not run. There is at least one more thread in community with exact same problem: (1) Intel VROC software Driver Version = 7.5.0.1991 problems continued - Intel Communities
I have also attached screenshots and event viewer. This is happening on 2 servers - Both Intel.
Also attached the file generated by Windows
Thank You.
0 项奖励
JoseH_Intel
主持人
6,167 次查看
Hello MoVij,
Thank you. That is useful information. Let me analyze it and will let you know my findings.
Jose A.
0 项奖励
MoVij
初学者
6,124 次查看
Hello Jose,
Any update?
We have two production servers in limbo and would greatly appreciate some insight. Thank You.
0 项奖励
MoVij
初学者
6,155 次查看
Great. Thank you for looking into the issue.
0 项奖励
JoseH_Intel
主持人
6,116 次查看
Hello MoVij,
Can you please share the sysinfo and the VROC system report from the VROC GUI (you will need to install VROC 6.3 since 7.x is not working for you)?
System Information Retrieval Utility (SysInfo) for Intel® Server Boards and Intel® Server Systems Based on Intel® 61X Chipset
Jose A.
0 项奖励
JoseH_Intel
主持人
6,072 次查看
Hello MoVij,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. I will try to reach you on next Tuesday 24th. After that the thread will be archived automatically.
Jose A.
0 项奖励
MoVij
初学者
5,996 次查看
I suggest- the thread not be archived and kept active till problems is resolved.
This is a software bug  and we should help other intel users as much as possible in one single place. Please have your team research based on Event logs and Microsoft dump files provided till then if possible. We will try to get a maintenance window till then.
Thank you for your understanding and cooperation.
0 项奖励
MoVij
初学者
6,003 次查看
No. These are production systems and we can not easily reboot them as these tools require reboot.
0 项奖励
JoseH_Intel
主持人
5,978 次查看
Hello MoVij,
That's not a problem. We will keep the thread open and will wait for your updates. I will follow up with you next week on May 30th.
Jose A.
0 项奖励
JoseH_Intel
主持人
5,913 次查看
Hello MoVij,
Just following up just to know if you have made any progress or have any updates.
Jose A.
0 项奖励
MoVij
初学者
5,880 次查看
Hello Jose,
Did not get a chance to reboot the servers. Will update as soon as we can. Hopefully this weekend.
Mo
0 项奖励
JoseH_Intel
主持人
5,877 次查看
Hello MoVij,
Thank you for the update. Will wait for next week then.
Jose A.
0 项奖励
JoseH_Intel
主持人
5,844 次查看
Hello MoVij,
Just following up to know if you have made any progress or have any updates.
Jose A.
0 项奖励
JoseH_Intel
主持人
5,815 次查看
Hello MoVij,
We will proceed to archive this thread for now. If you have further issues or questions just go ahead and submit a new topic and refer to this one as the original.
Jose A.
0 项奖励
回复
