Wireless
8513 Discussões
Ax200 Indonesia Regulatory Domain is incomplete
silkatar900
Novato
3.395 Visualizações
Can't scan AP running on channel 36 because the card set itself to right regulatory domain but outdated list of allowable channel (checked using iw tools). Is there a way to update the allowable channel on this card ? For reference i attach latest pdf containing allowable channel (fetch from jdih(.)kominfo(.)go(.)id). Please refer to table 1 on page 18 to find list of allowable frequency range for RLAN devices, then go to Page 3 point 10 for definition of RLAN class devices.
9 Respostas
Jose_Intel
Funcionário
3.362 Visualizações
Hello @silkatar900
Thank you for posting on the Intel️® communities.
Our support is only provided in English. We may not be able to translate files attached to the thread. To better assist you, we use a translation tool, hence; the translation may not be completely accurate.
We understand your concern about the regulatory documentation, we will be more than happy to assist you.
Please allow us to research internally, as soon as we have any update, we will post here.
Jose B.
silkatar900
Novato
3.357 Visualizações
My worry is, because of this problem, it might hinder day to day activity where large scale ap deployment might require the new channel where this card can't connect to or provide poor performance in a case of roaming where some ap isn't accessible because of this. I have a little edit for my original post, Channel 36 was scannable not scannable but not nor connectable as self managed regulatory domain decides to disable channel 36 through 64 on ID regulatory domain.
JohnatanDoe
Principiante
3.306 Visualizações
Any Intel Wifi is pretty much useless, cannot even utilize full AC speed. I have AX201 which is built in on my OMEN15.
This has been discussed before on this thread
Wifi AX201 Lock Wifi Interface to 173.3Mbps (Channel Width 20MHz only) - Intel Community
However, there're no result until the end.
Seriously Intel, how hard is it to update your firmware to allow those channels ?? It's been years. And I really surprised that no tech channel / influencer bothered by this. Obviously we're not the only one affected by this ridiculous speed limitation on supposedly fast wifi 6/6E
silkatar900
Novato
3.298 Visualizações
I could only hope intel acknowledge and fix this problem then... AX200 is not EOL-ed yet right ? I've look at this card history on bugzilla and related to LAR feature, I really hope it's updateable via firmware loader function run by device drivers on linux and windows as well.
Jose_Intel
Funcionário
3.253 Visualizações
Hello silkatar900
Thank you for patiently waiting.
Please try this:
·      Recommended Settings for 802.11ax Connectivity URL https://www.intel.com/content/www/us/en/support/articles/000057574/wireless.html
·      Guide to Configure Wi-Fi Channels and Channel Widths to Improve Network Connection URL https://www.intel.com/content/www/us/en/support/articles/000058989/wireless/intel-killer-wi-fi-products.html
Once everything is configured, please share the outcome with us.
Jose B.
silkatar900
Novato
3.246 Visualizações
Hi Jose,
After trying both point you just mention, this wifi card (ax200) still cannot scan the AP running on channel 36. I have set default/recommended settings on ax200 based on table of Recomended settings above, and looked at wifi analyzer apps on android to confirm if there is any channel interference (confirm no interference on channel 36). I also changed my AP to 40Mhz and it's still didn't fix wifi scanning issue on channel 36.
SilkATar
Jose_Intel
Funcionário
3.218 Visualizações
Hello silkatar900
Thank you for following our steps.
Please let us continue our research. We will post any update here.
Jose B.
Jose_Intel
Funcionário
3.183 Visualizações
Hello silkatar900
We received an update on this matter. Our network adapter (Intel® Wi-Fi 6 AX200 (Gig+)) doesn't block or manage channel settings, those should be managed via AP.
In addition, channel availability is regulated by each country we don't control channel allowance.
In this case, we highly recommend checking with the system manufacturer for further assistance. Please keep in mind that this case will no longer be monitored.
Jose B.
silkatar900
Novato
3.164 Visualizações
Hi Jose,
I know this might be my last reply to this post, but please let me write this in my thread. Thank you for replying and clarifying the problem i had. It was managed by AP because AP announced itself the Regulatory domain, then AX200 applied known channel saved in the card itself. So i don't really agree with my network adapter (Intel® Wi-Fi 6 AX200 (Gig+)), not being in control of what channel it allowed to transmit because it contradicts with what my AP known as good channel to transmit itself.
I get myself a new home in german, and it applied itself new channel allowance. So let me thank you for your help and the engineer that help you along the way to answer my question in this thread.
Goodbye,
SilkATar
Responder
