With the summary; “Ant tool” with BE200 network adapter parameters please. (2023 or 2024 version)
“ANT tool, Version 22.2000.0.0-05160 (C) 2007-2020 Intel corporation” is outdated, so unfortunately hardware ;
The parameters in the Ant.exe and HwDetection.xml files say “Detected hardware: Intel(R) Wi-Fi 7 BE200 320MHz". cannot be found.
With parameter information for the Intel(R) Wi-Fi 7 BE200 320MHz network adapter;
I cannot find Intel's new “ANT tool” version for 2023 or 2024. help please.
windows 11, 24H2, Intel Wireless WiFi 23.60.0.10
In the tests performed ;
“C:\ANT>ANT.exe --QueryMCC
(C) 2007-2020 Intel company / OEM Tools group. All rights reserved.
Detected hardware: (???? ---none.)
or any network adapter defined as crf_id=“0x0f” in the HwDetection.xml file;
for example:<Device name=“TYPHOON” crf_id=“0x0f” rf_type=“0x010D” />
C:\ANT>ANT.exe -QueryMCC
Error: The read command fails with the following condition: , 256 (error.
In short, for Intel(R) Wi-Fi 7 BE200 320MHz, with the following or Intel's “ANT Tool 2023 or 2024” actual information
<Device name=“GALE2” should contain crf_id=“0x0f” rf_type=“ 0x0F08” but this parameter
“Ant tool” that contains these parameters. please.
best regards
“Nart”
According to the given rf_type codes: 0x010C, 0x010A, 0x010A, 0x010A, 0x010D, 0x010D, 0x0F08 indicate the respective Wi-Fi technologies and frequency ranges. For example
802.11n :0x0105
802.11a : 0x0101 (5 GHz frequency)
802.11ac (Wi-Fi 5): 0x0108 (Thunder ac9260 /Jefferson - ac9460, 9461
802.11ax (Wi-Fi 6): 0x010C, 0x010A, 0x010D (Typhoon - ax210, ax1675, Garfield -ax211, ax411, ax1690
802.11be (Wi-Fi 7): x0F08 (Gale Peak) 2)
[code]<NVM_METADATA>
<Devices>
<Device name="GALE2" device_id="0x272B" /> OR
<Device name="GALE2" crf_id="0x0f" rf_type="0x0F08" /> cdb="0x01"/>
</Devices>
<Macs>
<MAC name="GALE2" mac_type="0x00??" />
</Macs>
</NVM_METADATA>
[/code]
Intel® Wi-Fi 7 BE200 (Gale Peak 2) : crf_id=0x0f
Intel® Wi-Fi 7 BE201 (Fillmore Peak 2): crf_id=0x10
Intel® Wi-Fi 7 BE202 (Misty Peak 2): crf_id=0x11
<Device name="Fillmore2" crf_id="0x10" rf_type="0x0F08" /> mac_type=? specific value
<Device name="Misty2" crf_id="0x11" rf_type="0x0F08" /> mac_type=? specific value
<Device name="Gale2" crf_id="0x0F" rf_type="0x0F08" /> mac_type=? specific value
Hello nart,
Thank you for posting in Intel Community. We see that you're looking for the latest version of the Ant Tools. However, we'd like to make sure that we are assisting you accurately.
- Can you tell us where you installed or how you got the tool for it?
- Can you show us a screenshot of the error message?
- May we request for the reason of why this tool is needed?
- Please generate a log file of your system using Intel® System Support Utility for Windows
We'll may have follow up questions depending on the answers. We will wait for your response.
Francis Ryan P.
Hello Francis Ryan P.
1.This tool is installed on my own old computer (I work from home)
It was forwarded to me by my R&D department 4 years ago. Unfortunately, the staff member who contacted me for this program in the past years left and I found out that he is no longer alive and that they could not find the new version or the Ant.exe and (HwDetection) files containing the new hardware parameters.
2.Attached is a screenshot of the error message (image attached)
Detected hardware: ??? (cannot find hardware information;
but finds installed hardware when crf_id=“0x0f” in any HwDetection file)
error with summary giving the message; exe and HwDetection “Intel(R) Wi-Fi 7 BE200, 201,202 does not contain device information.
3.The need for this tool is for my work.
Functional testing definition and user acceptance, functional, performance and stress testing, beta and delta testing, testing that examines potential user input at different stages throughout the software lifecycle. A company whose name I cannot share due to my contract. I am committed to supporting technological, agile development, creating more actionable feedback and maximizing product success and helping this company build high quality products that customers will love.
4.Attached is a log file of your system.
(I mentioned it in previous posts. I guess you haven't looked at the pictures in the previous attachment, I would appreciate it if you could check them out. )
Detected hardware:
C:\ANT>ANT.exe -SetMCC US -d append
(C) 2007-2020 Intel corporation / OEM Tools group. All rights reserved.
Detected hardware:
C:\ANT>
"ANT.exe -SetMCC US -d append"
Attached is a log file " AntToolLog.log"
AND
"C:\ANT>ANT.exe -SetMCC US -d append
Error: Read command fails with status: , 256
C:\ANT>"
Attached is a log file " BE200_AntToolLog.log"
Hello Nart,
Thank you for sharing the requested information. We'll check on our end and let you know once we have acquired the information we seek. Greatly appreciate your cooperation on this one.
Francis Ryan P.
Hello nart,
After reviewing the tool you've requested, we recommend reaching out to the Intel representative or Field Application Engineer (FAE) who previously provided the tool to obtain the latest version of the Ant Tool. Should they be unable to assist, you may request access through our Resource Documentation Center or Intel DevZone.
Please don't hesitate to reach out if you need further clarification. If you have any inquiries regarding Intel products in the future, feel free to open a new thread. Please note that this thread will no longer be actively monitored by Intel Customer Support, as no further action is required at this time. We appreciate your understanding and cooperation. Thank you for your time.
Francis Ryan P.
:)) Thank you for your time. Let's request access through Intel DevZone. thanks.
Merhaba Francis Ryan P.
Buradan herhangi bir çözüme yardımcı olmadığı için lütfen burada paylaşılan kişisel (tüm veriler) günlükleri, görüntüleri ve verileri silebilir misiniz?
Teşekkürler.
Hi Francis
I got error message while using -ant_isolation command in ANT tool. Could you help to check the BE200 module can support the command or not?
*Adapters: WiFi-7 BE200 320MHz
*Driver version: 23.70.0.6
C:\ANT7>ant -network Asus_AX88U_2.4G -ant_isolation
ANT tool, Version ANT.01908.23.70.0
(C) 2007-2024 Intel corporation / OEM Tools group. All rights reserved.
Detected hardware: Device Identified by crf_id: 0x0f
SetDeviceFromString: GALE
RF-Kill is Disabled (RF is ON)
ERROR: -ant_isolation is not supported for this HW.
Hi GP_Yu;
obviously there is no "GALE" support in the old version. i would like to help. (Version 22.2000.0.0-05160
(C) 2007-2020 Intel corporation / OEM)
you have the parameter -->"" Detected hardware: Device Identified by crf_id: 0x0f "" !!! interesting why you don't have such a hardware name;
Detected hardware: Intel(R) Wi-Fi 7 BE200 320MHz (should be)
HwDetection.xml can you review the file Do you have this parameter?
"<Device name="GALE" crf_id="0x0f" rf_type="0x0F08" /> "
I don't have your new "intel ant tool version for a long time. can you please share this new version 2024.
("ANT tool, Version ANT.01908.23.70.0
(C) 2007-2024 Intel corporation / OEM Tools group. All rights reserved." )
(*Adapters: WiFi-7 BE200 320MHz , *Driver version: 23.70.0.6 )
we have the same hardware and driver.
ant tool no installation required;
"Ant.exe,
Singletons.dll
HwDetection.xml,
AppTemplate.xml,
, TestCatalog.xml " As you know, the existence of their files is sufficient.
I would be grateful if you could share these files.
<email removed>
NART
Best regards
C:\ant>ant -network Tenda_B8B760_6G -ant_isolation
C:\ant>
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
