Wireless
9026 Discussions
AX201 160MHZ
Manny
Hi, i just had an issue where a new laptop equipped with the AX201 160MHZ WIFI 6 Adapter wasn't seeing certain WIFI SSIDS.
i tried updating the driver, tried changing the wireless mode to 802.11ac.
Please advise.
Esteban_D_Intel
Hello Manny,
To better assist you I would appreciate if you could provide the following information:
  • Please provide the steps to replicate this behavior.
  • Do you remember if this issue happened after a new OS update or Wireless driver update?
  • Were any changes made prior to this situation?
  • Is this the original adapter that came pre-installed in your system or have you changed/installed a new adapter recently?
  • What driver have you tested? Please provide version.
Please run the following tool and attach the reports generated.
Intel® System Support Utility (Intel® SSU) Download link
1. Open the application and click on "Scan" to see the system and device information.
2. By default, Intel® SSU will take you to the "Summary View".
3. Click on the menu where it says "Summary" to change to "Detailed View".
4. To save your scan, click on "Next", then "Save".
Esteban D.
Intel Technical Support Technician
Esteban_D_Intel
Hello Manny,
Were you able to check the email that I send you?
Please let me know if you need further assistance.
Esteban D.
Esteban_D_Intel
Hello Manny,
We have not heard back from you.
If you need any additional information, please submit a new question as this thread will no longer being monitored
Esteban D.
