Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
function prolugue consumes many cycles
developer1
ビギナー
3,536件の閲覧回数
I'm profiling my application (linux x86_64, SandyBridge, using perf), and one of its functions takes about 30% of the runtime. In the function, looks like saving registers to the stack consumes the most time - this is annotation of function start:
  0.39        push   %r15
 95.35        push   %r14
  1.27        push   %r13
  0.16        push   %r12
  0.15        mov    %rdi,%r12
  0.25        push   %rbp
  0.14        mov    %rsi,%rbp
  0.12        push   %rbx
  0.18        sub    $0x8,%rsp
I tried using RESOURCE_STALLS counter, and looks like RESOURCE_STALLS.SB is high on this instruction as well, in addition i didn't see high cache misses on this instruction. What can i do to continue investigating this? Are there additional counters which i should examine?
0 件の賞賛
17 返答(返信)
Bernard
高評価コントリビューター I
3,536件の閲覧回数
Can you profile with VTune or post the VTune front-end , back-end pipeline stalls analysis?
Can you also post that function disassembly?Regarding the   push   %r14 instruction it is interesting what is beign loaded(pushed) onto stack.It seems that 95.0% of the function's prologue is spent  waiting on resource beign available.
developer1
ビギナー
3,536件の閲覧回数
I've uploaded the vtune sampling. I hope these are the correct counters... I've selected General Exploration. I see there are first level TLB misses, but there are other places in the code which have even more dTLB misses and much less cycles..
--Yossi
TimP
名誉コントリビューター III
3,536件の閲覧回数
In the absence of further evidence, I'd guess the time may be associated with allocating a fill buffer, due to previous code having left the buffers full of data pending flush to L1, as might happen when writing to multiple cache lines in a loop.
If that is so, sometimes forcing the function to in-line or at least take advantage of some ipo could alleviate it.
developer1
ビギナー
3,536件の閲覧回数
thanks for the reply. is there a performance counter which could indicate this situation or show which code stores too many cache lines to L1?
SergeyKostrov
高評価コントリビューター II
3,536件の閲覧回数
>>...In the function, looks like saving registers to the stack consumes the most time... Try to use a structure of parameters which could be passed to the function and in that case only one parameter will be saved on the stack. I have no idea what is wrong with your codes but it is possible that there is a problem with the stack alignment.
Bernard
高評価コントリビューター I
3,536件の閲覧回数
Can you post functions call stack?Does your function receives some input?Such a geat number of RESOURCES_STALLS.ANY could indicate that pipeline can be stalled for example by previous dependent store instructions or by branch misprediction.Can you perform front-end pipeline stalls analysis and post the results?
developer1
ビギナー
3,536件の閲覧回数
The function has no input, and it is called from main() after other functions have been called.
Frontend analysis shoed no branch mispredictions (BR_MISP_RETIRED.** and BACLEARS.ANY were 0). However, see very large count on LD_BLOCKS_PARTIAL.ADDRESS_ALIAS - about 45% of total program count (see attachment). Does it mean that another instruction is trying to load/store from the same page offset? How can i find/eliminate the conflict?
developer1
ビギナー
3,536件の閲覧回数
And this is the file..
SergeyKostrov
高評価コントリビューター II
3,536件の閲覧回数
>>...Does it mean that another instruction is trying to load/store from the same page offset?.. It is Not clear and so far I could only say that it is a really strange problem. Could you create a simple reproducer?
SergeyKostrov
高評価コントリビューター II
3,536件の閲覧回数
>>...I'm profiling my application ( linux x86_64... I just realized that you have an interesting system. Is that a 32-bit operating system with 64-bit memory address space extensions?
Bernard
高評価コントリビューター I
3,536件の閲覧回数
By looking at description of LD_BLOCKS_PARTIAL.ADDRESS_ALIAS event it seems that it measures false dependency in Memory Order Buffer.I suppose that it could be related to reordering load and stores.I think that address aliasing  has been detected in store buffer which prevents further in-order memory operation.It could be also  what you are suggesting.It could be interesting if you could post full disassembly.I would like to look at previous operations which involved r14.
developer1
ビギナー
3,536件の閲覧回数
Thanks for the suggestions, unfortunately I can't post full disassembly due to legal issues..
So, I've tried to use gdb to try tracking down address which may alias my stack, but no luck. Then, took the advice of TimP and ilyapolak above, and tried to use "mfence" to narrow down the problem. Finally, i've found a piece of code which performs small PCI write, and then sfence, and runs before the function above is called:
[cpp]
write_pci(&pci_address, data);
asm volatile ("sfence":::"memory");
[/cpp]
Putting the mfence *before* this sfence had almost no effect. However, putting my mfence right *after* this sfence, makes the "mfence" consume many cycles, instead of the "push r14" which comes sometime after it. Also, removing all memory serializations (sfence and mfence) improved the performance of "push r14" and the whole application.
So my conclusion was - the PCI write is slow, and sfence made subsequent writes wait for its completion. So the unlucky instruction which filled the store buffer got the hit and actually waited for this PCI write to complete. Does that sound reasonable?
Also - looks like all performance counters related to memory stores as asynchronous - in the sense they indicate a problem sometime after the root cause of the problem, so need to use mfence to narrow it down. Also, looks like mfence is "synchronous" while sfence/lfence are not, is this true?
Bernard
高評価コントリビューター I
3,536件の閲覧回数
@developer
If you cannot post the code disassembly, maybe you can track by yourself memory operations which used r14 register prior to the function prologue and post your findings.I suspect that there could be some kind of WAR issue.
Bernard
高評価コントリビューター I
3,536件の閲覧回数
>>>Also - looks like all performance counters related to memory stores as asynchronous >>>
I think that internally performance counters related to specific event could be incremented when micro-code and internal logic detects occurence of those events.
SergeyKostrov
高評価コントリビューター II
3,536件の閲覧回数
>>...Also, removing all memory serializations (sfence and mfence) improved the performance of "push r14" and the whole application. It is a very interesting result because in several linear algebra algorithms I've implemented usage SFENCE improves performance of the processing by ~5% on 32-bit and 64-bit WIndows systems with Pentium 4, Atom and Ivy Bridge processors. That is, we have completely different results. Also, I've experimented with SFENCE and I figured out that it needs to be placed in a proper place during processing and it depends on an algorithm.
developer1
ビギナー
3,536件の閲覧回数
@Sergey
I guess the major difference is that I have slow PCI write, while your algorithms probably have only RAM accesses.. So you are saying SFENCE provided some kind of hint to the CPU to do better memory ordering for your algorithm?
SergeyKostrov
高評価コントリビューター II
3,536件の閲覧回数
>>...So you are saying SFENCE provided some kind of hint to the CPU to do better memory ordering for your algorithm?.. Yes, exactly! If you're interested to complete an experiment try to use a 3-loop matrix multiplication algorithm ( a classic-form or a transposed-form ) for verifications if it works on your computer.
返信
