Wireless
7726 Discussions
AX200 bluetooth will disconnect after some seconds later
JustinWang
Hi All
We used AX200 on our Linux (Ubuntu) , when we connect bluetooth device , the device will disconnect after connect for some seconds later. Even we re-connect again, the device also disconnect for few seconds. Could you help to share some suggestion ?
JustinWang
Hi All
We got solution we found
Thanks all
JustinWang
Hi All
Thanks all
SamM11
Hi JustinWang
Can you kindly share your solution?
By the way,what version of ubuntu you use?
SamM11
Hi @JustinWang ,
Thanks a lot !!
We use the Nvidia Orin NX for our platform.
So I think this way you provided should be work on our platform too.
