1 解答
Hi Lin Wang,
the uncore PMU is not supported in perf in your Linux kernel. You need to try Linux kernel 3.5.
Roman
链接已复制
13 回复数
Hi Lin Wang,
on the screen shot I see that only the count for raw event 0x461 is zero. Event 0x461 is UNC_DRAM_PAGE_CLOSE.CH2 and not UNC_DRAM_PAGE_CLOSE.CH0. Instead you have to use event 0x161 to monitor UNC_DRAM_PAGE_CLOSE.CH0.
Roman
I had no trouble reading these events on my Intel Xeon X5680 using utilities from msrtools-1.2 to read and write the uncore performance monitor MSRs. I did not think that "perf" had any provisions for accessing the MSR-based uncore counters?
Hi Lin Wang,
what is the version of Linux kernel are you using? Could you post the complete command line for perf that you are using with the raw events ?
Roman
Hi Lin Wang,
the -e rXXX format is to collect statistics for *on-core* raw PMU events.But you would like to monitor events from *uncore* PMU. I need to check on the status of perf uncore support in Linux. There was a recent development in that direction. In the meantime, could you send the Linux kernel version you are using ("uname -a" command).
Roman
The initial support for Xeon E5620 (and other processors with microarchitecture codenamed Nehalem-EP, Westmere-EP and SandyBridge-EP) uncore events is included into the Linux kernel mainline starting from version 3.5
Hi Lin Wang,
Roman
