Wireless
8536 Diskussionen
AX200 keeps crashing randomly - Kernel 5.15.0-46 firmware=66.f1c864e0.0 cc-a0-66.ucode
zedisdead
Anfänger
12.664Aufrufe
I've already tried disabling power management and tried using different iwlwifi module options but nothing seems to make a difference.
When it crashes, trying to remove and add iwlwifi and/or iwlmvm modules by the following command is useless (dmesg output prior to that attached):
$ sudo modprobe -r iwlwifi
$ sudo modprobe iwlwifi
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Ubuntu
Description:	Ubuntu 22.04.1 LTS
Release:	22.04
Codename:	jammy
$ uname -a
Linux xxxxxx 5.15.0-46-generic #49-Ubuntu SMP Thu Aug 4 18:03:25 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
$ cat /etc/modprobe.d/iwlwifi*
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system.  When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
$ systool -vm iwlwifi
Module = "iwlwifi"
  Attributes:
    coresize            = "450560"
    initsize            = "0"
    initstate           = "live"
    refcnt              = "1"
    srcversion          = "40FD69FEC12568AA09FE04D"
    taint               = ""
    uevent              =
  Parameters:
    11n_disable         = "0"
    amsdu_size          = "0"
    bt_coex_active      = "Y"
    disable_11ac        = "N"
    disable_11ax        = "N"
    enable_ini          = "Y"
    fw_restart          = "Y"
    led_mode            = "0"
    nvm_file            = "(null)"
    power_level         = "0"
    power_save          = "N"
    remove_when_gone    = "N"
    swcrypto            = "0"
    uapsd_disable       = "3"
  Sections:
$ cat /etc/tlp.conf | grep -i wifi
# WiFi power saving mode: on=enable, off=disable; not supported by all adapters.
WIFI_PWR_ON_AC=off
WIFI_PWR_ON_BAT=off
$ iw dev wlp82s0 get power_save
Power save: off
$ lsmod
Module                  Size  Used by
xt_nat                 16384  64
xt_tcpudp              20480  88
veth                   32768  0
rfcomm                 81920  16
xt_conntrack           16384  2
xt_MASQUERADE          20480  14
nf_conntrack_netlink    49152  0
xfrm_user              40960  1
xfrm_algo              16384  1 xfrm_user
xt_addrtype            16384  2
nft_compat             20480  170
br_netfilter           32768  0
nft_counter            16384  138
vboxnetadp             28672  0
vboxnetflt             28672  0
vboxdrv               573440  2 vboxnetadp,vboxnetflt
bridge                307200  1 br_netfilter
stp                    16384  1 bridge
llc                    16384  2 bridge,stp
ccm                    20480  6
nft_objref             16384  0
nf_conntrack_netbios_ns    16384  0
nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
nft_masq               16384  1
snd_ctl_led            24576  0
snd_hda_codec_conexant    28672  1
snd_hda_codec_generic   102400  1 snd_hda_codec_conexant
nvidia_uvm           1314816  0
nft_fib_inet           16384  0
nft_fib_ipv4           16384  1 nft_fib_inet
nft_fib_ipv6           16384  1 nft_fib_inet
nft_fib                16384  3 nft_fib_ipv6,nft_fib_ipv4,nft_fib_inet
nft_reject_inet        16384  0
nf_reject_ipv4         16384  1 nft_reject_inet
nf_reject_ipv6         20480  1 nft_reject_inet
nft_reject             16384  1 nft_reject_inet
cmac                   16384  3
algif_hash             16384  1
algif_skcipher         16384  1
af_alg                 32768  6 algif_hash,algif_skcipher
bnep                   28672  2
nft_ct                 20480  0
nft_chain_nat          16384  30
nf_nat                 49152  4 xt_nat,nft_masq,nft_chain_nat,xt_MASQUERADE
nf_conntrack          172032  9 xt_conntrack,nf_nat,nft_ct,nf_conntrack_netbios_ns,xt_nat,nf_conntrack_broadcast,nf_conntrack_netlink,nft_masq,xt_MASQUERADE
nf_defrag_ipv6         24576  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
typec_displayport      16384  1
ip_set                 53248  0
nf_tables             245760  621 nft_ct,nft_compat,nft_reject_inet,nft_fib_ipv6,nft_objref,nft_fib_ipv4,nft_counter,nft_masq,nft_chain_nat,nft_reject,nft_fib,nft_fib_inet
libcrc32c              16384  3 nf_conntrack,nf_nat,nf_tables
overlay               151552  13
btusb                  61440  0
uvcvideo              106496  0
btrtl                  24576  1 btusb
btbcm                  24576  1 btusb
btintel                40960  1 btusb
bluetooth             704512  43 btrtl,btintel,btbcm,bnep,btusb,rfcomm
ecdh_generic           16384  2 bluetooth
ecc                    36864  1 ecdh_generic
nfnetlink              20480  5 nft_compat,nf_conntrack_netlink,nf_tables,ip_set
intel_tcc_cooling      16384  0
x86_pkg_temp_thermal    20480  0
intel_powerclamp       20480  0
nvidia_drm             73728  7
coretemp               24576  0
nvidia_modeset       1146880  12 nvidia_drm
kvm_intel             372736  0
kvm                  1028096  1 kvm_intel
crct10dif_pclmul       16384  1
nvidia              40816640  582 nvidia_uvm,nvidia_modeset
ghash_clmulni_intel    16384  0
aesni_intel           376832  8
crypto_simd            16384  1 aesni_intel
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel
rapl                   20480  0
joydev                 32768  0
mei_hdcp               24576  0
intel_rapl_msr         20480  0
snd_sof_pci_intel_cnl    16384  0
snd_sof_intel_hda_common   102400  1 snd_sof_pci_intel_cnl
soundwire_intel        40960  1 snd_sof_intel_hda_common
soundwire_generic_allocation    16384  1 soundwire_intel
soundwire_cadence      36864  1 soundwire_intel
snd_sof_intel_hda      20480  1 snd_sof_intel_hda_common
think_lmi              28672  0
snd_sof_pci            20480  2 snd_sof_intel_hda_common,snd_sof_pci_intel_cnl
intel_cstate           20480  0
input_leds             16384  0
firmware_attributes_class    16384  1 think_lmi
wmi_bmof               16384  0
snd_sof_xtensa_dsp     16384  1 snd_sof_intel_hda_common
snd_sof               147456  2 snd_sof_pci,snd_sof_intel_hda_common
intel_wmi_thunderbolt    20480  0
snd_soc_hdac_hda       24576  1 snd_sof_intel_hda_common
snd_hda_ext_core       32768  3 snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
snd_soc_acpi_intel_match    61440  2 snd_sof_intel_hda_common,snd_sof_pci_intel_cnl
iwlmvm                569344  0
serio_raw              20480  0
snd_soc_acpi           16384  2 snd_soc_acpi_intel_match,snd_sof_intel_hda_common
soundwire_bus          94208  3 soundwire_intel,soundwire_generic_allocation,soundwire_cadence
i915                 3100672  5
mac80211             1249280  1 iwlmvm
snd_soc_core          339968  4 soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_soc_hdac_hda
snd_hda_codec_hdmi     77824  1
snd_compress           24576  1 snd_soc_core
rmi_smbus              16384  0
ac97_bus               16384  1 snd_soc_core
rmi_core              106496  1 rmi_smbus
snd_pcm_dmaengine      16384  1 snd_soc_core
libarc4                16384  1 mac80211
videobuf2_vmalloc      20480  2 rmi_core,uvcvideo
videobuf2_memops       20480  1 videobuf2_vmalloc
snd_hda_intel          53248  7
videobuf2_v4l2         32768  2 rmi_core,uvcvideo
snd_intel_dspcfg       28672  2 snd_hda_intel,snd_sof_intel_hda_common
snd_intel_sdw_acpi     20480  2 snd_sof_intel_hda_common,snd_intel_dspcfg
snd_hda_codec         163840  5 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_soc_hdac_hda
videobuf2_common       77824  5 videobuf2_vmalloc,rmi_core,videobuf2_v4l2,uvcvideo,videobuf2_memops
snd_seq_midi           20480  0
iwlwifi               450560  1 iwlmvm
snd_seq_midi_event     16384  1 snd_seq_midi
snd_hda_core          110592  9 snd_hda_codec_generic,snd_hda_codec_conexant,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_sof_intel_hda_common,snd_soc_hdac_hda,snd_sof_intel_hda
videodev              258048  4 rmi_core,videobuf2_v4l2,uvcvideo,videobuf2_common
snd_rawmidi            49152  1 snd_seq_midi
thinkpad_acpi         131072  0
snd_hwdep              16384  1 snd_hda_codec
ttm                    86016  1 i915
ee1004                 20480  0
snd_seq                77824  2 snd_seq_midi,snd_seq_midi_event
nvram                  16384  1 thinkpad_acpi
mc                     65536  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
nls_iso8859_1          16384  1
snd_pcm               143360  11 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,soundwire_intel,snd_sof,snd_sof_intel_hda_common,snd_compress,snd_soc_core,snd_hda_core,snd_pcm_dmaengine
ledtrig_audio          16384  4 snd_ctl_led,snd_hda_codec_generic,snd_sof,thinkpad_acpi
drm_kms_helper        311296  2 nvidia_drm,i915
snd_seq_device         16384  3 snd_seq,snd_seq_midi,snd_rawmidi
processor_thermal_device_pci_legacy    16384  0
cec                    61440  2 drm_kms_helper,i915
cfg80211              974848  3 iwlmvm,iwlwifi,mac80211
8250_dw                16384  0
snd_timer              40960  2 snd_seq,snd_pcm
processor_thermal_device    20480  1 processor_thermal_device_pci_legacy
mei_me                 40960  1
rc_core                65536  1 cec
i2c_algo_bit           16384  1 i915
processor_thermal_rfim    24576  1 processor_thermal_device
mei                   135168  3 mei_hdcp,mei_me
fb_sys_fops            16384  1 drm_kms_helper
processor_thermal_mbox    16384  2 processor_thermal_rfim,processor_thermal_device
snd                   106496  28 snd_ctl_led,snd_hda_codec_generic,snd_seq,snd_hda_codec_conexant,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_compress,thinkpad_acpi,snd_soc_core,snd_pcm,snd_rawmidi
syscopyarea            16384  1 drm_kms_helper
processor_thermal_rapl    20480  1 processor_thermal_device
ucsi_acpi              16384  0
sysfillrect            20480  1 drm_kms_helper
intel_rapl_common      40960  2 intel_rapl_msr,processor_thermal_rapl
sysimgblt              16384  1 drm_kms_helper
typec_ucsi             45056  1 ucsi_acpi
intel_soc_dts_iosf     20480  1 processor_thermal_device_pci_legacy
intel_pch_thermal      20480  0
typec                  69632  2 typec_displayport,typec_ucsi
soundcore              16384  2 snd_ctl_led,snd
int3403_thermal        20480  0
platform_profile       16384  1 thinkpad_acpi
int340x_thermal_zone    20480  2 int3403_thermal,processor_thermal_device
int3400_thermal        20480  0
acpi_thermal_rel       16384  1 int3400_thermal
acpi_pad              184320  0
mac_hid                16384  0
sch_fq_codel           20480  2
ipmi_devintf           20480  0
ipmi_msghandler       122880  1 ipmi_devintf
msr                    16384  0
parport_pc             49152  0
ppdev                  24576  0
lp                     28672  0
parport                69632  3 parport_pc,lp,ppdev
pstore_blk             16384  0
ramoops                32768  0
pstore_zone            32768  1 pstore_blk
mtd                    77824  0
reed_solomon           28672  1 ramoops
efi_pstore             16384  0
drm                   622592  15 drm_kms_helper,nvidia,nvidia_drm,i915,ttm
ip_tables              32768  0
x_tables               53248  7 xt_conntrack,nft_compat,xt_tcpudp,xt_addrtype,xt_nat,ip_tables,xt_MASQUERADE
autofs4                49152  2
wacom                 131072  0
hid_generic            16384  0
usbhid                 65536  1 wacom
hid                   151552  3 wacom,usbhid,hid_generic
nvme                   49152  3
sdhci_pci              69632  0
cqhci                  36864  1 sdhci_pci
i2c_i801               36864  0
intel_lpss_pci         24576  0
e1000e                299008  0
sdhci                  81920  1 sdhci_pci
crc32_pclmul           16384  0
i2c_smbus              20480  1 i2c_i801
psmouse               176128  0
nvme_core             135168  4 nvme
thunderbolt           315392  0
intel_lpss             16384  1 intel_lpss_pci
xhci_pci               24576  0
idma64                 20480  0
xhci_pci_renesas       20480  1 xhci_pci
wmi                    32768  3 intel_wmi_thunderbolt,wmi_bmof,think_lmi
video                  61440  2 thinkpad_acpi,i915
pinctrl_cannonlake     36864  0
$ lshw | grep -B 24 -i wifi
        *-pci:5
             description: PCI bridge
             product: Cannon Lake PCH PCI Express Root Port #15
             vendor: Intel Corporation
             physical id: 1d.6
             bus info: pci@0000:00:1d.6
             version: f0
             width: 32 bits
             clock: 33MHz
             capabilities: pci pciexpress msi pm normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:127 memory:ceb00000-cebfffff
           *-network
                description: Wireless interface
                product: Wi-Fi 6 AX200
                physical id: 0
                bus info: pci@0000:52:00.0
                logical name: wlp82s0
                version: 1a
                serial: ac:67:5d:c8:4d:35
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
                configuration: broadcast=yes driver=iwlwifi driverversion=5.15.0-46-generic firmware=66.f1c864e0.0 cc-a0-66.ucode ip=192.168.0.239 latency=0 link=yes multicast=yes wireless=IEEE 802.11
13 Antworten
AndrewG_Intel
Mitarbeiter
12.647Aufrufe
Hello @zedisdead
In order to review this further, could you please provide the following details?
1- Is this behavior happening since the first day or did it work fine before?
2- Is the Intel® Wi-Fi 6 AX200 the original wireless adapter that came pre-installed in your system or did you install/integrate it on the computer?
3- Have you tried installing the firmware from the following page? If not, we recommend installing the firmware and testing again.
4- Type the following command to the terminal: # lspci​ and provide us with the outcome.
If the Intel network controller ​is properly identified, (for example: you see a line "Intel Corporation Wireless AX200 or similar) please proceed to step 4.
5- Type in the command: # modinfo iwlwifi​ and provide the outcome.
Andrew G.
zedisdead
Anfänger
12.590Aufrufe
Hi Andrew,
Please find below the answers to your questions.
Zed
1. Since the first day. I got this laptop from my work with a fresh install of Ubuntu 22.04
2.  Intel® Wi-Fi 6 AX200 is the original wireless adapter.
3. No I haven't. The firmware (66.f1c864e0.0 cc-a0-66.ucode) in use came with Ubuntu 22.04. Can you please advise what's a newer firmware to try?
4.
$ lspci
00:00.0 Host bridge: Intel Corporation Device 3e20 (rev 0d)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0d)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0d)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:15.0 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:16.3 Serial controller: Intel Corporation Cannon Lake PCH Active Management Technology - SOL (rev 10)
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0)
00:1b.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #15 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
00:1f.0 ISA bridge: Intel Corporation Cannon Lake LPC Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation TU117GLM [Quadro T2000 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
04:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
06:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
2c:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
52:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
53:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller
5.
i$ modinfo iwlwifi
filename:       /lib/modules/5.15.0-46-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
author:         Intel Corporation <linuxwifi@intel.com>
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-bz-a0-mr-a0-66.ucode
firmware:       iwlwifi-bz-a0-gf4-a0-66.ucode
firmware:       iwlwifi-bz-a0-gf-a0-66.ucode
firmware:       iwlwifi-bz-a0-hr-b0-66.ucode
firmware:       iwlwifi-SoSnj-a0-mr-a0-66.ucode
firmware:       iwlwifi-ma-a0-fm-a0-66.ucode
firmware:       iwlwifi-ma-a0-mr-a0-66.ucode
firmware:       iwlwifi-ma-a0-gf4-a0-66.ucode
firmware:       iwlwifi-ma-a0-gf-a0-66.ucode
firmware:       iwlwifi-ma-a0-hr-b0-66.ucode
firmware:       iwlwifi-SoSnj-a0-jf-b0-66.ucode
firmware:       iwlwifi-SoSnj-a0-hr-b0-66.ucode
firmware:       iwlwifi-SoSnj-a0-gf-a0-66.ucode
firmware:       iwlwifi-SoSnj-a0-gf4-a0-66.ucode
firmware:       iwlwifi-ty-a0-gf-a0-66.ucode
firmware:       iwlwifi-so-a0-gf-a0-66.ucode
firmware:       iwlwifi-so-a0-hr-b0-66.ucode
firmware:       iwlwifi-so-a0-jf-b0-66.ucode
firmware:       iwlwifi-cc-a0-66.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-66.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-66.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-66.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-66.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-66.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-66.ucode
firmware:       iwlwifi-Qu-b0-hr-b0-66.ucode
srcversion:     40FD69FEC12568AA09FE04D
alias:          pci:v00008086d00002727sv*sd*bc*sc*i*
alias:          pci:v00008086d00007E40sv*sd*bc*sc*i*
alias:          pci:v00008086d00002729sv*sd*bc*sc*i*
alias:          pci:v00008086d000054F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd*bc*sc*i*
alias:          pci:v00008086d00002726sv*sd*bc*sc*i*
alias:          pci:v00008086d00002725sv*sd*bc*sc*i*
alias:          pci:v00008086d00002723sv*sd*bc*sc*i*
alias:          pci:v00008086d00002720sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd*bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002526sv*sd*bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000526Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211
retpoline:      Y
intree:         Y
vermagic:       5.15.0-46-generic SMP mod_unload modversions
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        7D:17:41:79:9B:FD:BB:C4:C9:58:54:28:ED:61:EB:C2:E4:6C:2E:06
sig_hashalgo:   sha512
signature:      19:AE:5F:AF:C2:66:2F:32:AF:70:8D:CC:76:AA:98:50:1F:26:F9:19:
		E9:41:96:05:79:D0:C0:7D:11:E7:DA:A2:5D:AB:1C:B6:71:92:1D:4A:
		86:5D:16:1E:70:9D:BD:9D:0B:AD:EF:7F:C2:EE:DC:24:86:C0:52:93:
		26:C3:02:39:FD:37:52:1F:7A:10:20:43:8A:19:BA:1B:09:FE:EE:E4:
		0B:F3:14:E3:AC:6D:05:CB:38:6F:B8:AB:04:30:3C:FD:61:24:2D:61:
		1B:D9:5A:17:2F:A6:2E:52:40:43:7B:5A:D5:2C:6D:48:2D:80:F6:4F:
		C1:E3:D8:6F:3D:88:3B:B4:E0:C0:6E:63:3D:80:18:64:D1:A8:4A:07:
		CC:86:C0:D4:74:EC:52:8D:B4:CB:C6:8F:4D:5D:50:68:D1:93:F4:84:
		70:9B:FF:EE:52:88:78:DA:A8:17:1E:5F:6E:BF:E5:C3:1E:1D:65:29:
		ED:3E:F7:AC:95:28:17:D5:DE:A3:EE:38:75:50:38:22:FC:7F:D7:58:
		4F:AB:A8:F8:B7:B1:CB:51:B8:54:7A:76:3D:F8:8B:16:FB:2C:7D:EA:
		56:0A:39:BC:97:98:1D:69:4F:A0:8E:42:C8:49:3D:1D:D6:99:85:04:
		F5:45:4D:29:B9:CC:E2:45:58:E3:4C:11:DB:28:D7:FC:F9:F6:03:30:
		3E:21:62:95:78:DF:69:35:77:DC:15:71:20:9D:BF:52:82:DB:AC:60:
		C4:62:41:E3:7F:ED:FD:DC:49:96:5C:B6:A8:7D:5B:85:06:65:21:A7:
		D3:39:2F:29:C3:EE:17:80:AC:64:EA:62:D1:51:9E:CA:D2:09:5C:49:
		B7:EA:2E:76:8A:94:8E:82:46:55:87:BD:8A:D0:FA:7D:1C:4B:48:43:
		F3:53:A8:1C:0D:1C:98:E7:13:03:A2:DC:30:62:22:01:F7:A1:81:07:
		E4:15:67:2F:DF:F2:AA:9B:DD:06:27:FD:C4:C6:32:10:05:D2:4D:AE:
		AA:B8:23:A9:6F:79:DA:DB:23:1B:BD:C1:54:CC:48:2D:BF:CA:44:0E:
		CF:EF:06:ED:19:29:F1:BD:51:14:7F:FE:41:0C:9A:E0:1D:B8:42:C4:
		86:00:35:A2:6F:0E:BA:91:B5:A9:9A:CF:35:6C:4C:2A:49:45:4E:CE:
		8F:6A:0D:84:2A:BD:26:4F:B7:E6:BE:61:7D:C8:13:2B:D6:E7:16:2A:
		FA:3E:43:BF:72:40:3B:14:0C:F3:56:B4:69:BA:F4:31:6A:4F:7B:EC:
		12:07:5B:EA:CD:A1:A5:07:45:2A:A7:68:B8:AF:95:12:0E:6C:14:3F:
		AD:66:7E:E0:D2:D8:CE:F8:38:06:D2:B5
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:Enable debug INI TLV FW debug infrastructure (default: true (bool)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
zedisdead
Anfänger
12.596Aufrufe
Hi Andrew,
Please find the answers to your questions below:
1. Yes, I've recently started using this laptop from work.
2. Wi-Fi 6 AX200 is the only and the original wireless adapter.
3. Instead of updating the adapter firmware I've updated the linux kernel to version 5.18, which comes with: firmware=71.058653f6.0 cc-a0-71.ucode. However the issue persists.
4. Please find the output in file attached, along with the output of the previous commands but capture while running kernel 5.18
5. Same as above.
Thank you.
UPDATED: attached dmesg output
AndrewG_Intel
Mitarbeiter
12.587Aufrufe
Hello zedisdead
Thank you for your response and for all the reports. Please allow us to review this further and we will be posting back in the thread as soon as more details are available.
Andrew G.
AndrewG_Intel
Mitarbeiter
12.502Aufrufe
Hello zedisdead
Thank you for your patience in this matter.
 We have reviewed the logs and confirmed wireless errors occurred at the hardware level, this is an OEM issue:
  • Line 1234: Aug 22 09:50:32.948425 libR90XGYAE kernel: iwlwifi 0000:52:00.0: base HW address: ac:67:5d:c8:4d:35
  • Line 1243: Aug 22 09:50:33.148800 libR90XGYAE kernel: iwlwifi 0000:52:00.0 wlp82s0: renamed from wlan0
  • Line 1373: Aug 22 09:50:52.340452 libR90XGYAE kernel: iwlwifi 0000:52:00.0: Error sending STATISTICS_CMD: time out after 2000ms.
  • Line 1374: Aug 22 09:50:52.341171 libR90XGYAE kernel: iwlwifi 0000:52:00.0: Current CMD queue read_ptr 111 write_ptr 112
  • Line 1377: Aug 22 09:50:52.360545 libR90XGYAE kernel: WARNING: CPU: 2 PID: 1444 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2118 __iwl_trans_pcie_grab_nic_access>
In this case, we would like to suggest the possible workarounds:
If the behavior persists, our recommendation is to contact your Original Equipment Manufacturer (OEM) Lenovo* for further assistance on this matter.
Andrew G.
pconstantine
Einsteiger
12.003Aufrufe
Have exactly the same problem with Asus Strix X670E-E motherboard.
Unfortunately there is nothing like "PCIe Power Saving mode" or "PCIe ASPM (Active State Power Management)" in the bios settings.
After it fails to call __iwl_trans_pcie_grab_nic_access as reported in dmesg the wifi driver fails to wake up the card.
The only solution is to reboot.
I suppose it's still a driver problem as the Lenovo laptop of the OP and my desktop system have nothing in common apart from the wifi chipset and Ubuntu 22.04
zedisdead
Anfänger
11.445Aufrufe
I'm still struggling with this issue. Have you found workaround?
AndrewG_Intel
Mitarbeiter
12.464Aufrufe
Hello zedisdead
We are checking this thread and we would like to know if you were able to review our previous post and if the behavior persists.
Please feel free to share any feedback about the outcome of the steps.
Andrew G.
AndrewG_Intel
Mitarbeiter
12.430Aufrufe
Hello zedisdead
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andrew G.
zedisdead
Anfänger
12.333Aufrufe
Sorry,
I missed notifications about your reply.
I haven't deliberately tried the fix your suggest but somehow the issue has been solved.
Not sure if the bios was updated or if it was due to a kernel update but it's no longer happening.
Thank you your time and help.
Zed.
pconstantine
Einsteiger
11.962Aufrufe
Got it completely fixed by adding "pcie_port_pm=off pcie_aspm.policy=performance" to the kernel boot flags
zedisdead
Anfänger
11.663Aufrufe
Unfortunately it make no difference to me.
zedisdead
Anfänger
11.663Aufrufe
Unfortunately the issue came back after a couple kernel updates:
$ sudo dmesg | grep wifi
[    5.947719] iwlwifi 0000:52:00.0: enabling device (0000 -> 0002)
[    5.967946] iwlwifi 0000:52:00.0: Direct firmware load for iwlwifi-cc-a0-72.ucode failed with error -2
[    5.969371] iwlwifi 0000:52:00.0: api flags index 2 larger than supported by driver
[    5.969385] iwlwifi 0000:52:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
[    5.969791] iwlwifi 0000:52:00.0: loaded firmware version 71.058653f6.0 cc-a0-71.ucode op_mode iwlmvm
[    6.266752] iwlwifi 0000:52:00.0: BIOS contains WGDS but no WRDS
[    6.266955] iwlwifi 0000:52:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz, REV=0x340
[    6.415766] iwlwifi 0000:52:00.0: Detected RF HR B3, rfid=0x10a100
[    6.490058] iwlwifi 0000:52:00.0: base HW address: ac:67:5d:c8:4d:35
[    6.524013] iwlwifi 0000:52:00.0 wlp82s0: renamed from wlan0
[ 1303.805003] iwlwifi 0000:52:00.0: Error sending STATISTICS_CMD: time out after 2000ms.
[ 1303.805021] iwlwifi 0000:52:00.0: Current CMD queue read_ptr 150 write_ptr 151
[ 1303.826007] WARNING: CPU: 15 PID: 1623 at drivers/net/wireless/intel/iwlwifi/pcie/trans.c:2118 __iwl_trans_pcie_grab_nic_access+0x232/0x260 [iwlwifi]
[ 1303.826050]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1303.826104] RIP: 0010:__iwl_trans_pcie_grab_nic_access+0x232/0x260 [iwlwifi]
[ 1303.826126]  iwl_trans_pcie_grab_nic_access+0x1f/0x50 [iwlwifi]
[ 1303.826134]  iwl_force_nmi+0x5e/0x100 [iwlwifi]
[ 1303.826140]  iwl_trans_sync_nmi_with_addr+0x5a/0x130 [iwlwifi]
[ 1303.826146]  iwl_trans_pcie_sync_nmi+0x49/0x70 [iwlwifi]
[ 1303.826154]  iwl_trans_txq_send_hcmd_sync+0x2f3/0x370 [iwlwifi]
[ 1303.826165]  iwl_trans_txq_send_hcmd+0xb3/0x150 [iwlwifi]
[ 1303.826172]  iwl_trans_send_cmd+0x88/0x110 [iwlwifi]
[ 1303.826406] iwlwifi 0000:52:00.0: iwlwifi transaction failed, dumping registers
[ 1303.826408] iwlwifi 0000:52:00.0: iwlwifi device config registers:
[ 1303.826533] iwlwifi 0000:52:00.0: 00000000: 27238086 00100000 0280001a 00000000 00000004 00000000 00000000 00000000
[ 1303.826535] iwlwifi 0000:52:00.0: 00000020: 00000000 00000000 00000000 00808086 00000000 000000c8 00000000 00000100
[ 1303.826536] iwlwifi 0000:52:00.0: 00000040: 00028010 10008ec0 001b0c10 0045e812 10120000 00000000 00000000 00000000
[ 1303.826538] iwlwifi 0000:52:00.0: 00000060: 00000000 00080812 00000005 00000006 00000002 00000000 00000000 00000000
[ 1303.826539] iwlwifi 0000:52:00.0: 00000080: 000f0011 00002000 00003000 00000000 00000000 00000000 00000000 00000000
[ 1303.826540] iwlwifi 0000:52:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826541] iwlwifi 0000:52:00.0: 000000c0: 00000000 00000000 c823d001 0d000008 00804005 00000000 00000000 00000000
[ 1303.826542] iwlwifi 0000:52:00.0: 000000e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826543] iwlwifi 0000:52:00.0: 00000100: 14c10001 00100000 00000000 00462031 00002000 00002000 00000014 40000001
[ 1303.826544] iwlwifi 0000:52:00.0: 00000120: 0000000f ceb00460 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826546] iwlwifi 0000:52:00.0: 00000140: 14c00000 ff000000 000000ff 15410018 00000000 0001001e 00481e1f 00000000
[ 1303.826546] iwlwifi 0000:52:00.0: iwlwifi device memory mapped registers:
[ 1303.826569] iwlwifi 0000:52:00.0: 00000000: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 1303.826570] iwlwifi 0000:52:00.0: 00000020: ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
[ 1303.826573] iwlwifi 0000:52:00.0: iwlwifi device AER capability structure:
[ 1303.826588] iwlwifi 0000:52:00.0: 00000000: 14c10001 00100000 00000000 00462031 00002000 00002000 00000014 40000001
[ 1303.826589] iwlwifi 0000:52:00.0: 00000020: 0000000f ceb00460 00000000
[ 1303.826589] iwlwifi 0000:52:00.0: iwlwifi parent port (0000:00:1d.6) config registers:
[ 1303.826661] iwlwifi 0000:00:1d.6: 00000000: a3368086 00100407 060400f0 00810000 00000000 00000000 00525200 200000f0
[ 1303.826662] iwlwifi 0000:00:1d.6: 00000020: ceb0ceb0 0001fff1 00000000 00000000 00000000 00000040 00000000 000203ff
[ 1303.826663] iwlwifi 0000:00:1d.6: 00000040: 01428010 00008001 00100000 0f724c13 70120042 0074b200 01400000 00000008
[ 1303.826664] iwlwifi 0000:00:1d.6: 00000060: 00000000 00000837 00000000 0000000e 00000003 00000000 00000000 00000000
[ 1303.826665] iwlwifi 0000:00:1d.6: 00000080: 00019005 fee002d8 00000000 00000000 0000a00d 22a817aa 00000000 00000000
[ 1303.826667] iwlwifi 0000:00:1d.6: 000000a0: c8030001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826668] iwlwifi 0000:00:1d.6: 000000c0: 00000000 00000000 00000000 00000000 07001001 00021842 099e0008 00000000
[ 1303.826669] iwlwifi 0000:00:1d.6: 000000e0: 00e30300 88b688b6 00100006 00000000 00000150 4c000000 01120fb5 83000000
[ 1303.826670] iwlwifi 0000:00:1d.6: 00000100: 14010001 00000000 00010000 00060011 00003101 00002000 00000000 00000000
[ 1303.826671] iwlwifi 0000:00:1d.6: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826672] iwlwifi 0000:00:1d.6: 00000140: 1501000d 000d000f 00000000 00000000 2001001f 00000406 00000003 00000000
[ 1303.826673] iwlwifi 0000:00:1d.6: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826674] iwlwifi 0000:00:1d.6: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826675] iwlwifi 0000:00:1d.6: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826676] iwlwifi 0000:00:1d.6: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826677] iwlwifi 0000:00:1d.6: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.826678] iwlwifi 0000:00:1d.6: 00000200: 2201001e 00b0281f 6002280f
[ 1303.826683] iwlwifi 0000:52:00.0: iwlwifi root port (0000:00:1d.6) AER cap structure:
[ 1303.826691] iwlwifi 0000:00:1d.6: 00000000: 14010001 00000000 00010000 00060011 00003101 00002000 00000000 00000000
[ 1303.826692] iwlwifi 0000:00:1d.6: 00000020: 00000000 00000000 00000000 00000000 00000000 00000000
[ 1303.847652] WARNING: CPU: 15 PID: 1623 at drivers/net/wireless/intel/iwlwifi/iwl-trans.h:1414 iwl_fwrt_dump_lmac_error_log+0x4c2/0x540 [iwlwifi]
[ 1303.847687]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1303.847727] RIP: 0010:iwl_fwrt_dump_lmac_error_log+0x4c2/0x540 [iwlwifi]
[ 1303.847748]  iwl_fwrt_dump_error_logs+0x2d/0x210 [iwlwifi]
[ 1303.847764]  iwl_trans_sync_nmi_with_addr+0xa6/0x130 [iwlwifi]
[ 1303.847770]  iwl_trans_pcie_sync_nmi+0x49/0x70 [iwlwifi]
[ 1303.847778]  iwl_trans_txq_send_hcmd_sync+0x2f3/0x370 [iwlwifi]
[ 1303.847788]  iwl_trans_txq_send_hcmd+0xb3/0x150 [iwlwifi]
[ 1303.847795]  iwl_trans_send_cmd+0x88/0x110 [iwlwifi]
[ 1303.848005] iwlwifi 0000:52:00.0: HW error, resetting before reading
[ 1303.876610] iwlwifi 0000:52:00.0: Loaded firmware version: 71.058653f6.0 cc-a0-71.ucode
[ 1303.876614] iwlwifi 0000:52:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 1303.876616] iwlwifi 0000:52:00.0: 0x00000000 | trm_hw_status0
[ 1303.876617] iwlwifi 0000:52:00.0: 0x00000000 | trm_hw_status1
[ 1303.876618] iwlwifi 0000:52:00.0: 0x00000000 | branchlink2
[ 1303.876618] iwlwifi 0000:52:00.0: 0x00000000 | interruptlink1
[ 1303.876619] iwlwifi 0000:52:00.0: 0x00000000 | interruptlink2
[ 1303.876620] iwlwifi 0000:52:00.0: 0x00000000 | data1
[ 1303.876621] iwlwifi 0000:52:00.0: 0x00000000 | data2
[ 1303.876622] iwlwifi 0000:52:00.0: 0x00000000 | data3
[ 1303.876622] iwlwifi 0000:52:00.0: 0x00000000 | beacon time
[ 1303.876623] iwlwifi 0000:52:00.0: 0x00000000 | tsf low
[ 1303.876624] iwlwifi 0000:52:00.0: 0x00000000 | tsf hi
[ 1303.876625] iwlwifi 0000:52:00.0: 0x00000000 | time gp1
[ 1303.876625] iwlwifi 0000:52:00.0: 0x00000000 | time gp2
[ 1303.876626] iwlwifi 0000:52:00.0: 0x00000000 | uCode revision type
[ 1303.876627] iwlwifi 0000:52:00.0: 0x00000000 | uCode version major
[ 1303.876628] iwlwifi 0000:52:00.0: 0x00000000 | uCode version minor
[ 1303.876628] iwlwifi 0000:52:00.0: 0x00000000 | hw version
[ 1303.876629] iwlwifi 0000:52:00.0: 0x00000000 | board version
[ 1303.876630] iwlwifi 0000:52:00.0: 0x00000000 | hcmd
[ 1303.876631] iwlwifi 0000:52:00.0: 0x00000000 | isr0
[ 1303.876632] iwlwifi 0000:52:00.0: 0x00000000 | isr1
[ 1303.876632] iwlwifi 0000:52:00.0: 0x00000000 | isr2
[ 1303.876633] iwlwifi 0000:52:00.0: 0x00000000 | isr3
[ 1303.876634] iwlwifi 0000:52:00.0: 0x00000000 | isr4
[ 1303.876634] iwlwifi 0000:52:00.0: 0x00000000 | last cmd Id
[ 1303.876635] iwlwifi 0000:52:00.0: 0x00000000 | wait_event
[ 1303.876636] iwlwifi 0000:52:00.0: 0x00000000 | l2p_control
[ 1303.876637] iwlwifi 0000:52:00.0: 0x00000000 | l2p_duration
[ 1303.876638] iwlwifi 0000:52:00.0: 0x00000000 | l2p_mhvalid
[ 1303.876638] iwlwifi 0000:52:00.0: 0x00000000 | l2p_addr_match
[ 1303.876639] iwlwifi 0000:52:00.0: 0x00000000 | lmpm_pmg_sel
[ 1303.876640] iwlwifi 0000:52:00.0: 0x00000000 | timestamp
[ 1303.876641] iwlwifi 0000:52:00.0: 0x00000000 | flow_handler
[ 1303.897797] iwlwifi 0000:52:00.0: 0x00000000 | ADVANCED_SYSASSERT
[ 1303.897799] iwlwifi 0000:52:00.0: 0x00000000 | umac branchlink1
[ 1303.897800] iwlwifi 0000:52:00.0: 0x00000000 | umac branchlink2
[ 1303.897801] iwlwifi 0000:52:00.0: 0x00000000 | umac interruptlink1
[ 1303.897802] iwlwifi 0000:52:00.0: 0x00000000 | umac interruptlink2
[ 1303.897803] iwlwifi 0000:52:00.0: 0x00000000 | umac data1
[ 1303.897803] iwlwifi 0000:52:00.0: 0x00000000 | umac data2
[ 1303.897804] iwlwifi 0000:52:00.0: 0x00000000 | umac data3
[ 1303.897805] iwlwifi 0000:52:00.0: 0x00000000 | umac major
[ 1303.897806] iwlwifi 0000:52:00.0: 0x00000000 | umac minor
[ 1303.897806] iwlwifi 0000:52:00.0: 0x00000000 | frame pointer
[ 1303.897807] iwlwifi 0000:52:00.0: 0x00000000 | stack pointer
[ 1303.897808] iwlwifi 0000:52:00.0: 0x00000000 | last host cmd
[ 1303.897809] iwlwifi 0000:52:00.0: 0x00000000 | isr status reg
[ 1303.919013] iwlwifi 0000:52:00.0: IML/ROM dump:
[ 1303.919015] iwlwifi 0000:52:00.0: 0x5A5A | IML/ROM SYSASSERT
[ 1303.919016] iwlwifi 0000:52:00.0: 0x5A5A5A5A | IML/ROM error/state
[ 1303.940097] iwlwifi 0000:52:00.0: 0x5A5A5A5A | IML/ROM data1
[ 1303.961232] iwlwifi 0000:52:00.0: 0x5A5A5A5A | IML/ROM WFPM_AUTH_KEY_0
[ 1304.003311] iwlwifi 0000:52:00.0: WRT: Collecting data: ini trigger 4 fired (delay=0ms).
[ 1304.024497] iwlwifi 0000:52:00.0: WRT: Failed to dump region: id=1, type=10
[ 1304.045645] iwlwifi 0000:52:00.0: WRT: Failed to dump region: id=2, type=11
[ 1304.172093] iwlwifi 0000:52:00.0: Failed to get monitor header
[ 1304.172095] iwlwifi 0000:52:00.0: WRT: Failed to fill region header: id=16, type=2
[ 1304.256771] iwlwifi 0000:52:00.0: WRT: Failed to dump region: id=21, type=10
[ 1304.277893] iwlwifi 0000:52:00.0: WRT: Failed to dump region: id=22, type=10
[ 1306.494241] iwlwifi 0000:52:00.0: Error, can not clear persistence bit
[ 1306.494247] iwlwifi 0000:52:00.0: mac start retry 0
[ 1306.494374]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.494565]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.494769] iwlwifi 0000:52:00.0: Failed to synchronize multicast groups update
[ 1306.494999]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.495284]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.495438]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.495763]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.495909]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.496142]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.496278]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.496568]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.496661] iwlwifi 0000:52:00.0: Failed to trigger RX queues sync (-5)
[ 1306.496710]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.496966]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.497142]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.497413]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.497549]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.497790]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.498117]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.498754]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.499006]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.499342]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.499521]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.499856]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.500021]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.500377]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.500621]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.500939]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.501109]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.501437]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.501603]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.502000]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.502280]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.502608]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.502781]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.503130]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.503301]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.503649]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.503765] WARNING: CPU: 15 PID: 1413 at drivers/net/wireless/intel/iwlwifi/mvm/../iwl-trans.h:1354 iwl_mvm_wait_sta_queues_empty+0xaa/0xf0 [iwlmvm]
[ 1306.503805]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
[ 1306.504282]  ? __iwl_err.cold+0x5d/0x62 [iwlwifi]
[ 1306.504389] iwlwifi 0000:52:00.0: iwl_trans_wait_txq_empty bad state = 0
[ 1306.504932]  snd_sof_utils snd_soc_hdac_hda snd_hda_ext_core rapl nvidia(POE) snd_soc_acpi_intel_match snd_soc_acpi soundwire_bus snd_soc_core snd_hda_codec_hdmi snd_compress ac97_bus snd_pcm_dmaengine snd_hda_intel iwlmvm snd_intel_dspcfg snd_intel_sdw_acpi i915 snd_hda_codec binfmt_misc mac80211 snd_hda_core snd_hwdep mei_pxp mei_hdcp snd_pcm rmi_smbus intel_rapl_msr rmi_core libarc4 drm_buddy snd_seq_midi videobuf2_vmalloc videobuf2_memops ttm snd_seq_midi_event videobuf2_v4l2 snd_rawmidi videobuf2_common iwlwifi thinkpad_acpi drm_dp_helper input_leds cmdlinepart videodev snd_seq cec nvram spi_nor processor_thermal_device_pci_legacy platform_profile think_lmi rc_core iwlmei intel_cstate serio_raw intel_wmi_thunderbolt mc firmware_attributes_class wmi_bmof mtd ee1004 ledtrig_audio processor_thermal_device snd_seq_device nls_iso8859_1 drm_kms_helper processor_thermal_rfim i2c_algo_bit ucsi_acpi snd_timer cfg80211 processor_thermal_mbox fb_sys_fops mei_me typec_ucsi
$ lspci
00:00.0 Host bridge: Intel Corporation Device 3e20 (rev 0d)
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 0d)
00:02.0 VGA compatible controller: Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630] (rev 02)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 0d)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:12.0 Signal processing controller: Intel Corporation Cannon Lake PCH Thermal Controller (rev 10)
00:14.0 USB controller: Intel Corporation Cannon Lake PCH USB 3.1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Cannon Lake PCH Shared SRAM (rev 10)
00:15.0 Serial bus controller: Intel Corporation Cannon Lake PCH Serial IO I2C Controller #0 (rev 10)
00:16.0 Communication controller: Intel Corporation Cannon Lake PCH HECI Controller (rev 10)
00:16.3 Serial controller: Intel Corporation Cannon Lake PCH Active Management Technology - SOL (rev 10)
00:1b.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #17 (rev f0)
00:1b.4 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #21 (rev f0)
00:1c.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #1 (rev f0)
00:1d.0 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #9 (rev f0)
00:1d.6 PCI bridge: Intel Corporation Cannon Lake PCH PCI Express Root Port #15 (rev f0)
00:1e.0 Communication controller: Intel Corporation Cannon Lake PCH Serial IO UART Host Controller (rev 10)
00:1f.0 ISA bridge: Intel Corporation Cannon Lake LPC Controller (rev 10)
00:1f.3 Audio device: Intel Corporation Cannon Lake PCH cAVS (rev 10)
00:1f.4 SMBus: Intel Corporation Cannon Lake PCH SMBus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Cannon Lake PCH SPI Controller (rev 10)
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (7) I219-LM (rev 10)
01:00.0 VGA compatible controller: NVIDIA Corporation TU117GLM [Quadro T2000 Mobile / Max-Q] (rev a1)
01:00.1 Audio device: NVIDIA Corporation Device 10fa (rev a1)
02:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller SM981/PM981/PM983
04:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:00.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:01.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:02.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
05:04.0 PCI bridge: Intel Corporation JHL7540 Thunderbolt 3 Bridge [Titan Ridge 4C 2018] (rev 06)
06:00.0 System peripheral: Intel Corporation JHL7540 Thunderbolt 3 NHI [Titan Ridge 4C 2018] (rev 06)
2c:00.0 USB controller: Intel Corporation JHL7540 Thunderbolt 3 USB Controller [Titan Ridge 4C 2018] (rev 06)
52:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
53:00.0 SD Host controller: Genesys Logic, Inc GL9755 SD Host Controller
$ modinfo iwlwifi
filename:       /lib/modules/5.18.17-051817-generic/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko
license:        GPL
description:    Intel(R) Wireless WiFi driver for Linux
firmware:       iwlwifi-100-5.ucode
firmware:       iwlwifi-1000-5.ucode
firmware:       iwlwifi-135-6.ucode
firmware:       iwlwifi-105-6.ucode
firmware:       iwlwifi-2030-6.ucode
firmware:       iwlwifi-2000-6.ucode
firmware:       iwlwifi-5150-2.ucode
firmware:       iwlwifi-5000-5.ucode
firmware:       iwlwifi-6000g2b-6.ucode
firmware:       iwlwifi-6000g2a-6.ucode
firmware:       iwlwifi-6050-5.ucode
firmware:       iwlwifi-6000-6.ucode
firmware:       iwlwifi-7265D-29.ucode
firmware:       iwlwifi-7265-17.ucode
firmware:       iwlwifi-3168-29.ucode
firmware:       iwlwifi-3160-17.ucode
firmware:       iwlwifi-7260-17.ucode
firmware:       iwlwifi-8265-36.ucode
firmware:       iwlwifi-8000C-36.ucode
firmware:       iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware:       iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware:       iwlwifi-BzBnj-a0-hr-b0-72.ucode
firmware:       iwlwifi-BzBnj-a0-gf4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-gf-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-fm4-a0-72.ucode
firmware:       iwlwifi-BzBnj-a0-fm-a0-72.ucode
firmware:       iwlwifi-gl-a0-fm-a0-72.ucode
firmware:       iwlwifi-bz-a0-fm-a0-72.ucode
firmware:       iwlwifi-bz-a0-mr-a0-72.ucode
firmware:       iwlwifi-bz-a0-gf4-a0-72.ucode
firmware:       iwlwifi-bz-a0-gf-a0-72.ucode
firmware:       iwlwifi-bz-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-mr-a0-72.ucode
firmware:       iwlwifi-ma-a0-fm-a0-72.ucode
firmware:       iwlwifi-ma-a0-mr-a0-72.ucode
firmware:       iwlwifi-ma-a0-gf4-a0-72.ucode
firmware:       iwlwifi-ma-a0-gf-a0-72.ucode
firmware:       iwlwifi-ma-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-jf-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-hr-b0-72.ucode
firmware:       iwlwifi-SoSnj-a0-gf-a0-72.ucode
firmware:       iwlwifi-SoSnj-a0-gf4-a0-72.ucode
firmware:       iwlwifi-ty-a0-gf-a0-72.ucode
firmware:       iwlwifi-so-a0-gf-a0-72.ucode
firmware:       iwlwifi-so-a0-hr-b0-72.ucode
firmware:       iwlwifi-so-a0-jf-b0-72.ucode
firmware:       iwlwifi-cc-a0-72.ucode
firmware:       iwlwifi-QuQnj-b0-jf-b0-72.ucode
firmware:       iwlwifi-QuZ-a0-jf-b0-72.ucode
firmware:       iwlwifi-QuZ-a0-hr-b0-72.ucode
firmware:       iwlwifi-Qu-b0-jf-b0-72.ucode
firmware:       iwlwifi-Qu-c0-hr-b0-72.ucode
firmware:       iwlwifi-QuQnj-b0-hr-b0-72.ucode
firmware:       iwlwifi-Qu-b0-hr-b0-72.ucode
srcversion:     5280A475D2A1879C790F8CB
alias:          pci:v00008086d00007740sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A840sv*sd*bc*sc*i*
alias:          pci:v00008086d00002727sv*sd*bc*sc*i*
alias:          pci:v00008086d00007E40sv*sd*bc*sc*i*
alias:          pci:v00008086d00002729sv*sd*bc*sc*i*
alias:          pci:v00008086d00007F70sv*sd*bc*sc*i*
alias:          pci:v00008086d000054F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F1sv*sd*bc*sc*i*
alias:          pci:v00008086d000051F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007AF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00007A70sv*sd*bc*sc*i*
alias:          pci:v00008086d00002726sv*sd*bc*sc*i*
alias:          pci:v00008086d00002725sv*sd*bc*sc*i*
alias:          pci:v00008086d00002723sv*sd*bc*sc*i*
alias:          pci:v00008086d00002720sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A0F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000043F0sv*sd*bc*sc*i*
alias:          pci:v00008086d00004DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d00003DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000034F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000006F0sv*sd*bc*sc*i*
alias:          pci:v00008086d000002F0sv*sd*bc*sc*i*
alias:          pci:v00008086d0000A370sv*sd*bc*sc*i*
alias:          pci:v00008086d00009DF0sv*sd*bc*sc*i*
alias:          pci:v00008086d000031DCsv*sd*bc*sc*i*
alias:          pci:v00008086d000030DCsv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Csv*sd*bc*sc*i*
alias:          pci:v00008086d0000271Bsv*sd*bc*sc*i*
alias:          pci:v00008086d00002526sv*sd*bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009074bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E01bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00003E02bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001014bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd000010D0bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024FDsv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000930bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000950bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000850bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000910bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000810bc*sc*i*
alias:          pci:v00008086d000024F6sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F5sv*sd00000010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000044bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000004bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008130bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000D030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd0000C030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00009030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00008030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00009010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00008010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000B0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D0B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000D010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd0000C010bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00001030bc*sc*i*
alias:          pci:v00008086d000024F4sv*sd00000030bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000150bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000250bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000050bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000012bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000001F0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000110bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000132bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000130bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd000010B0bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00001010bc*sc*i*
alias:          pci:v00008086d000024F3sv*sd00000010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009E10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009000bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd0000520Abc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005212bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005F10bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005490bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005290bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005590bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005190bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005090bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005420bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000502Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005020bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009410bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009510bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009200bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00009210bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009112bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000900Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00009010bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005202bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005102bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005002bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005200bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd0000500Abc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005000bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00001010bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005400bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005510bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005410bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005412bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005012bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005C10bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005210bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005302bc*sc*i*
alias:          pci:v00008086d0000095Bsv*sd00005310bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005100bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005110bc*sc*i*
alias:          pci:v00008086d0000095Asv*sd00005010bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00000000bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002150bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002050bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002110bc*sc*i*
alias:          pci:v00008086d000024FBsv*sd00002010bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00008010bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004210bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004310bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004110bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004510bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004410bc*sc*i*
alias:          pci:v00008086d00003166sv*sd00004212bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004012bc*sc*i*
alias:          pci:v00008086d00003165sv*sd00004010bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00001070bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008570bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008370bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00008270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00008070bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000370bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000472bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000470bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000272bc*sc*i*
alias:          pci:v00008086d000008B4sv*sd00000270bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000062bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000060bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000172bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000170bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000072bc*sc*i*
alias:          pci:v00008086d000008B3sv*sd00000070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C02Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C26Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C272bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000CC70bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000C270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C760bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C06Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000C070bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004420bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004220bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000402Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004020bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005770bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00005070bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004360bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004370bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004560bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004570bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Cbc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A6Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004A70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000486Ebc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004870bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004462bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000446Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004460bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004472bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004470bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004262bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd0000426Abc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004260bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004272bc*sc*i*
alias:          pci:v00008086d000008B2sv*sd00004270bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004162bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004062bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004160bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd0000406Abc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004060bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C70bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004C60bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004170bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004072bc*sc*i*
alias:          pci:v00008086d000008B1sv*sd00004070bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000462bc*sc*i*
alias:          pci:v00008086d00000893sv*sd00000262bc*sc*i*
alias:          pci:v00008086d00000892sv*sd00000062bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000822bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000422bc*sc*i*
alias:          pci:v00008086d00000895sv*sd00000222bc*sc*i*
alias:          pci:v00008086d00000894sv*sd00000022bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00005260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004860bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000446Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004460bc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd0000426Abc*sc*i*
alias:          pci:v00008086d0000088Fsv*sd00004260bc*sc*i*
alias:          pci:v00008086d0000088Esv*sd0000406Abc*sc*i*
alias:          pci:v00008086d0000088Esv*sd00004060bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004462bc*sc*i*
alias:          pci:v00008086d00000888sv*sd00004262bc*sc*i*
alias:          pci:v00008086d00000887sv*sd00004062bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004822bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004422bc*sc*i*
alias:          pci:v00008086d00000891sv*sd00004222bc*sc*i*
alias:          pci:v00008086d00000890sv*sd00004022bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005027bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005025bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005017bc*sc*i*
alias:          pci:v00008086d00000897sv*sd00005015bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005007bc*sc*i*
alias:          pci:v00008086d00000896sv*sd00005005bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001027bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001025bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001017bc*sc*i*
alias:          pci:v00008086d000008AFsv*sd00001015bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001007bc*sc*i*
alias:          pci:v00008086d000008AEsv*sd00001005bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000084sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000083sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001317bc*sc*i*
alias:          pci:v00008086d00000886sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001327bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000885sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000089sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000087sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005226bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005225bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005221bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005207bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005206bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005205bc*sc*i*
alias:          pci:v00008086d00000091sv*sd00005201bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005216bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005215bc*sc*i*
alias:          pci:v00008086d00000090sv*sd00005211bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005317bc*sc*i*
alias:          pci:v00008086d0000008Bsv*sd00005315bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005327bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005325bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005307bc*sc*i*
alias:          pci:v00008086d0000008Asv*sd00005305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00004820bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C228bc*sc*i*
alias:          pci:v00008086d00000085sv*sd0000C220bc*sc*i*
alias:          pci:v00008086d00000082sv*sd0000C020bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001318bc*sc*i*
alias:          pci:v00008086d00000085sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001328bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001308bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001307bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00000082sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004239sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001118bc*sc*i*
alias:          pci:v00008086d00004238sv*sd00001111bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001307bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000422Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001128bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001121bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001108bc*sc*i*
alias:          pci:v00008086d0000422Bsv*sd00001101bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001316bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001216bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001311bc*sc*i*
alias:          pci:v00008086d0000423Dsv*sd00001211bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001326bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001321bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001221bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001306bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001206bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001301bc*sc*i*
alias:          pci:v00008086d0000423Csv*sd00001201bc*sc*i*
alias:          pci:v00008086d0000423Bsv*sd00001011bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001021bc*sc*i*
alias:          pci:v00008086d0000423Asv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001114bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001014bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001111bc*sc*i*
alias:          pci:v00008086d00004236sv*sd00001011bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001104bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001004bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001101bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001001bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001124bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001024bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001121bc*sc*i*
alias:          pci:v00008086d00004235sv*sd00001021bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001316bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001216bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001315bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001215bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001314bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001214bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001311bc*sc*i*
alias:          pci:v00008086d00004237sv*sd00001211bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001326bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001226bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001325bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001225bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001324bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001224bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001321bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001221bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001306bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001206bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001305bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001205bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001304bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001204bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001301bc*sc*i*
alias:          pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends:        cfg80211,iwlmei
retpoline:      Y
intree:         Y
vermagic:       5.18.17-051817-generic SMP preempt mod_unload modversions
sig_id:         PKCS#7
signer:         Build time autogenerated kernel key
sig_key:        4F:F2:76:3C:F1:9D:42:20:CB:2D:EF:DA:BC:69:85:F2:11:E6:DC:BC
sig_hashalgo:   sha512
signature:      15:8C:2F:35:AB:56:8A:39:89:B5:C3:3A:20:51:5E:F0:09:6A:C2:19:
		4A:FB:E2:9F:33:B0:8D:ED:B1:8A:21:D9:35:69:BB:F0:AA:53:46:06:
		1E:30:92:84:E5:C6:A1:B5:FC:DB:75:02:B4:06:E4:42:88:8A:73:A5:
		7B:B9:8A:56:E1:CD:2D:C6:24:1D:BB:5A:B7:82:ED:B3:82:90:29:38:
		C4:0B:5A:9A:F0:41:4E:05:DF:7F:85:E4:88:1F:23:05:64:93:9A:F0:
		B9:0A:26:FD:9A:2E:5B:8D:9F:25:02:73:F9:8A:40:49:DB:BE:7B:F2:
		A9:7C:D6:D7:AD:4D:E3:1C:86:A7:F2:67:56:6F:F4:0C:0B:80:21:85:
		4A:FB:39:91:D4:48:26:49:88:8F:08:04:A2:A9:B0:22:E2:4A:E4:CC:
		30:DB:9D:F5:CE:82:57:61:0C:9F:5E:0F:33:38:95:7E:8F:BF:A5:0B:
		45:95:12:6D:93:D5:AA:88:45:CE:C0:09:E9:5B:FC:F1:4F:2B:F6:70:
		7C:8D:CB:5D:FA:7A:CE:37:36:FD:23:1D:1C:53:80:AA:11:AD:56:FC:
		9E:30:4A:4A:BD:CA:79:B1:3C:D0:F8:BE:CA:54:DA:60:8B:F7:21:5A:
		B3:19:44:E1:D6:7C:EA:57:6E:5F:4B:C2:F1:A8:25:61:32:43:32:A7:
		2D:7D:92:45:1B:AA:5B:79:4E:CE:05:87:F0:1C:07:87:E1:BC:6D:02:
		2C:BF:A3:50:5D:CF:3B:60:4C:4D:44:BB:E1:54:BD:1F:9F:94:86:5B:
		A7:9B:45:07:55:DA:20:E6:2C:8C:44:2B:CB:BB:FE:7B:AB:B1:AB:0E:
		28:91:5F:CB:64:5D:4F:34:66:B4:04:4E:EF:8F:63:F4:D2:63:1D:FD:
		50:82:80:58:8A:0D:BB:7C:DD:F5:3C:82:4C:62:D5:DB:F9:6A:B5:4B:
		5F:45:44:14:BF:62:0F:02:43:C5:6E:7A:27:69:2F:EB:05:70:12:09:
		3B:DB:A5:32:80:36:3C:F2:5F:DD:98:2E:0D:70:98:48:5B:DD:63:76:
		5C:2B:B8:3B:0E:86:A0:AC:13:CF:96:EF:3F:ED:7E:D3:5A:4E:5C:C5:
		3B:88:B4:C0:DD:A7:DC:3F:B0:AC:34:81:3C:14:EA:09:70:10:1C:3B:
		66:FD:5B:2A:28:08:4F:F7:90:41:A7:EC:02:51:4B:40:2C:09:CA:71:
		4E:7B:81:BB:87:82:52:07:C1:C6:FE:26:6B:DE:87:5D:08:36:0D:5C:
		C4:78:6D:47:89:78:CE:C7:06:C5:08:C0:79:9A:D3:18:6B:5D:1F:0F:
		3E:02:2B:60:A8:8D:BF:AB:75:9D:6E:92
parm:           swcrypto:using crypto in software (default 0 [hardware]) (int)
parm:           11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm:           amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm:           fw_restart:restart firmware in case of error (default true) (bool)
parm:           nvm_file:NVM file name (charp)
parm:           uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm:           enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm:           bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm:           led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm:           power_save:enable WiFi power management (default: disable) (bool)
parm:           power_level:default power save level (range from 1 - 5, default: 1) (int)
parm:           disable_11ac:Disable VHT capabilities (default: false) (bool)
parm:           remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm:           disable_11ax:Disable HE capabilities (default: false) (bool)
Antworten
