Wireless
8563 Discussions
After upgrading to Windows 8.1, initial internet access is delayed
etaus
I have been using Windows 8.0 and N6235 without problems in a Series 9 Samsung notebook. After booting, it took a few seconds to connect to the internet through my router and I have had no inconveniences so far.
I upgraded to Windows 8.1 and from that point onwards, after booting or resuming, internet access is not available for usually more than 1 minute (it can sometimes be 2 or 3 as well). The wireless connection icon indicates that internet is available, but no program can connect. Without doing anything but waiting, the issue solves itself and connection is available again.
As additional comments :
a. Google Talk now has an additional task which is Proxy Authentication, and I don't use any proxy
b. I have upgraded drivers to latest wireless drivers that Samsung offers and the result is the same.
c. I have run the Intel software detection applet and it indicates that all drivers are up to date
Does anyone have any idea how to eliminate this delay ? I don't know how proxy authentication works, but it looked to me as this was somehow introduced by the upgrade and I cannot find a clue that this is true and/or how to fix it. (if this is the culprit).
etaus
Issue solved. Norton Internet Security needed an upgrade. Thanks anyway.
MMart351
I have this same issue since upgrading to Windows 8.1 using a Centrino N 2230. Everything was fine using Win 8.0
When I boot up the PC the WIFI connects immediately, however if I need to reboot for any reason the WIFI will not connect for about 2 minutes even if I try to manually connect.
I'm using the latest drivers 16.5.3 and the Intel WiFi Connection Utility.
Authentication on my router is set to WPA2 AES. I have tried with No Encryption and it reacts the same way.
Not using any Internet Security other than the built in Windows Defender.
Jose_H_Intel1
It does not make sense why it works properly on a cold start but not on reboot; so far we can only tell it is not an authentication issue. Have you tested using static IP address?
Perhaps testing the system in safe mode with networking may also help troubleshooting the issue further.
http://windows.microsoft.com/en-us/windows-vista/advanced-startup-options-including-safe-mode http://windows.microsoft.com/en-us/windows-vista/advanced-startup-options-including-safe-mode
MMart351
Hi Joe,
I realize this doesn't make much sense but its happening. I've been wrecking my brain trying to figure this out!
I just tried your two suggestions...
Setup the network using static IP - no change.
Tried Safe Mode with networking - no change.
Jose_H_Intel1
Taking a look into a log may help determining what happens; these are the steps to create a log:
  • Open Intel® Proset Connection Utility.
  • Go to Tools, Intel® Wireless Troubleshooter, Wireless Event Viewer.
  • Click on File, Settings. Make sure the first box is checked and choose the log's location and filename.
  • Go to the Driver Log tab and check all boxes. Click OK.
At any moment the log file will appear in the selected folder but it may not be immediate. You may keep note of the time and restart your system for the activity to be recorded.
MMart351
# EventSourceTimeError SeverityDomainUserDescription1ZeroConfigService11/15/2013 22:59InformationGeneralSYSTEMIntel® WiFi HotSpot Assistant is active2ZeroConfigService11/15/2013 22:59InformationGeneralSYSTEMIntel® WiFi Paid HotSpot Assistant is active3ZCfgSvc11/15/2013 22:59InformationGeneralSYSTEMASTK: The adapter does not suppport Asset Tracking!4ZCfgSvc11/15/2013 22:59InformationGeneralSYSTEMASTK: The adapter does not suppport Asset Tracking!5Profile Manager API11/15/2013 22:59ErrorProfileTexelAn unexpected error occurred!6Profile Manager API11/15/2013 22:59ErrorProfileSYSTEMAn unexpected error occurred!7ZCfgSvc11/15/2013 22:59InformationGeneralSYSTEMApplying last profile.8S24EvMon11/15/2013 22:59ErrorAppDriverSYSTEMProfile extraction error9Profile Manager API11/15/2013 22:59ErrorProfileTexelAn unexpected error occurred!10Profile Manager API11/15/2013 22:59ErrorProfileSYSTEMAn unexpected error occurred!11Profile Manager API11/15/2013 22:59ErrorProfileSYSTEMThe specified profile type is not supported.12Profile Manager API11/15/2013 22:59WarningProfileTexelThe given profile already exists in the database.13Profile Manager API11/15/2013 22:59ErrorProfileTexelAn unexpected error occurred!14Profile Manager API11/15/2013 22:59ErrorProfileSYSTEMAn unexpected error occurred!15Profile Manager API11/15/2013 22:59ErrorProfileSYSTEMThe specified profile type is not supported.16Profile Manager API11/15/2013 22:59WarningProfileTexelThe given profile already exists in the database.17Task Tray11/15/2013 22:59InformationGeneralTexelEnd scan event from the service.18IWA11/15/2013 23:00InformationAdapterTexelScan end event from the Service.19ZCfgSvc11/15/2013 23:00InformationGeneralSYSTEMApplying last profile.20Profile Manager API11/15/2013 23:00ErrorProfileTexelAn unexpected error occurred!21Profile Manager API11/15/2013 23:00ErrorProfileSYSTEMAn unexpected error occurred!22Profile Manager API11/15/2013 23:00ErrorProfileSYSTEMThe specified profile type is not supported.23Profile Manager API11/15/2013 23:00WarningProfileTexelThe given profile already exists in the database.24Task Tray11/15/2013 23:00InformationGeneralTexelEnd scan event from the service.25IWA<td align="right" class="xl6...
Jose_H_Intel1
The log seems to be indicating some issues with the profile. Is it possible to delete the wireless profile from Intel® Proset Software and add it again?
Did anything else change before the issue started to happen?
MMart351
I've completely removed and added the profile multiple times so that can't be it.
Nothing else has changed other than the upgrade from Windows 8.0 to 8.1
Other people are experiencing this same issue from the upgrade. I have thread open on the Microsoft Answers page as well... http://answers.microsoft.com/en-us/windows/forum/windows8_1-hardware/delayed-wifi-connect-after-restart-only-since/11c2b5a8-66fb-408e-a6b0-bd11d56723a9 Delayed WIFI connect after restart only since upgrading to Windows 8.1 - Microsoft Community
MMart351
This is still an issue... are new drivers being worked on to address this or has a solution been found?
Many people have been posting about this on the Microsoft Community page...
Jose_H_Intel1
I read the replies in the Microsoft* thread, and based on ErSto's comments, this issue seems to be affecting non-Intel® wireless adapters too, which leads me to believe this is related to the operating system or other more specific configuration (VPN, system part of a domain, third party software, firewall, etc). It may also help to upgrade your AP's firmware or test with a different AP altogether.
MMart351
I wish Intel would release some new drivers for the N 2230 for 8.1
It worked flawlessly on 8.0
I found a lot of complaints here too...
http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductDetailsViewer?Type=Hardware&Name=Intel+Centrino+2230+Wireless+Network+Adapter&ModelOrVersion=2230BN.HMWG%2CHMWWB&Vendor=Intel&Locale=&LastSearchTerm=&BreadcrumbPath=&TempOsid=Windows+8.1 Windows 8.1 compatibility for Intel Centrino 2230 Wireless Network Adapter model 2230BN.HMWG,HMWWB
JInns
FWIW, Dell today released a http://www.dell.com/support/drivers/us/en/19/DriverDetails/Product/latitude-e7240-ultrabook?driverId=C8WJJ&osCode=WB64A&fileId=3328768843&languageCode=EN&categoryId=NI 8.1 driver set for the Intel 7260 with the following description:
Fixes:
- Reconnect the same SSID connection, it will take a long time and show limited.
Jose_H_Intel1
We will be releasing a new driver soon too. If the issue persists we will follow up then.
MMart351
Issue resolved using the following drivers...
File name: https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=23493&lang=eng&OSVersion=Windows%208.1%2C%2064-bit*&DownloadType=Software%20Applications Wireless_16.7.0_e164.exe
Version: 16.7.0
Date: 12/17/2013
Status: Latest
Operating Systems:Windows 8.1*, Windows 8.1, 64-bit*
