Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
Windows 2012 r2 crashes
LAlli
Windows crashes by itself once or twice a week since I implemented VROC. Microsoft doesn't have hotfix yet. Does Intel have something to fix this problem ?
0x000000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL iaVroc.sys
https://support.microsoft.com/en-us/help/2916984/stop-error-0x000000d1-and-windows-server-2012-runs-a-bugcheck-when-you https://support.microsoft.com/en-us/help/2916984/stop-error-0x000000d1-and-windows-server-2012-runs-a-bugcheck-when-you
  • Motherboard Model and Manufacturer: Asus rampage extreme VI
  • Processor Model: I9 7960x
  • Amount of RAM that you have installed: 32gb 4133mhz ddr 4 corsair
  • Numer of Storage devices and their capacity (SSDs and HDDs) on your machine: 2x 16x asus hyper card 8x intel 760p m.2 and dimm2 2x intel 760p m.2 total 10x intel 760 m.2
  • The Drives are used in a RAID (0, 1, 5, 10) configuration?: 1x raid 10 and 3x raid 1
following mini dump is only show last 2 events.
Vroc log is attached.
LAlli
Sstem Report
System Information
OS name: Microsoft Windows Server 2012 R2 Standard OS version: 6.3.9600 System name: SERVER1 System manufacturer: System manufacturer System model: System Product Name
Processor: GenuineIntel Intel64 Family 6 Model 85 Stepping 4 2.801 GHz
BIOS: American Megatrends Inc., 1401
Intel® Rapid Storage Technology enterprise Information User interface version: 5.3.0.1412
Language: English (United States)
Intel controller: VMD
Number of NVMe ports: 10
Intel controller: SATA (AHCI)
Number of SATA ports: 8
RAID option ROM version: 5.3.0.1052
Driver version: 5.3.0.1388
VMD driver version: 5.3.0.1388
ISDI version: 5.3.0.1412
Storage System Information
RAID Configuration
Array Name: NVMe_Array_0000
Available space: 24,428 MB
Number of volumes: 1
Volume member: 1Raid10D
Number of array disks: 2
Array disk: BTHH815608CK256B
Array disk: BTHH815609RC256B
Array Name: NVMe_Array_0001
Volume member: 2Raid10D
Array disk: BTHH75130X0M256B
Array disk: BTHH815609E4256B
Array Name: NVMe_Array_0002
Available space: 97,694 MB
Volume member: Raid10C
Number of array disks: 4
Array disk: BTHH82050RTN512D
Array disk: BTHH82050V3H512D
Array disk: BTHH82050RUG512D
Array disk: BTHH82050UNW512D
Array Name: NVMe_Array_0003
Volume member: 3Raid10D
Array disk: BTHH815609YE256B
Array disk: BTHH815609PC256B
Volume name: 1Raid10D
Status: Normal
Type: RAID 1
System volume: No
Data stripe size: N/A
Initialized: Yes
Blocks with media errors: 0
Physical sector size: 512 Bytes
Logical sector size: 512 Bytes
Volume name: 2Raid10D
Status: Normal
Type: RAID 1
System volume: No
Initialized: Yes
Volume name: Raid10C
Status: Normal
Type: RAID 10
System volume: Yes
Data stripe size: 64 KB
Initialized: Yes
Volume name: 3Raid10D
Status: Normal
Type: RAID 1
System volume: No
Initialized: Yes
Hardware Information
Controller name: Intel(R) VROC (Intel-SSD-only)
Type: VMD
Mode: RAID
Number of volumes: 4
Volume: 1Raid10D
Volume: 2Raid10D
Volume: Raid10C
Volume: 3Raid10D
Number of spares: 0
Number of available disks: 0
Rebuild on Hot Insert: Disabled
Manufacturer: 8086
Model number: 201D
Product revision: 4
Direct attached disk: BTHH815608CK256B
Direct attached disk: BTHH815609RC256B
Direct attached disk: BTHH75130X0M256B
Direct attached disk: BTHH815609E4256B
Direct attached disk: BTHH82050RTN512D
Direct attached disk: BTHH82050V3H512D
Direct attached disk: BTHH82050RUG512D
Direct attached disk: BTHH82050UNW512D
Direct attached disk: BTHH815609YE256B
Direct attached disk: BTHH815609PC256B
Controller name: Intel(R) C600+/C220+ series chipset SATA AHCI Controller
Type: SATA
Mode: AHCI
Number of volumes: 0
Number of spares: 0
Number of available disks: 6
Manufacturer: 8086
Model number: A282
Product revision: 0
Direct attached disk: BTLA8054085K256CGN Direct attached disk: BTLA805200UM256CGN Direct attached disk: BTLA8051062P256CGN Direct attached disk: BTLA80530BVE256CGN Direct attached disk: BTLA80510FPF256CGN Direct attached disk: BTLA805201QW256CGN
Disk on Controller 0, Port 0
Status: Normal
Type: NVMe SSD
Location type: Internal
Usage: Array disk
System disk: No
Disk data cache: Enabled
Command queuing: None
Model: INTEL SSDPEKKW256G8
Serial number: BTHH815608CK256B
SCSI device ID: 0
Firmware: 001C
Disk on Controller 0, Port 1
Status: Normal
Type: NVMe SSD
Usage: Array disk
System disk: No
Serial number: BTHH815609RC256B
SCSI device ID: 0
Firmware: 001C
Disk on Controller 0, Port 2
Status: Normal
Type: NVMe SSD
Usage: Array disk
System disk: No
Serial number: BTHH75130X0M256B
SCSI device ID: 0
Firmware: 001C
Disk on Controller 0, Port 3
Status: Normal
Type: NVMe SSD
Usage: Array disk
System disk: No
Serial number: BTHH815609E4256B
Hello Danone.
Thank you for contacting Intel Technical Support.
Based on the configuration you shared with us we found the following information:
  • Motherboard Model and Manufacturer: Asus rampage extreme VI is a Gaming motherboard it was not designed to be used as a server board.
  • The Asus rampage extreme VI was designed to work with Windows® 10 64-bit and has some drivers available for other older operating systems (OS) none of them are a server distribution.
  • The Intel® SSD 760p Series was not tested or validated to work with your Asus rampage extreme VI motherboard (based on the http://compatibleproducts.intel.com/ProductDetails?prodSearch=True&searchTerm=Intel%C2%AE%20SSD%20760p%20Series Intel® Product Compatibility Tool).
  • The Intel® SSD 760p Series was not designed to be used on a datacenter environment and that will void the SSD warranty.
  • The Asus Hyper M.2 X16 Card is not supported tested or validated by Intel® to be used with our M.2 devices.
This being said your current configuration is not supported by Intel® and it is expected to experience errors.
The 0x000000d1 DRIVER_IRQL_NOT_LESS_OR_EQUAL iaVroc.sys error as you mentioned is related to the specific OS you have on your system and Microsoft is currently working on a solution and Intel® does not have a specific solution for it.
Our only recommendation is to wait for an update on this thread:
We hope you find this information useful.
Thank you for your patience and understanding.
Josh B.
Intel Customer Support
Hello Danone.
Thank you for having contacted Intel Technical Support.
We have not heard from you since our last communication and we would like to know if you need further assistance or if we can close this case?
Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought.
We will be looking forward to your reply.
Josh B.
Intel Customer Support.
LAlli
Hi Josh,
I solved issue by enabling disk cache in intel rapid storage software. it has been 1 month and 1 week I don't have any crashes and no problem so far.
LAlli
Hi again I experience blue screen today although enabling help the issue but still receiving blue screen I will keep this topic updated once I see improvement.
LAlli
Hi again,
I did several test finally I found that memory is not in mainboard vql list and as a result is not compatible with mainboard and somehow it triggered vroc.sys still don't know exactly how it is related to vroc but It actually problem is corsair ddr4 4133mhz ram(there is nothing wrong with ram just not compatible with mainboard). I ended up with buying GSkill ddr4 4200mhz it has been 3 weeks and without having single problem.
I am now 100% sure above configuration is working
