Wireless
8519 ディスカッション
AX1675 not working on Linux (no config found)
thcast
初心者
29,178件の閲覧回数
I have an Intel Killer WiFi 6E AX1675i chip on a brand new machine, and unfortunately it doesn't work on Linux, even though the product page says Linux is supported.
Distro: Arch
Kernel: 6.2.6
lspci | grep -i network
0000:00:14.3 Network controller: Intel Corporation Device 51f1 (rev 01)
sudo dmesg | grep iwl
[sudo] password for ori:
[   25.927632] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   25.931091] iwlwifi: No config found for PCI dev 51f1/1672, rev=0x370, rfid=0x2010d000
[   25.931350] iwlwifi: probe of 0000:00:14.3 failed with error -22
What I find odd is that on https://wiki.freebsd.org/WiFi/Iwlwifi/Chipsets there is this in the list of supported devices:
0x8086 / 0x51f0 / any / 0x1672
Killer(R) Wi-Fi 6E AX1675i 160MHz Wireless Network Adapter (211NGW)
iwlwifi-so-a0-gf-a0-
The only difference is that it's 0x51f0, whereas mine says 0x51f1, so perhaps the same driver might work? I'm not sure how to test that out though.
Bluetooth works perfectly fine.
How could I get my wifi working?
1 解決策
Ernesto_C_Intel1
モデレーター
15,750件の閲覧回数
Hello thcast,
Please proceed to update your OS's Kernel version to address the issue with your Intel® Killer™ Wi-Fi 6E AX1675 (i/s).
If the issue persists, please continue to contact your OS support or community since the OS is not able to detect the wireless card.
Ernesto C.
元の投稿で解決策を見る
18 返答(返信)
Jocelyn_Intel
従業員
29,139件の閲覧回数
Hello, @thcast
Thank you for posting on the Intel® communities.
I am sorry to hear that you are having issues with your wireless card, I will gladly assist you here.
Please, answer these questions to have a better perspective of this issue:
  1. Is the Intel® Killer™ Wi-Fi 6 AX1650 the pre-installed wi-fi card in your motherboard/laptop or is it an integration (upgrade/ not the original card in the laptop/motherboard)?
  2. Is it a desktop or laptop?
  3. Was it working fine before?
  4. Make sure that your wireless adapter is connected properly running # lspci command in the terminal and verify if the wireless adapter is recognized. This is an example of what should display.
  5. Make sure that the module is installed properly running # modinfo iwlwifi command. This is an example of the output.
  6. Type # lsmod | grep iwlwifi to make sure the driver is loaded, the output should be like this, If the result is empty, the driver hasn't been loaded. Most likely to be a distribution issue:
  7. Type # dmesg | grep iwlwifi. If the result is empty, the driver wasn’t initialized and this is a distribution issue:
  8. Type the # dmesg | grep “no suitable firmware found!” command, the result is not empty, that means that you don't have a suitable FW, you need to check here for supported FW or here for latest versions.
Jocelyn M.
thcast
初心者
29,110件の閲覧回数
Hi @Jocelyn_Intel ,
here are the answers to your questions:
1. Yes, it was pre-installed. It is an MSI Stealth 14 Studio A13V laptop.
2. Laptop.
3. No, it has never worked under Linux. It did work under Windows, but I no longer have Windows installed.
4.
~ ❯❯❯ lspci
0000:00:00.0 Host bridge: Intel Corporation Device a706
0000:00:01.0 PCI bridge: Intel Corporation Device a70d
0000:00:02.0 VGA compatible controller: Intel Corporation Raptor Lake-P [Iris Xe Graphics] (rev 04)
0000:00:04.0 Signal processing controller: Intel Corporation Device a71d
0000:00:06.0 System peripheral: Intel Corporation RST VMD Managed Controller
0000:00:07.0 PCI bridge: Intel Corporation Device a76e
0000:00:08.0 System peripheral: Intel Corporation Device a74f
0000:00:0d.0 USB controller: Intel Corporation Device a71e
0000:00:0d.2 USB controller: Intel Corporation Device a73e
0000:00:0e.0 RAID bus controller: Intel Corporation Volume Management Device NVMe RAID Controller Intel Corporation
0000:00:14.0 USB controller: Intel Corporation Alder Lake PCH USB 3.2 xHCI Host Controller (rev 01)
0000:00:14.2 RAM memory: Intel Corporation Alder Lake PCH Shared SRAM (rev 01)
0000:00:15.0 Serial bus controller: Intel Corporation Alder Lake PCH Serial IO I2C Controller #0 (rev 01)
0000:00:16.0 Communication controller: Intel Corporation Alder Lake PCH HECI Controller (rev 01)
0000:00:1f.0 ISA bridge: Intel Corporation Device 519d (rev 01)
0000:00:1f.3 Multimedia audio controller: Intel Corporation Device 51ca (rev 01)
0000:00:1f.4 SMBus: Intel Corporation Alder Lake PCH-P SMBus Host Controller (rev 01)
0000:00:1f.5 Serial bus controller: Intel Corporation Alder Lake-P PCH SPI Controller (rev 01)
0000:01:00.0 VGA compatible controller: NVIDIA Corporation AD107M [GeForce RTX 4060 Max-Q / Mobile] (rev a1)
0000:01:00.1 Audio device: NVIDIA Corporation Device 22be (rev a1)
10000:e0:06.0 PCI bridge: Intel Corporation Device a74d
10000:e1:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
 5.
~ ❯❯❯ modinfo iwlwifi
filename:       /lib/modules/6.2.7-arch1-1/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.zst
license:        GPL
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-BzBnj-b0-fm-b0-72.ucode
firmware:       iwlwifi-gl-b0-fm-b0-72.ucode
firmware:       iwlwifi-bz-a0-fm4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-hr-b0-72.ucode
firmware:       iwlwifi-BzBnj-a0-gf4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-gf-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-fm4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-fm-a0-72.ucode
firmware:       iwlwifi-gl-a0-fm-a0-72.ucode
firmware:       iwlwifi-bz-a0-fm-a0-72.ucode
firmware:       iwlwifi-bz-a0-mr-a0-72.ucode
firmware:       iwlwifi-bz-a0-gf4-a0-72.ucode
firmware:       iwlwifi-bz-a0-gf-a0-72.ucode
firmware:       iwlwifi-bz-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-mr-a0-72.ucode
firmware:       iwlwifi-ma-a0-fm-a0-72.ucode
firmware:       iwlwifi-ma-a0-mr-a0-72.ucode
firmware:       iwlwifi-ma-a0-gf4-a0-72.ucode
firmware:       iwlwifi-ma-a0-gf-a0-72.ucode
firmware:       iwlwifi-ma-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-jf-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-gf-a0-72.ucode
firmware:       iwlwifi-SoSnj-a0-gf4-a0-72.ucode
firmware:       iwlwifi-ty-a0-gf-a0-72.ucode
firmware:       iwlwifi-so-a0-gf-a0-72.ucode
firmware:       iwlwifi-so-a0-hr-b0-72.ucode
firmware:       iwlwifi-so-a0-jf-b0-72.ucode
firmware:       iwlwifi-cc-a0-72.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-72.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-72.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-72.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-72.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-72.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-72.ucode
firmware:       iwlwifi-Qu-b0-hr-b0-72.ucode
srcversion:     F230833AC4C04A291C86468
alias:          pci:v00008086d00007740sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A840sv*sd*bc*sc*i*
alias:          pci:v00008086d00002727sv*sd*bc*sc*i*
alias:          pci:v00008086d00007E40sv*sd*bc*sc*i*
alias:          pci:v00008086d00002729sv*sd*bc*sc*i*
alias:          pci:v00008086d00007F70sv*sd*bc*sc*i*
alias:          pci:v00008086d000054F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F1sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd*bc*sc*i*
alias:          pci:v00008086d00002726sv*sd*bc*sc*i*
alias:          pci:v00008086d00002725sv*sd*bc*sc*i*
alias:          pci:v00008086d00002723sv*sd*bc*sc*i*
alias:          pci:v00008086d00002720sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd*bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002526sv*sd*bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
retpoline:      Y
intree:         Y
vermagic:       6.2.7-arch1-1 SMP preempt mod_unload
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        48:75:E3:BC:0D:C8:EB:D3:E6:50:07:29:73:AB:8E:D6:73:0F:35:22
sig_hashalgo:   sha512
signature:      30:65:02:30:5A:2C:A3:74:B0:97:FA:C9:5F:27:DF:12:B6:13:80:CD:
               0D:44:9A:D0:08:CD:2E:25:5D:90:C1:5F:93:DD:53:79:63:7A:BC:CF:
               CE:22:AA:41:6E:5B:91:FA:B3:A7:F5:E8:02:31:00:A3:92:F8:01:E5:
               70:08:52:6B:55:2E:9C:CD:8A:4F:47:3B:B3:64:4A:EA:0E:DE:DF:09:
               73:44:11:7E:C5:6A:90:51:2C:F9:A2:D3:CE:31:1C:A0:3B:35:52:67:
               D1:3C:64
parm:           debug:debug output mask (uint)
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
parm:           disable_11be:Disable EHT capabilities (default: false) (bool)
6.
~ ❯❯❯ lsmod | grep iwlwifi
iwlwifi               544768  0
cfg80211             1277952  1 iwlwifi
7.
~ ❯❯❯ sudo dmesg | grep iwlwifi        ✘ 1
[   37.097673] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[   37.101720] iwlwifi: No config found for PCI dev 51f1/1672, rev=0x370, rfid=0x2010d000
[   37.101890] iwlwifi: probe of 0000:00:14.3 failed with error -22
8. sudo dmesg | grep 'no suitable firmware found!'  return nothing.
Hopefully this helps!
Thanks!
thcast
初心者
29,126件の閲覧回数
Hi @Jocelyn_Intel ,
thanks for the reply. Here are the answers:
1. Yes, it is preinstalled. It is an MSI Stealth 14 Studio A13V laptop.
2. Laptop
3. No, it has never worked on Linux. It did work on Windows, but I no longer have Windows installed.
4. Attached as lspci.txt
5. Attached as modinfo.txt
6. Attached as lsmod.txt
7. Attached as dmesg.txt
8. The output was empty, that message was not found anywhere in my dmesg logs.
Let me know if there's anything else you need!
Thanks!
Jocelyn_Intel
従業員
29,108件の閲覧回数
Hello, @thcast
Thank you for the information provided.
I checked the dmesg logs and something is off, the output should be more complete, but it actually shows an error, so we will need more information:
  1. Please provide us with your OS name, kernel version/distribution, you can find this information with the command: $ hostnamectl
  2. Did you make sure your router is running the latest firmware? What is the model?
  3. Just to confirm, by not working, do you mean that you have no Wi-fi connectivity?
  4. If so, Did you try connecting to other networks?
  5. Attach your debug logs and complete dmesg logs so we can investigate it, type: # dmesg | grep ASSERT and # dmesg > dmesg.log
Jocelyn M.
thcast
初心者
29,096件の閲覧回数
Hi @Jocelyn_Intel
More information, as requested:
1.
Operating System: Arch Linux
Kernel: Linux 6.2.7-arch1-1
Architecture: x86-64
2. The router shouldn't be an issue as I cannot get that far.
3. It's not working as in I don't have a wireless device I can use. The wireless adapter doesn't show up when running ip addr. Based on the dmesg logs I posted previously, it seems that iwlwifi can see the PCI device, but if doesn't recognize it by its Vendor/Device ID.
4. I can't connect, or even scan for wireless networks as the network adapter doesn't get recognised.
5. Attached full dmesg log as dmesg-full.txt
Thanks!
thcast
初心者
29,091件の閲覧回数
Also, I just noticed that the thread's title says 1650, but it should be 1675. I did write 1675 in the post itself though, so the rest should be correct.
Jocelyn_Intel
従業員
29,048件の閲覧回数
Hello, @thcast
I will proceed to do some research and check your logs.
As soon as I have updates, I will post them here.
Jocelyn M.
thcast
初心者
28,837件の閲覧回数
Hi @Jocelyn_Intel ,
it's been a few days, did you manage to find out anything please? I've been installing system updates as they come but unfortunately I'm still unable to use the wifi chip.
daper
ビギナー
28,468件の閲覧回数
Hello! I am in the same situation. Has been there any progress?
slDias
ビギナー
28,382件の閲覧回数
Hello, I had the same problem and managed to fix, it is a very scrappy workaround as I'm not a c dev and didn't want to spend too much time on it.
download the fix attached and then:
sudo apt-get install git build-essential
git clone https://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/backport-iwlwifi.git
cd backport-iwlwifi
git apply ~/Downloads/fix1675.txt
make defconfig-iwlwifi-public
sed -i 's/CPTCFG_IWLMVM_VENDOR_CMDS=y/# CPTCFG_IWLMVM_VENDOR_CMDS is not set/' .config
make -j4
sudo make install
reboot and it should work.
got to this solution by following this so question and by replicating this patch  but to the kernel repo instead of intel's dev repo. as compiling the dev repo threw some errors that the kernel did not.
worked on linux mint with a 1675s
NazmiF
ビギナー
27,810件の閲覧回数
H @slDias ,
can you share 'fix1675.txt' file here?
I want to try your solution step because I have the same problem with you.
Sorry, I didn't saw your attachment. Thanks
I can use it.
Nazmi
molten_moron
ビギナー
22,508件の閲覧回数
@slDias, you just solved months of frustration for me on my Samsung laptop. I finally have working wifi on linux again! I simply cannot thank you enough!
smartjack
ビギナー
28,104件の閲覧回数
I am in the same situation, though on a Ubuntu distro, same chip and issue though.
I tried the suggested WA by @slDias, however, that did not work for me for some reason. I have fiddled with the Ubuntu system for a bit, so might have broken something, but seems that the driver is trying to use the compiled version:
[    4.023185] Loading modules backported from iwlwifi
[    4.023188] iwlwifi-stack-public:master:11192:158b6d9b
[    4.205853] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    4.208391] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x80400 wfpm id 0x80000020
[    4.208434] iwlwifi 0000:00:14.3: PCI dev 51f1/1672, rev=0x370, rfid=0x2010d000
[    4.208437] iwlwifi: No config found for PCI dev 51f1/1672, rev=0x370, rfid=0x2010d000
[    4.208448] iwlwifi: probe of 0000:00:14.3 failed with error -22
Maybe I'm missing something? The fix was applied (checked the file itself).
Thank you
slDias
ビギナー
27,860件の閲覧回数
I don't know if this is your problem, but I forgot to mention the secure boot must be disabled. you can do that through your BIOS
By your logs it seems its using the compiled version. But, just for reference, here's what mine looks like:
[    5.484763] Loading modules backported from iwlwifi
[    5.484765] iwlwifi-stack-public:master:11120:e2036f55
[    5.706935] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    5.714385] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x80400 wfpm id 0x80000020
[    5.714427] iwlwifi 0000:00:14.3: PCI dev 51f1/1671, rev=0x370, rfid=0x2010d000
[    5.717345] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[    5.717395] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.36
[    5.718807] iwlwifi 0000:00:14.3: loaded firmware version 77.f92b5fed.0 so-a0-gf-a0-77.ucode op_mode iwlmvm
[    5.846651] iwlwifi 0000:00:14.3: Detected Killer(R) Wi-Fi 6E AX1675s 160MHz Wireless Network Adapter (211NGW), REV=0x370
[    6.013143] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[    6.013153] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    6.013160] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    6.013168] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    6.013573] iwlwifi 0000:00:14.3: loaded PNVM version 881c99e1
[    6.028700] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[    6.028709] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[    6.098175] iwlwifi 0000:00:14.3: base HW address: 70:a8:d3:dd:a7:a7
[    6.114839] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[    8.040981] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x1f
[    8.041034] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    8.041044] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    8.041053] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    8.056840] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
It may also be the case that this does not work for the 1675i as I could not test it, but the original writer of that patch had one
Hope it helps
slvrscoobie
ビギナー
27,643件の閲覧回数
Ive got the same card 1675i, and running into the same no config found issue on linux mint. I have my secure boot disabled.
while looking at this a like 7th time I realized how to edit the 1675fix.txt for my computer, and apply your code to make it work. Once I did that, and made sure to disable secure boot, Mint greeted me that WIFI NETWORK WAS AVAILABLE!
Key was to drop everything except from the fix file except whats listed this patch , then follow the code from @slDias.
Thanks!!!
NazmiF
ビギナー
27,470件の閲覧回数
Hi All,
I have the same issue here in Ubuntu 20.04.
But all the things are being solved by upgrading to Ubuntu 22.04
Nazmi
Ernesto_C_Intel1
モデレーター
15,973件の閲覧回数
Hello thcast,
I'd like to ask if you still need assistance on this issue?
Ernesto C.
Ernesto_C_Intel1
モデレーター
15,751件の閲覧回数
Hello thcast,
Ernesto C.
返信
