Wireless
8510 토론
AX101 Linux Debian Driver WiFi driver No config found for PCI dev 7af0/0244
WaCe
초보자
2,924 조회수
Please help the Inte WiFi 6 AX101
kernel version
6.1.0-25-amd64
# dmesg | grep iwlwifi
[    2.597503] Intel(R) Wireless WiFi driver for Linux
[    2.597683] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    2.601668] perf uncore: Cannot find matched IMC device.
[    2.601716] perf uncore: Cannot find matched IMC device.
[    2.601762] perf uncore: Cannot find matched IMC device.
[    2.601808] perf uncore: Cannot find matched IMC device.
[    2.604016] iwlwifi: No config found for PCI dev 7af0/0244, rev=0x430, rfid=0x10c000
[    2.604047] iwlwifi: probe of 0000:00:14.3 failed with error -22
# lspci -kvnn | sed -n '/Network/,/^$/ p'
00:14.3 Network controller [0280]: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:7af0] (rev 11)
       DeviceName: Onboard - Ethernet
       Subsystem: Intel Corporation Alder Lake-S PCH CNVi WiFi [8086:0244]
       Flags: fast devsel, IRQ 18
       Memory at 9341c000 (64-bit, non-prefetchable) [size=16K]
       Capabilities: [c8] Power Management version 3
       Capabilities: [d0] MSI: Enable- Count=1/1 Maskable- 64bit+
       Capabilities: [40] Express Root Complex Integrated Endpoint, MSI 00
       Capabilities: [80] MSI-X: Enable- Count=16 Masked-
       Capabilities: [100] Latency Tolerance Reporting
       Capabilities: [164] Vendor Specific Information: ID=0010 Rev=0 Len=014 <?>
       Kernel modules: iwlwifi
Bluetooth is working normal.
have download latest linux-firmware-20240811  and copy intel folder to  and iwlwifi-* /lib/firmware/intel/lib/firmware/
0 포인트
12 응답
JedG_Intel
중재자
2,616 조회수
Hello WaCe,
Could you please elaborate or describe the issue you are having? Please generate System Support Utility (SSU) report to have a better understanding of your system configuration and component. Please follow instructions here and send the report - Intel® System Support Utility for the Linux* Operating System
I hope to hear from you soon!
Jed G.
0 포인트
WaCe
초보자
2,579 조회수
Hello Jed G.,
Here is the generated file from SSU.
I read the generated txt file, there is no component about the WiFi Component, the WiFi is run normally in Windows.
Best regards
0 포인트
JedG_Intel
중재자
2,565 조회수
Hello WaCe,
I appreciate you for sharing the SSU logs. Please also share the information below for me to address this properly.
1. Was this working fine before?
2. Is this the original adapter that came pre-installed in your system, or have you changed/installed a new adapter recently?
3. Did you make recent changes to the system?
I hope to hear from you soon.
Jed G.
0 포인트
WaCe
초보자
2,555 조회수
Hello Jed G.,
No, this is new system.
This is the original adapter that came pre-installed on the motherboard brand = Maxsun type = H610M 666 WIFI6 link to product = https://www.maxsun.com/products/ms-h610m-666-wifi6
No.
Best regards
0 포인트
JedG_Intel
중재자
2,539 조회수
Hello WaCe,
I appreciate this information. I'll be conducting an investigation with regards to this matter and I'll get back in touch as soon as possible.
Jed G.
0 포인트
JedG_Intel
중재자
2,531 조회수
Hi WaCe,
I'm just following up to gather more information for the investigation.  Please see below.
- Is this a laptop or desktop system?
Additionally, please share the output of the following.
1. $ hostnamectl
2. # lspci​
3. # modinfo iwlwifi​
I'll be waiting for your response.
Jed G.
0 포인트
WaCe
초보자
2,519 조회수
Hi Jed G.,
It is a desktop system.
Best Regards
0 포인트
JedG_Intel
중재자
2,496 조회수
Hi WaCe,
Thank you for this information. I'll continue to investigate this matter and I'll give you an update as soon as I can.
Jed G.
0 포인트
JedG_Intel
중재자
2,413 조회수
Hello WaCe,
I'm reaching out to give you an update. Based on the investigation, both logs provided do not detect AX101 but shows Qualcomm Atheros AR9485 Wireless Network Adapter and error Module iwlwifi not found. Please check with desktop OEM to see if this system is compatible with 2 wireless cards and Linux OS. Additionally, Kernel version 6.1.0-25 is not the latest. Latest stable kernel version is 6.12 https://www.kernel.org/.
Should you have other questions or concerns, please let me know.
Jed G.
0 포인트
RobbieR_Intel
중재자
2,338 조회수
Hello WaCe,
I would like to check if you were able to see the information my colleague has posted. Your feedback at your earliest convenience would be greatly appreciated so we can move forward with resolving this matter.
Robbie R.
0 포인트
WaCe
초보자
2,300 조회수
Hello Robbie R.,
I do not know what to do next, since I cannot found documentation about Debian is support 2 WiFi card or not. Thank you Jed G. for the help.
Thank you Robbie R. for the follow up, while I still can use the Atheros WiFi, and I just want to post the No Config message while booting up Debian for the forum to know, and we can close this thread.
Best Regards
0 포인트
JedG_Intel
중재자
2,259 조회수
Hello WaCe,
Thank you for the update. Since you confirmed that we can close this thread, I'll proceed to do so. Should you have other questions or concerns, please create a new thread as this thread will no longer be monitored.
Jed G.
0 포인트
응답
