Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
告知
Looking for RAID, VROC? You found the forum to ask questions!
351 ディスカッション
installare win10/Linux su Optane
LBast1
ビギナー
1,566件の閲覧回数
È possibile intsallare l'intero OS Win10 e/o Linux su:
1. INTEL Optane 900P 480 GB (SSDPED1D480GAX1)?
2. INTEL Optane SSD serie 900P (SSDPED1D280GASX)?
3. INTEL Optane 900P 280 GB (SSDPE21D280GASM)?
Quindi usare questi SSD in modo "tradizionale" (cioè *non* in modo "cache")?
0 件の賞賛
3 返答(返信)
JosafathB_Intel
モデレーター
725件の閲覧回数
Hello LBast1, Thank you for contacting Intel® Memory & Storage Support. As we understand, you need assistance with your Intel® Optane™ SSD 900P Series. If we infer correctly we will appreciate if you can review the following information: • Physical Installation Instructions for PCIe* NVMe* U.2 and Add-In Card Solid State Drives (https://www.intel.com/content/www/us/en/support/articles/000026843/memory-and-storage/intel-optane-memory.html) • System Requirements for an Intel® Optane™ SSD 900P Series Drive (https://www.intel.com/content/www/us/en/support/articles/000025741/memory-and-storage/enthusiast-ssds.html) • After following to the instructions and recommendations provided on the previous articles and checking with your motherboard original equipment manufacturer (OEM) regarding compatibility with your Intel® Optane™ SSD 900P Series and regarding hardware and BIOS configuration, we advise you to download an updated image of Windows 10 from Microsoft* and to install your OS in UEFI mode. In order to further assist you we will like you to provide us with the following information: • If you are able to access your OS please provide us with the following information -The SSU logs. 1- Go to https://downloadcenter.intel.com/download/25293/and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. - A screenshot of the “Disk Management” of windows showing all your SSDs and partitions. • If you are not able to access your OS we will appreciate if you can provide us with information regarding your PC configuration (CPU, Motherboard model, and manufacturer, etc). We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
モデレーター
725件の閲覧回数
Hello LBast1, Thank you for contacting Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
モデレーター
725件の閲覧回数
Hello LBast1, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
返信
