Wireless
8534 Discussions
Advanced-N 6235 adapter unable to find networks. Bluetooth not finding either.
Hi all:
I just installed an Advanced-N 6235 mini PCIe adapter into a DQ77KB motherboard. (The system works flawlessly with a USB-N53 adapter from Asus. That is how I am typing this. 4 wireless networks are available to the Asus adapter)
When I inserted the card, it went in easily at about a 40* angle. I had to apply pressure to keep it flat when inserting the 2 little end screws. Is that how it should be done?
I downloaded the latest Windows 8 64-bit drivers from the Intel site. 15.6.0.19 is the driver version installed. When I run Intel PROSet Wireless -> WiFi Manual Diagnostics - Run Tests, it says the hardware is enabled, the 15.6.0.19 driver is loaded and the radio is on, but the scan test fails.
Do I need to do anything else to get it to scan properly? Is there anything special I need to set in the Advanced properties?
Also, the bluetooth scan of a new keyboard doesn't work. It found the keyboard once (after many failed attempts), appeared to load the drivers, allowed me to type about 4 characters, and then lost the connection permanently. It cannot find it again when I scan. It appears that there are a lot of bluetooth drivers installed on my system.
Any ideas would be appreciated. I'd really like to get this working and free up 2 USB ports on my DQ77KB.
Thank you.
Victor_B_Intel
Thank you very much for your post Ians,
NOn regards to your question, please note that the Intel® Centrino® Advanced-N 6235 wireless adapter is meant to be professionally installed by Original Equipment Manufacturer (OEM) technicians on certified systems only.
Also, please note that these adapters are not meant to be sold separately since your system must be compliant with the required FCC certifications in compliance with the International Special Committee for Radio Interference standards for radiated and conducted electromagnetic interference.
For additional information, refer to:
Intel® WiFi Products - Upgrade or exchange Intel® wireless adapter hardware
http://www.intel.com/support/wireless/wlan/sb/CS-006006 http://www.intel.com/support/wireless/wlan/sb/CS-006006
Intel® WiFi Products - Why doesn't my laptop recognize my new Intel wireless adapter?
http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm http://www.intel.com/support/wireless/wlan/sb/CS-031167.htm
I hope this helps
Victor_B_Intel
I hope this helps
