Wireless
8782 Discussions
7260 Wi-Fi card fails to initialize after hibernate with recent drivers
PM3
Intel dual band wireless-ac 7260 card fails with certain version of driver.
It does not fail with version 7.0.3, but fails with 7.0.5 and 7.1.0 (the newest). Failure happens after computer wakes up after a hybernation. It just does not work.
The errors are:
Windows has stopped this device because it has reported problems. (Code 43)
The description for Event ID 5010 from source NETwNs64 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
The following information was included with the event:
\Device\NDMP10
Intel(R) Dual Band Wireless-AC 7260
The description for Event ID 8000 from source NETwNs64 cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
\Device\NDMP10
The specified resource type cannot be found in the image file
Intel(R) Dual Band Wireless-AC 7260 : Could not allocate the resources necessary for operation.
\Device\NDMP10
000008000200380000000000891300C000000000000000000000000000000000000000000000000057445256CE010000
My laptop model: Toshiba C855-190 with i5-3210M, 16G of RAM, Windows 7 64 bit
I've installed the card to the laptop myself. It worked with the old drivers, the reason for installing new drivers is that the card starts much slower than the original card after hibernate.
Windows was restarted multiple times, I've tried to re-install drivers as well. Such thing do not help, the issue only occurs with newer drivers.
I don't require much assistance, I just think it will be useful to fix that bug in the driver. Please let me know if you want me to run a debug version or do something else technical.
Jose_H_Intel1
Hi mrd000, I appreciate the information you have provided.
I believe we can continue in the existing thread where the same topic is being discussed:
