Wireless
8567 Discussions
Adonde consigo una placa de red WiFi modelo 112bnhmw ?
CAlva25
n_scott_pearson
I am answering you here. Please delete the other three version of the question that you created (here, here and here).
The 112BNHMW is a Intel Centrino Wireless-N 1000 b/g/n module designed for the mini-PCIe connector. You can purchase them through Amazon. Here is link to entry: https://www.amazon.com/Centrino-Wireless-N-112BNHMW-300Mbps-Wireless/dp/B009WJ44CA.
Hope this helps,
CAlva25
Thank you for your prompt response. According to the specifications is compatible with Windows XP and Windows 7. What is not compatible with windows 10 x64? Enviado desde mi smartphone Samsung Galaxy. -------- Mensaje original -------- De: Intel Forums <supportreplies@intel.com> Fecha: 7/5/20 22:37 (GMT-03:00) Para: c_a_alvarez_@hotmail.com Asunto: n.scott.pearson le ha respondido: Adonde consigo una placa de red WiFi modelo 112bnhmw ? I am answering you here. Please delete the other three version of the question that you created (here, here and here). The 112BNHMW is a Intel Centrino Wireless-N 1000 b/g/n module designed for the mini-PCIe connector. You can purchase them through Amazon. Here is link to entry: https://www.amazon.com/Centrino-Wireless-N-112BNHMW-300Mbps-Wireless/dp/B009WJ44CA. Hope this helps, ...S [https://forums.intel.com/ncsphoto/9piV2awv8q83s15ANWzurpy7G3ZB-7zbqATbsmIndlJ_aPTirBiN6mmmZ_BReZOh?fromEmail=1]<https://forums.intel.com/0050P000008IalM?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> n.scott.pearson<https://forums.intel.com/0050P000008IalM?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> (Cliente) I am answering you here. Please delete the other three version of the question that you created (here<https://forums.intel.com/s/question/0D50P00004fMOhy/que-placa-wifi-puede-reemplazar-al-modelo-112bnhmw-en-una-notebook-hp-pavilion-dv5-2148la-?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterPostNotification&s1uid=0050P000008IalM&emtm=1588898824608&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000...>, here<https://forums.intel.com/s/question/0D50P00004fMPaV/where-i-get-in-argentina-a-model-112bnhmw-wifi-network-?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterPostNotification&s1uid=0050P000008IalM&emtm=1588899976015&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterComme...> and here<https://forums.intel.com/s/question/0D50P00004fMOhz/that-wifi-plate-can-replace-the-112bnhmw-model-in-an-hp-pavilion-dv5-2148the-?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterPostNotification&s1uid=0050P000008IalM&emtm=1588900055229&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext...>). The 112BNHMW is a Intel Centrino Wireless-N 1000 b/g/n module designed for the mini-PCIe connector. You can purchase them through Amazon. Here is link to entry: <https://www.amazon.com/Centrino-Wireless-N-112BNHMW-300Mbps-Wireless/dp/B009WJ44CA> https://www.amazon.com/Centrino-Wireless-N-112BNHMW-300Mbps-Wireless/dp/B009WJ44CA. Hope this helps, ...S Ver/Responder<https://forums.intel.com/0D70P000006iJoZ?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> o responda a este correo electrónico En respuesta a [https://forums.intel.com/img/userprofile/default_profile_45_v2.png?fromEmail=1]<https://forums.intel.com/0050P000008uqYA?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> CAlva25<https://forums.intel.com/0050P000008uqYA?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> (Cliente) ha hecho una pregunta. jueves, 7 de mayo de 2020 21:45<https://forums.intel.com/0D50P00004fMOJl?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D&OpenCommentForEdit=1> Adonde consigo una placa de red WiFi modelo 112bnhmw ? [https://forums.intel.com/ncsphoto/9piV2awv8q83s15ANWzurpy7G3ZB-7zbqATbsmIndlJ_aPTirBiN6mmmZ_BReZOh?fromEmail=1]<https://forums.intel.com/0050P000008IalM?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> n.scott.pearson<https://forums.intel.com/0050P000008IalM?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> (Cliente) I am answering you here. Please delete the other three version of the question that you created (here<https://forums.intel.com/s/question/0D50P00004fMOhy/que-placa-wifi-puede-reemplazar-al-modelo-112bnhmw-en-una-notebook-hp-pavilion-dv5-2148la-?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterPostNotification&s1uid=0050P000008IalM&emtm=1588898824608&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000...>, here<https://forums.intel.com/s/question/0D50P00004fMPaV/where-i-get-in-argentina-a-model-112bnhmw-wifi-network-?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterPostNotification&s1uid=0050P000008IalM&emtm=1588899976015&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterComme...> and here<https://forums.intel.com/s/question/0D50P00004fMOhz/that-wifi-plate-can-replace-the-112bnhmw-model-in-an-hp-pavilion-dv5-2148the-?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterPostNotification&s1uid=0050P000008IalM&emtm=1588900055229&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext...>). The 112BNHMW is a Intel Centrino Wireless-N 1000 b/g/n module designed for the mini-PCIe connector. You can purchase them through Amazon. Here is link to entry: <https://www.amazon.com/Centrino-Wireless-N-112BNHMW-300Mbps-Wireless/dp/B009WJ44CA> https://www.amazon.com/Centrino-Wireless-N-112BNHMW-300Mbps-Wireless/dp/B009WJ44CA. Hope this helps, ...S jueves, 7 de mayo de 2020 22:37<https://forums.intel.com/0D70P000006iJoZ?fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> Está recibiendo correos electrónicos cuando alguien "Comentarios sobre mis publicaciones". Para cambiar o desactivar el correo electrónico Forums, iniciar sesión<https://forums.intel.com/_ui/core/feeds/notification/ChatterEmailSettings?setupid=CollaborationEmailSettings&fromEmail=1&s1oid=00DU0000000YT3c&s1nid=0DB0P000000U1Hq&s1uid=0050P000008uqYA&s1ext=0&emkind=chatterCommentNotification&emtm=1588901825803&emvtk=5new6G6sedEkGRSf_Pgh_uv9XF8mPmygn.Zns35peR8%3D> como 300002681959@intel.com.isvc. ¿Están empezando a molestar las notificaciones acerca de esta publicación? Responda a este mensaje de correo electrónico con la palabra " mute ". For Privacy and Legal notices, please visit these links: http://www.intel.com/privacy, https://www.intel.com/content/www/us/en/legal/terms-of-use.html. [Forums]
n_scott_pearson
Well, as you can see, you should not respond through email! 😖
Windows support for its various wireless modules is documented here: Supported Operating Systems for Intel Wireless Products.
As you can see, the Intel Centrino Wireless-N 1000 module was discontinued a number of years ago and Intel's support for this module was terminated at Windows 8.1. Microsoft ported this driver to Windows 10 and provided it inbox - which means that support for it should have automatically been installed - but it is possible that Microsoft dropped this support in the latest releases, I don't know.
