Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
Intel® VTune™ Amplifier XE for Linux
Ramagounder_t_
初學者
1,275 檢視
HI,
Our customer try to evaluate Intel® VTune™ Amplifier XE for Linux.
While activation in Step 3
Step 3 of 7 | Activation > Remote Offline Activation
In order to complete the offline activation process, you will need to use a
system that is connected to the Internet.
1. On the connected system, go to:
   https://registrationcenter.intel.com/RegCenter/remoteactivation.aspx
2. Enter this product activation code on the above web page:
   PMG2-GTNZ-2GGW-7EC3-MNQ3-P4V6-DMF
3. Save the product unlock code that is displayed on the above web page.
4. Choose option 1 below and enter the product unlock code to complete the
activation process.
So, try to redirect URL >>  https://registrationcenter.intel.com/RegCenter/remoteactivation.aspx while register with product key. we are getting below message.
Sorry, evaluation serial numbers may not be activated using this Remote Activation Page. Please go to https://registrationcenter.intel.com/RegCenter/Register.aspx to register this serial number.
So, I tried the respective link it through below error message
Our records indicate that the serial number you provided has already been registered. Please check your records and try again. If you feel you have received this message in error.
Kindly help us to get evaluate the trail version licenses .
Please Find the Attachment.
Thanks & Regards,
Vijay Kumar TP
CSIR 4PI, Bangalore
HCL Bangalore.
0 積分
2 回應
Bernard
傑出貢獻者 I
1,275 檢視
I Think that you will receive faster response by posting your question on dedicated VTune forum.
TimP
榮譽貢獻者 III
1,275 檢視
As this is a registration issue, the form specifically about registration and licensing should give you more timely response.  I agree generally with Iliya about using the VTune forum.
As the site says your license is already registered, you should be able to use that site to request a copy of the license file to be emailed to you.  Copying that file to your install system, e.g. to /opt/intel/licenses/ should enable you to install.
回覆
