Wireless
8513 討論
BE200 connect to 802.11ax only from Intel driver 23.50
Davidd1
初學者
3,911 檢視
I installed a BE200 adapter in my desktop, and it can be connected to 802.11be when the Intel driver version is under 23.50, but once I updated to 23.50 and above version, BE200 can only connect to 802.11ax.
And I never able to connect to MLO no matter the driver version, any help is appreciated!
My OS: win11 24H2 with preview release version 26100.1301
Intel BE200 driver: 23.60.1.2
0 積分
8 回應
Davidd1
初學者
3,904 檢視
Attached with the SSU log
DeancR_Intel
主席
3,745 檢視
Hi Davidd1,
Apologies for the delay in my response.
Thank you for the SSU logs and upon reviewing, I cannot find your wireless card BE200 in the logs. Also, I would suggest the newest version of your wireless card (23.70.2).
Here's the link for reference:
Intel® Wireless Wi-Fi Drivers for Windows® 10 and Windows 11*
I recommend clean install of the wireless driver.
Here's the link for guide and reference:
Clean Installation of Wireless Drivers (intel.com)
Let us know if you encounter any issues
Dean R.
Davidd1
初學者
3,718 檢視
I found that the 11be is disabled by default since 23.40 from this release note, would you please help to let me know how to enable 11be in BIOS?
DeancR_Intel
主席
3,600 檢視
Hi Davidd1,
We would like to clarify if you changed your wireless card because we need to further investigate this matter. Upon looking to your motherboard specifications, it only supports Wi-Fi 6.
Dean R.
DeancR_Intel
主席
3,539 檢視
Hi Davidd1,
Dean R.
Davidd1
初學者
3,500 檢視
the orignal wifi adapter is wifi 6, I added 1 PCIE wifi 7 network adapter, and I found once the driver update above 23.40 then I can only connect to ax protocol since I am in China region.
DeancR_Intel
主席
3,465 檢視
Hi Davidd1,
Do please wait for our higher ups working on this case to be able to provide a resolution to your inquiry. Please do give us more time to this, we will get back to you possibly when I have the necessary information.
Dean R.
DeancR_Intel
主席
3,308 檢視
Hi Davidd1,
Based on the release notes for the WIFI driver version: 23.70.2, the driver comes with the Wi-Fi 7 Regulatory updates for China and South Korea.
With this in mind, there may be a compatibility issue after self-integrating the Intel wireless Wi-Fi 7 BE200 card on this system. Please do note that the compatibility and limitation are dependent on how the system was designed.
We suggest contacting your system manufacturer or motherboard manufacturer to check the compatibility of the self-integration of the wireless card.
Dean R.
回覆
