- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I can use internet on 5GHz wifi all day, watch youtube , download game from steam, but when I try to connect to game server, I lose internet every time i hit "log in" button or after login
I have try to do the ping test when play game, found that
It doesn not happen when I'm on 2.4GHz, I can log in and play Would of Warship / AOE thought Stream.
When I fail to connect with game server with 5GHz wifi, I"m still connected, but I have no internet. The weird part is I have to connect do 2.4GHz and switch back to 5GHz to restore internet access on this wifi.
It doesn't matter how far I am from router, it happens anyway even if i put my laptop next to it.
It's MSi GF63 with intel AC 9560, so I'm sure it can use 5GHz wifi.
Someone has told me to update driver or replaced a new wifi card, I hace update the driver ver and replaced a new wifi card but problem still happening.
I buy my notebook on Mar 2020, the problem is happen after windows update about Sep 2020, as before there was no problem on play game with 5G WIFI
Now i need to switch WIFI to 2.4G when I going to play game
Attached with the screen capture of Ping Test when Play Game and Intel SSU result
Operating System: Microsoft Windows 10 家用版(10.0.19042 Build 19042)
Intel Wifi Driver Ver: 22.0.0.6 | Date : 2020/9/17
コピーされたリンク
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, Thank you for posting in the Intel® Communities Support.
In order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the Router?
The notebook came with the Intel® Wireless-AC 9560 card pre-install, you replace it with Intel® Wi-Fi 6 AX200 card and that is the one you are currently using, correct?
Did you check with MSI directly before replacing the Intel® Wireless card to make sure it is fully compatible with their system?
If you use the Ethernet connection and test the steam application, is the problem the same when trying to connect to the game server?
You mentioned "the problem is happen after windows update about Sep 2020", by any chance, for testing purposes, do you have the option to do a rollback of Windows* to version 1909 and restore it to factory settings? We recommend before tying this step to first of all back up all the information you might have in your system and also to get in contact directly with MIS for guidance on this procedure, since there might be some restrictions related to the Windows* license:
Albert R.
A Contingent Worker at Intel
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
@Alberto_Sykes Thanks for help
Asus RT AC68U Before, Now i have change Linksys EA9350 for Wifi 6 since i think is the router problem
Yes, I have try to do the test with AC9560 but have the same problem
Hardware is no problem, it is the software problem, this is not include with MSI warranty
Yes, no any problem found
Sure, i have try to reset to factory default, i have use windows's reset function, after reset windows has auto update to the near ver. and I lose my back usb driver (i have do the backup usb when i buy notebook) ; otherwise, I have download windows 10 from Microsoft and re-install again, but also is the update ver. so i can't rollback to old version of windows 10
I don't know what can i do now, i think i must found out the OS backup USB driver and re-store it
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, Thank you very much for providing that information.
We will do further research on this matter, as soon as I get any updates I will post all the details on this thread.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, I just received an update on this matter.
While we are still currently working on this case, please provide the SSU report, mark the option of getting 3rd party logs as well and event log, in order for us to be able to verify further details about the components in your system:
Also, please fill the information requested in the document attached to this post so we can better assist you.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello PanPan, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
I have re-install my windows now,
but the problem still happening, i have no idea now
attached with update SSU log file
hope the problem can be solved
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, Thank you very much for sharing those details.
Just to let you know, there are new Intel® drivers available on our web site that were released recently, so, what we can try is a clean installation of those drivers following the instructions in the link below, please install Intel® Wireless driver version 22.10.0:
https://www.intel.com/content/www/us/en/support/articles/000022173/network-and-io/wireless.html
And then, Intel® Bluetooth driver version 22.10.0, once you get the chance, please let us know the results:
If the problem persists after trying to install those drivers, please fill the form attached to this post and provide the SSU report with the updates.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello PanPan, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Thanks for your help
I have install the update drvier
I am use 5G for internet is no problem, but i haven't check on the gaming issue
if have any problem or result , i will keep update in this post
Thanks again for your help
Attached with the update SSU report
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, You are very welcome, thank you very much for providing those updates and the SSU report.
Perfect, it is great to hear that "I am use 5G for internet is no problem", and yes, go ahead and take your time to test the gaming issue and once you get the chance, please let us know the results.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, I just wanted to check if you were able to do the tests on the gaming issue and if you need further assistance on this matter?
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello PanPan, Since I have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Sorry, i forgot my account password before
I have test the gaming again but the disconnect problem still happening
I have test stream before, this time i have test Epic Game also, but the problem is same
But the disconnect problem of ping result is timeout about 10 times and then connect 5 times
Still can't play game with 5G network
attached with update ssu report
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, No problem at all, thank you very much for letting us know those updates and for providing the updated SSU report.
We are sorry to hear the problem persists, we will continue with our research on this matter and as soon as I get any information I will post all the details on this thread.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Hello PanPan, I just received an update on this matter.
While we are still working on this topic, could you please provide a picture of the Intel® Wireless Card and the antennas and how it is connected? This is in order for us to confirm how it is connected to the board.
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
that mean i need open my laptop base and take the photo on wifi card, right ?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, Thank you very much for sharing the picture.
Based on the photo, it seems that the Intel® Wireless card is properly connected and so are the antennas.
So, in this case, first, please make sure that the Encryption Method in Windows* is set to WPA2 - Home.
In the link below you will find the Advanced Intel® Wireless Adapter Settings in order to try the following troubleshooting steps:
Change the Wireless Mode or HT Mode to: "802.11ax enables 802.11ax data rates"
Change the channel width from "Auto" to "20 MHz"
Sometimes there is a firmware update available for the Router, did you check with the manufacturer of it to verify if that is the case for this unit in order to install it? Once you get in contact directly with them, please also gather the instructions on how to change the channel in the Router settings, since the one that you are currently using might have a lot of interference:
https://www.linksys.com/us/support/
Albert R.
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
Happy to say, the problem have solved
I have check my computer's setting
Default already set " 802.11ax
Has change from "Auto" to 20MHz"
The gaming problem has solved
but the wireless speed has drop from 6XX Mbps to 2XX Mbps
is this normal ?
- 新着としてマーク
- ブックマーク
- 購読
- ミュート
- RSS フィードを購読する
- ハイライト
- 印刷
- 不適切なコンテンツを報告
PanPan, Thank you very much for letting us know those results.
Perfect, excellent it is great to hear that the problem with the games is solved and now they are working properly.
You asked, "but the wireless speed has drop from 6XX Mbps to 2XX Mbps, is this normal?", Yes, it is normal based on the changes done from "Auto" to "20 MHz. So, in theory, now you should be able to change the channel width again to a higher value and the games should still work without any issues.
Please try that and let us know the results once you get the chance.
Albert R.
