Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
公告
how to get event of UNC_DRAM_PAGE_CLOSE.CHO
lin_w_2
初学者
3,676 次查看
I'm trying to get event UNC_DRAM_PAGE_CLOSE.CHO, but I always get 0. I use perf, and my OS is ubunto. My server is Intel xeon E5620.
I can get  UNC_DRAM_OPEN.CHO, But I can't get  UNC_DRAM_PAGE_CLOSE.CHO.
Do any body come across this question?
thanks a lot
lin wang
0 项奖励
1 解答
Roman_D_Intel
员工
3,676 次查看
Hi Lin Wang, the uncore PMU is not supported in perf in your Linux kernel. You need to try Linux kernel 3.5. Thanks, Roman
在原帖中查看解决方案
0 项奖励
13 回复数
Roman_D_Intel
员工
3,676 次查看
Hi Lin Wang, on the screen shot I see that only the count for raw event 0x461 is zero. Event 0x461 is UNC_DRAM_PAGE_CLOSE.CH2 and not UNC_DRAM_PAGE_CLOSE.CH0. Instead you have to use event 0x161 to monitor UNC_DRAM_PAGE_CLOSE.CH0. Best regards, Roman
0 项奖励
lin_w_2
初学者
3,676 次查看
Hello Roman Dementiev, Thanks for your reply, I upload a new screen shot. I can't get 0x161,0x261,0x461,0x162,0x262,0x462. I can get dram open event, but i can't get dram page close event and dram page miss event. I don't know why? best regards, lin wang
0 项奖励
McCalpinJohn
名誉分销商 III
3,676 次查看
I had no trouble reading these events on my Intel Xeon X5680 using utilities from msrtools-1.2 to read and write the uncore performance monitor MSRs. I did not think that "perf" had any provisions for accessing the MSR-based uncore counters?
0 项奖励
Roman_D_Intel
员工
3,677 次查看
Hi Lin Wang, what is the version of Linux kernel are you using? Could you post the complete command line for perf that you are using with the raw events ? Best regards, Roman
0 项奖励
lin_w_2
初学者
3,677 次查看
Hello Roman Dementiev, I attach two screen shot for my linux kernel and command line. best regards. lin wang
0 项奖励
lin_w_2
初学者
3,677 次查看
hello,jdmccalpin, Use 'perf list --help',show like screen shot, perf can access raw event.
0 项奖励
Roman_D_Intel
员工
3,677 次查看
Hi Lin Wang, the -e rXXX format is to collect statistics for *on-core* raw PMU events.But you would like to monitor events from *uncore* PMU. I need to check on the status of perf uncore support in Linux. There was a recent development in that direction. In the meantime, could you send the Linux kernel version you are using ("uname -a" command). Roman
0 项奖励
Roman_D_Intel
员工
3,677 次查看
The initial support for Xeon E5620 (and other processors with microarchitecture codenamed Nehalem-EP, Westmere-EP and SandyBridge-EP) uncore events is included into the Linux kernel mainline starting from version 3.5
0 项奖励
lin_w_2
初学者
3,677 次查看
hello Roman this screen shot is my linux kernel best regards, lin wang
0 项奖励
Roman_D_Intel
员工
3,677 次查看
0 项奖励
lin_w_2
初学者
3,677 次查看
hello, Roman, where are you find information about the support linux version, can you give me the link or document. I want learn more. Thank you. best regards, lin wang
0 项奖励
Roman_D_Intel
员工
3,677 次查看
Hi Lin Wang, the uncore perf support has been improved in Linux kernel 3.6: see here . Roman
0 项奖励
lin_w_
初学者
3,677 次查看
I have installed linux-tools-3.5 for profiling,but I can't get uncore PMU now, I will try linux-tools-3.6 the next few days.
0 项奖励
回复
